show xcode session-byid
The show xcode session-byid command displays detailed information about the supplied software based transcoding session. The session-byid command displays the configuration of each channel as well as a number of packet statistics for each channel. This same information can be looked up by IP address and port by using the show xcode session-byip command. If only the configuration portion is required, use the session-config command with the session id as the argument.
This command is entered as:
# show xcode session-byid 0x10001 17:53:01 ################# SESSION 0x10001 ################## Channel 0: HSP device = 0 Egress Interface = 0 Src IP:Port = 172.16.0.241:10000 Dst IP:Port = 172.16.0.15:6000 Codec = G711_ALAW_PCM Payload Type = 8 Pkt Interval = 20 msec Status = ENABLED HSP Counters: RxPackets 996 RxLatePackets 0 RxMisorderedPackets 0 RxBadPackets 0 RxEarlyPackets 0 RxDroppedPackets 0 RxFailures 0 TxPackets 993 TxFailures 0 Channel 1: HSP device = 0 Egress Interface = 1 Src IP:Port = 192.168.0.241:10000 Dst IP:Port = 192.168.0.15:6000 Codec = G711_ULAW_PCM Payload Type = 0 Pkt Interval = 20 msec Status = ENABLED HSP Counters: RxPackets 996 RxLatePackets 0 RxMisorderedPackets 0 RxBadPackets 0 RxEarlyPackets 0 RxDroppedPackets 0 RxFailures 0 TxPackets 993 TxFailures 0
