Static Stack Selection
In static stack selection, the outgoing stack is determined though the establishment of associated stacks in the h323 stack.
The incoming stack (configured in the h323 stack) uses its associated stack value to determine the associated outgoing stack. The associated stack value corresponds to the name of an h323 stack. This type of selection is referred to as static because the incoming stack always uses the stack specified in the associated stack as the outgoing stack; no other stacks are considered.
