Creating a Codec Policy
To create a codec policy:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the signaling-related configurations.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type codec-policy and then press Enter.
ORACLE(media-manager)# codec-policy ORACLE(codec-policy)#
- name—Enter the unique name for the codec policy. This is the value you will use to refer to this codec policy when you apply it to realms or session agents. This parameter is required and is empty by default.
allow-codecs—Enter the list of media format types (codecs) to allow for this codec policy. In your entries, you can use the asterisk (*) as a wildcard, the force attribute, or the no attribute so that the allow list you enter directly reflects your configuration needs. Enclose entries of multiple values in parentheses ( ( ) ). For more information, refer to the
Manipulation Modes section above.
The codecs that you enter here must have corresponding media profile configurations.
allow-codecs can be used to construct ingress, egress, or conditional codec policies. For details of conditional codec policies, refer to Conditional Codec Policies.
add-codecs-on-egress—Enter the codecs that the
Oracle® Enterprise Session Border Controller adds to an egress SDP offer if that codec is not already there. This parameter applies only to egress offers. For more information, refer to the
add-codecs-on-egress can be used to construct ingress, egress, or conditional codec policies. For details of conditional codec policies, refer to Conditional Codec Policies.
order-codecs—Enter the order in which you want codecs to appear in the outgoing SDP offer. Remember that you can use the asterisk (*) as a wildcard in different positions of the order to directly reflect your configuration needs. Enclose entries of multiple values in parentheses ( ( ) ). For more information, refer to the
order-codecs can be used to construct ingress, egress, or conditional codec policies. For details of conditional codec policies, refer to Conditional Codec Policies.
Save and activate your configuration.
Your codec policy configuration will resemble the following example:
codec-policy name private allow-codecs g723:no pcmu video:no order-codecs pcmu *
