Precedence
The Oracle® Enterprise Session Border Controller applies SIP header rules in the order you have entered them. This guards against the Oracle® Enterprise Session Border Controller removing data that might be used in the other header rules.
This ordering also provides you with ways to use manipulations strategically. For example, you might want to use two rules if you want to store the values of a regular expression. The first rule would store the value of a matched regular expression, and the second could delete the matched value.
In addition to taking note of the order in which header rules are configured, you now must also configure a given header rule prior to referencing it. For example, you must create Rule1 with the action store for the Contact header BEFORE you can create Rule2 which uses the stored value from the Contact header.
