Configuring Digest Authentication
In the Oracle® Enterprise Session Border Controller ACLI, you can access the Digest Authentication object at the path session-router->session-agent->auth-attribute. If enabled, the Digest Authentication process uses the attributes and values listed in this table.
If enabling Digest Authentication, all attributes listed below are required except for the in-dialog-methods attribute which is optional.The following table lists the digest authentication object
ORACLE(auth-attribute)# show
auth-attribute
auth-realm realm01
username user
password ********
in-dialog-methods ACK INVITE SUBSCRIBE
To configure digest authentication on the Oracle® Enterprise Session Border Controller:
- INVITE | BYE | ACK | CANCEL | OPTIONS | SUBSCRIBE | PRACK | NOTIFY | UPDATE | REFER
ORACLE(auth-attribute)# in-dialog-methods (ack invite subscribe)Note:
The methods not in this list are still resubmitted if a 401/407 response is received by the Oracle® Enterprise Session Border Controller.If you do not specify any in-dialog-method value(s), digest authentication does not add challenge-responses to in-dialog requests within a dialog.
This attribute setting applies to in-dialog requests only.
