Abbreviated Configuration Summary
Adding the short argument to the end of any show config or show running config command instructs the system to display an abbreviated output. The short argument tells the system to display only those parameters whose values have changed from the defaults.
ORACLE# show run sip-interface short sip-interface realm-id net172 sip-port address 172.16.101.11 registration-caching enabled sip-interface realm-id net192 sip-port address 192.168.101.11 registration-caching enabled
