SIP HNT Forced Unregistration Configuration
To enable SIP HNT forced unregistration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the
session-router path.
ORACLE(configure)# session-router
Type
sip-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config
Use the ACLI
select command so that you can work with the SIP configuration.
ORACLE(sip-config)# select
options—Set the options parameter by typing
options, a Space, the option name
force-unregistration, and then press Enter.
ORACLE(sip-config)# options +force-unregistration
If you type options force-unregistration, you will overwrite any previously configured options. In order to append the new option to the sip-config’s options list, you must prepend the new option with a plus sign as shown in the previous example.
