H.232 Interfaces Configuration
These are the ACLI parameters that you set:
name Name of the stack state State of the stack isgateway Enable the stack to run as a gateway terminal-alias List of aliases for terminal ras-port Listening port for RAS request gk-identifier Gatekeeper's identifier q931-port Q.931 call signalling port alternate-transport Alternate transport addresses/ports q931-max-calls Maximum number of Q.931 calls max-calls Stack's maximum number of calls max-channels Maximum number of channels per channel
To access the H.323 interface (h323-stack) and service mode parameters:
