SIP Embedded Route Header Configuration To set the Oracle® Enterprise Session Border Controller’s default behavior of using embedded route headers from ENUM queries or LRT lookups: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type session-router and press Enter. ORACLE(configure)# session-router ORACLE(session-router)# Type sip-config and press Enter. If you are adding this feature to a pre-existing SIP configuration, you will need to select and edit it. ORACLE(session-router)# sip-config ORACLE(sip-config)# use-embedded-route—Configure this as an option with one of the following arguments: all = use embedded routes from both ENUM and LRT results (default) none = do not use embedded routes enum = use embedded routes from ENUM results only lrt = use embedded routes from LRT results only In order to append the new option to the sip-config’s options list, you must prepend the new option with a plus sign. For example: Set the options parameter by typing options, a Space, the option name use-embedded-route, and then press Enter. ORACLE(sip-config)# options +use-embedded-route=none Save your work using the ACLI done command.
