process-implicit-tel-URI Configuration
To enable proccess-implicit-tel-URI
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config
and press Enter.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
options—Set the options parameter by typing
options, a Space, the option-name
proccess-implicit-tel-URI with a plus sign in front of it, and then press Enter.
ORACLE(sip-config)# options +proccess-implicit-tel-URI
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the SIP interface configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
