IWF Topology Hiding Configuration
To enable IWF topology hiding on your Oracle® Enterprise Session Border Controller :
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the signaling-level configuration elements.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config and press Enter. The system prompt changes.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
Use the ACLI
select command so that you can work with the session agent configuration to which you want to add these options.
ORACLE(session-agent)# select
options—Set the options parameter by typing
options, a Space, the option name preceded by a plus sign (+) (replace-call-origin-ip), and then press Enter. Follow the same steps to add the
NoPAssertedID option.
ORACLE(session-agent)# options +replace-call-origin-ip ORACLE(session-agent)# options +NoPAssertedID
If you type either of these options without the plus (+) sign, you will remove any previously configured options. In order to append the new option to the options list, you must prepend the new option with a plus sign as shown in the example above.
