A customer order entry system creates customer orders and publishes CustOrder message family messages. These messages must be forwarded to the warehouse in the form of a StockOrder message. The CustOrderToStockOrderFromRib TAFR converts the message from the CustOrder format to a StockOrder determines which warehouse specific topic to publish the message to.
Other subscribers may also subscribe to the CustOrder message, but these subscribers will operate independently of the CustOrderToStockOrderFromRib TAFR and is out of scope for these requirements.
The routing information for a message is must contain the following routing info records
a) a “direct ship indication” routing info record determined by the name field of “direct_ship_ind”. A “value” field value of “Y” implies this is a direct shipment from a third party supplier to the end customer.
b) a “gift certificate indication” (name field of “gift_cert_ind”). A “value” field value of “Y” implies this is a gift certificate fulfilled by a third party supplier.
c) if neither the direct ship indication nor the gift certificate indication has a value of “Y”, then a routing info record with the name of “physical_warehouse_id” must be present. The value field of this record must be a valid warehouse location ID. This field is used to determine the warehouse specific topic to publish the stock order message to.
d)
routing info record with a name field of “facility_type” should be present. If
it is not present, then the default facility type from the RIB configuration is
used. This value, along with c) above, references a unique entry in the RIB
configuration that is used to determine the output topic for stock order
messages.
Published output messages for the warehouse will be sent to a warehouse
specific JMS destination. The following output message routing info records
will be added if not present on the input message:
a. facility_type – the facility type. The value used will come from the default facility type found in the configuration.
If the routing info records contain a direct shipment indication with a value of “Y” or a gift certificate with a value of “Y”, then the message will be published without changes to the supplier topic associated with the TAFR. This message will not be forwarded to a warehouse specific topic. The name of this topic will assume to come from the TAFR MDB deployment configuration.
Outbound messages will have the same values as the input messages for the RIB message envelope tags of : <ribmessageID>, <customFlag>, <customData>, <hospitalRef>, <hospitalID>, <failure>, <id>. If one of these input fields are not present, then the output message will also not contain this tag. Nested tags within these fields will also be copied. An input message may contain a null or missing <publishTime>, while the output message may contain a set publishTime. All output message <publishTime> fields must be set to a date/time equal to or after the input publishTime.
The <messageData> or “payload” string will contain a <DOCTYPE> tag detailing the URL of a document type definition file. The directory specification in this URL will reside in the configuration, thus allowing the customer to configure his/her own value. The name of the DTD file specified will be “SODesc.dtd” for output messages of the type “socre” and “SORef.dtd” for output message of the type “sodel”.
Input message fields assumed to be numeric will cause the TAFR to fail if a non-numeric value is found.
Capitalization
differences of the input message <type> value will be ignored. Input
messages having a <type> value of “cocre” will be mapped to an output
type of “socre”. The output payload class type for this set of messages will be
the com.retek.payload.SODesc class. The input payload class will be the
com.retek.payload.CODesc class. This class contains a COHdrDesc object used for
all of the SODesc element values.
The table below details the conversion between the COHdrDesc fields and the
SODesc fields. Any CODesc field not contained in the table will be ignored. Note
that some fields are input as strings and are mapped to numbers. In these
cases, the input is assumed to be a numeric string.
COHdrDesc field |
SODesc field |
Required for |
Comment |
amount1 |
amount1 |
Neither |
COHdrDesc uses string, SODesc is number. Implementation assumes input is string of a decimal number |
amount2 |
amount2 |
Neither |
Same as amount1 |
amount3 |
amount3 |
Neither |
Same as amount1 |
amount4 |
amount4 |
Neither |
Same as amount1 |
amount5 |
amount5 |
Neither |
Same as amount1 |
amount6 |
amount6 |
Neither |
Same as amount1 |
base_code |
priority |
Both |
base_code is string, priority is number. Implementation assumes an integer number string |
bill_address4 |
bill_address4 |
Neither |
bill_address5 |
bill_address5 |
Neither |
bill_to_address_line_2 |
bill_address2 |
COHdrDesc only |
bill_to_address_line_3 |
bill_address3 |
COHdrDesc only |
bill_to_city |
bill_city |
COHdrDesc only |
bill_to_country_code |
bill_country_id |
COHdrDesc only |
bill_to_full_name |
bill_address_desc |
COHdrDesc only |
bill_to_postal_code |
bill_zip |
COHdrDesc only |
bill_to_state_province |
bill_state |
COHdrDesc only |
bill_to_street_address |
bill_address1 |
COHdrDesc only |
break_by_distro |
break_by_distro |
COHdrDesc only |
calculated_shipping_amount |
shipping_total |
COHdrDesc only |
shipping_total is a number, implementation assumes calculated_shipping_amount is a decimal string |
carrier_code |
carrier_code |
Both |
carrier_service_type_code |
carrier_service_code |
COHdrDesc only |
chute_type |
chute_type |
Neither |
cartonization _flag |
cartonization |
COHdrDesc only |
consumer_direct_flag |
consumer_direct |
COHdrDesc only |
document_type |
document_type |
Both |
event_code |
event_code |
Neither |
event_description |
event_description |
Neither |
message |
message |
Neither |
order_line_cost |
order_line_costs |
COHdrDesc only |
order_number |
parent_customer_order |
COHdrDesc only |
order_total |
total |
COHdrDesc only |
Total is a number, order_total is a string. |
order_type |
order_type |
Both |
physical_warehouse_id |
dc_destid |
Both |
pick_complete |
pick_complete |
COHdrDesc only |
pick_not_after_date |
Both |
pick_not_before_date |
Both |
po_nbr |
po_nbr |
Neither |
promotions_total |
promotion_total |
COHdrDesc only |
promotion_total is number, promotions_total is string. |
rollback_allocation |
COHdrDesc only |
route |
route |
COHdrDesc only |
ship_address4 |
ship_address4 |
Neither |
ship_address5 |
ship_address5 |
Neither |
ship_to_city |
ship_city |
COHdrDesc only |
ship_request_id |
distro_nbr |
Both |
distro_nbr is a long, ship_request_id is a string. The implementation will assume ship_request_id is an integer in string form. |
ship_to_address_line_3 |
ship_address3 |
Neither |
ship_to_address_line_2 |
ship_address2 |
Neither |
ship_to_country_code |
ship_country_id |
COHdrDesc only |
ship_to_fullname |
ship_address_desc |
COHdrDesc only |
ship_to_postal_code |
ship_zip |
COHdrDesc only |
ship_to_state_province |
ship_state |
COHdrDesc only |
ship_to_street_address |
ship_address1 |
COHdrDesc only |
taxable_total |
tax_total |
COHdrDesc only |
tax_total is number, implementation assumes taxable_total is a decimal numeric string. |
CODesc records also contain one or more CODtlDesc records which are mapped to SODtlDesc records contained within an SODesc. The table below maps source CODtlDesc fields to output SODtlDesc fields. These fields are only copied when the input CODtlDesc record contains an item_status element with a case-insensitive value of “L”. All other CODtlDesc records are filtered and not copied.
Note that some fields are input as strings and are mapped to numbers. In these cases, the input is assumed to be a numeric string.
Any CODtlDesc field not included in the table below will be ignored.
CODtlDesc field |
SODtlDesc field |
Required for |
Comment |
amount1 |
amount1 |
Neither |
CODtlDesc uses string, SODtlDesc is number. Implementation assumes input is string of a decimal number |
amount2 |
amount2 |
Neither |
Same as amount1 |
amount3 |
amount3 |
Neither |
Same as amount1 |
amount4 |
amount4 |
Neither |
Same as amount1 |
amount5 |
amount5 |
Neither |
Same as amount1 |
amount6 |
amount6 |
Neither |
Same as amount1 |
gift_services_line_amt |
gift_cost |
CODtlDesc Only |
gift_cost is a decimal number |
item_number |
item_id |
Both |
item_status |
item_status |
Both |
order_line_nbr |
order_line_nbr |
CODtlDesc Only |
order_line_nbr is a 3-digit integer number for SODtlDesc and is a String for order_line_nbr in CODtlDesc |
prom_line_amt |
promotion |
CODtlDesc Only |
promotion is an Long (integer) number, prom_line_amt is a string |
rdm_dest_id |
dest_id |
Both |
requested_quantity |
requested_unit_qty |
Both |
requested_unit_qty is a decimal number, requested_quantity is a string |
sh_additional_line_amt |
shipping |
CODtlDesc Only |
Shipping is a decimal number, sh_additional_line_amt is a string |
tax_line_amt |
tax |
CODtlDesc Only |
Tax is a decimal number, tax_line_amt is a string. |
total_line_merch_amt |
sub_total |
CODtlDesc Only |
sub_total is a decimal number, total_line_merch_amt is a string. |
unit_selling_price |
retail_price |
CODtlDesc Only |
retail_price is a decimal number, unit_selling_price is a string. |
unit_tax_percent |
tax_percent |
CODtlDesc Only |
TAX_PERCENT is a decimal number, unit_tax_percent is a string. |
Capitalization differences of the input message <type> value will be ignored. Input messages having a <type> value of “codel” will be mapped to an output type of “sodel”. The output payload class type for this set of messages will be the com.retek.payload.SORef class. The input payload class will be the com.retek.payload.CORef class. The table below details the conversion between the CORef fields and the SORef fields. Any CORef field not contained in the table will be ignored.
CORef field |
SORef field |
Required for |
Comment |
ship_request_id |
distro_nbr |
Both |
document_type |
SORef Only |
Set to a hard-coded value of “C” |
rdm_dest_id |
dc_dest_id |
SORef Only |
Implementation will assume that RdmDestId is always set. |
The SORef element may contain an array of SODtlRef elements. Certain fields of the CORef input payload will be mapped to a single SODtlRef element added to the SORef payload element. These fields are detailed in the table below
CORef field |
SODtlRef field |
Required for |
Comment |
item_number |
item_id |
Both |
dest_id |
SODtlRef Only |
Set to a hard-coded value of “-1” |
