Network Interface Configuration
These ACLI command sequences configure two network interfaces. The first sequence configures a network interface named m10, thus associating the network interface with the physical interface of the same name. The ACLI ip-address command assigns the IPv4 address 172.16.10.76 to the network interface. In a similar fashion, the second command sequence associates the m01 network and physical interfaces, and assigns an IPv4 address of 182.16.10.76.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m10 ORACLE(network-interface)# ip-address 172.16.10.76 ... ... ... ORACLE(network-interface)# ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m01 ORACLE(network-interface)# ip-address 182.16.10.76 ... ... ... ORACLE(network-interface)#
