1. Preface
1.1 Introduction
This manual is designed to help you maintain and process Over the Counter dealings in Interest Rate and Currency Options in Oracle FLEXCUBE. It also assists you in handling all the necessary activities in the life cycle of an OCT instrument once it is booked. This includes the generation of messages and reports, the accrual and liquidation of interest components, the application of charges and taxes and so on.
1.2 Audience
This manual is intended for the Customer Service Representatives (CSRs) and staff in charge of setting up new products in your bank.
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Acronyms and Abbreviations
The following are some of the acronyms and abbreviations you are likely to find in the manual:
BPEL
Business Process Execution Language
BPMN
Business Process Model and Notation
WF
Workflow
EOD
End of Day
BOD
Beginning of Day
KYC
Know Your Customer
ELCM
Enterprise Limits and Collateral Management
System/the system
Oracle FLEXCUBE system (unless otherwise specified).
1.5 Organization
This manual is organized as follows:
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual
Chapter 2
Maintenances describes about the general maintenance options available to ensure successful functioning of a credit appraisal management origina­tion process.
Chapter 3
Credit Appraisal Management Origination explains the workflow of a pro­cess and procedure to define and maintain the prospective corporate cus­tomer details.
Chapter 4
Credit Appraisal Management Closure/Transfer explains the workflow of a process and procedure to close / transfer facility.
Chapter 5
Credit Appraisal Management Covenant explains the workflow of a cove­nant process received from a client or customer.
Chapter 5
Credit Appraisal Management Covenant poller explains the workflow of a covenant poller process received from a client or customer.
Chapter 7
Reports lists the possible reports that can be generated for the module.
Chapter 8
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.6 Related Documents
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
