PreviousNextJavaScript must be enabled to correctly display this content
SIP-ISUP Format Interworking Configuration
This section show you how to set up a SIP-ISUP format interworking. First, you configure a SIP ISUP profile, and then you apply it to a realm, session agent or SIP interface.
To set up a SIP ISUP profile:
In Superuser mode, type
configure terminal and press Enter.
name—Enter the name of the SIP ISUP profile. You will use this name when you apply this profile to realms, session agents, and SIP interfaces. This parameter is required, and it has no default value.
isup-version—Specify the ISUP version you want to which you want to covert:
ansi-2000,
itu-99, gr-317, or
etsi-356.
convert-isup-format—Set this parameter to
enabled if you want to perform SIP ISUP format version interworking. The default is
disabled, meaning that this feature is turned off.
