The Messaging module of Oracle Lending is designed to handle your outgoing and incoming messages. The module supports various types of media. Besides standard media modes like Mail, Telex, and SWIFT you can also use other media types supported by the Media Control System (MCS) installed at the node at which the database of your branch is installed. Oracle Lending gives native support for media like Mail, Telex, and SWIFT using EMS as the MCS.
While defining a product, you can indicate the messages that should be generated for the events that take place during the lifecycle of contracts involving the product. When the events for which a message should be generated occur, the message will be automatically generated and sent to the concerned party. The message will be transmitted to the customer’s address through the media that you have specified, and in the format and language that you maintain for the customer – message combination.
While entering the details of a contract you can choose to generate or suppress the message. You also have the option to prioritize the urgency with which a SWIFT message should be generated.
In the case of outgoing messages, the module provides for the generation of messages using formats that you can define. By maintaining message formats you can ensure consistency across the branches of your bank. The module provides a host of features to enter or authorize test words and to interface with media control systems to actually generate the message.
Several customer addresses for a given media
With Oracle Lending’s multi-branch set up, the customers of your bank can operate their accounts from several locations. Based on the convenience of your customers, you can send messages to locations of their choice.
Oracle Lending provides for the setting up of several addresses for a given customer - media combination.
In addition, you can also associate a language with an address. All messages sent to the address are expressed in the language that you indicate.
Free format messages
In the course of your daily banking operations you may want to generate messages that are not automatically generated by the system or you may have to communicate a message that is very specific to a customer.
In Oracle Lending, you can personalize a message by defining a free format message and linking it to a customer - address combination. Whenever the message is to be generated it bears the personalized format that you have defined.
MCS maintenance
The messages that are sent from and delivered to your bank are transmitted and received from sources that are external to Oracle Lending. In Oracle Lending, these external sources are called Media Control Systems (MCS).
In a distributed environment, the database of a branch is located in a node or server. The MCS of the messages are also installed in a node. Thus, while defining an MCS you need to also indicate the node in which it is installed.
In case of incoming messages, you can set up of various message queues and direct incoming messages to them. You can further grant selective access to the queues to personnel at your bank who are authorized to handle incoming messages.
Archival is the process of storing old messages for future retrieval. While defining messaging preferences for your branch, you can specify the number of days for which an outgoing message should be kept in the Outgoing Message Browser. Messages are automatically archived after the number of days specified for your branch.
You can retrieve the messages that have been archived at anytime and process them just as you would any other message.
You can specify messaging preferences that governs the workflow aspects of the messaging system module at your branch. You can indicate the following preferences:
The Electronic Messaging Process is for both incoming and outgoing messages in Oracle Lending.
In Incoming EMS Process, a job is scheduled to poll the incoming folder on timely basis. Once a message is received in the folder, the job picks the message and sends it to an internal JMS queue. An MDB listening on the queue reads the message and identifies the media and processes the message.
In Outgoing EMS Process a job is scheduled to poll the outgoing messages that are generated but not handed off. Each messages polled is sent to an internal JMS queue. An MDB, acting upon the internal JMS queue picks the message from queue and sends the message to appropriate destination (Folder, or e-mail, or JMS queue).
The Outgoing EMS Process is in two layers. The EMS process as part of jobs in FCJ scheduler, polls the outgoing message table of FLEXCUBE for generated and un-send messages. The job then sends minimal data about the message to be handed off, to an internal JMS queue. The EMS process as part of an MDB that listens on internal JMS queue builds final message and sends to their intended destinations.
The ‘EMS out’ job is available as factory shipped.
The Outgoing EMS Process as part of jobs scheduler is as follows:
The Outgoing EMS Process in MDB is as follows:
The following diagram illustrates outgoing EMS process in scheduler.
The following diagram illustrates outgoing EMS process in MDB.
The Incoming EMS Process is in two layers. The EMS process as part of jobs in FCJ scheduler, polls the pre configured folder for messages and sends the messages read, to EMS internal queue. The EMS process as part of an MDB listening on internal JMS queue, identifies the message from queue and calls the incoming messages service package to process the message.
The ‘EMS in’ job is available as factory shipped.
The Incoming EMS Process as part of jobs scheduler is as follows:
The Incoming EMS Process in MDB is as follows:
The following diagram illustrates incoming EMS process in Job Scheduler..
The following diagram illustrates incoming EMS process in MDB.
