Applying QoS Constraint to a Realm You apply QoS constraints to realms using the qos-constraint parameter. To apply a QoS constraint to a realm: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type media-manager and press Enter ORACLE(configure)# media-manager ORACLE(media-manager)# Type realm-config and press Enter. If you adding this feature to a pre-existing realm, then you need to select and edit that realm. ORACLE(media-manager)# realm-config ORACLE(realm-config)# qos-constraints—Enter the name value from the QoS constraints configuration you want to apply to this realm. Save and activate your configuration.
