CustOrderToStockOrderTAFR
Overview
A customer order entry system creates customer orders and publishes CustOrder message family messages. These messages must be forwarded to the warehouse in the form of a StockOrder message. The CustOrderToStockOrderFromRib TAFR converts the message from the CustOrder format to a StockOrder determines which warehouse specific topic to publish the message to.
Other subscribers may also subscribe to the CustOrder message, but these subscribers will operate independently of the CustOrderToStockOrderFromRib TAFR and is out of scope for these requirements.
Functional Requirements
The routing information for a message is must contain the following routing info records
a)      a “direct ship indication” routing info record determined by the name field of “direct_ship_ind”. A “value” field value of “Y” implies this is a direct shipment from a third party supplier to the end customer.
b)      a “gift certificate indication” (name field of “gift_cert_ind”). A “value” field value of “Y” implies this is a gift certificate fulfilled by a third party supplier.
c)      if neither the direct ship indication nor the gift certificate indication has a value of “Y”, then a routing info record with the name of “physical_warehouse_id” must be present. The value field of this record must be a valid warehouse location ID. This field is used to determine the warehouse specific topic to publish the stock order message to.
d)      if neither the direct ship indication nor the gift certificate indication has a value of “Y”, then a routing info record with a name field of “facility_type” should be present. If it is not present, then the default facility type from the RIB configuration is used. This value, along with c) above, references a unique entry in the RIB configuration that is used to determine the output topic for stock order messages.
Published output messages for the warehouse will be sent to a warehouse specific JMS destination. The following output message routing info records will be added if not present on the input message:
a.       facility_type – the facility type. The value used will come from the default facility type found in the configuration.
If the routing info records contain a direct shipment indication with a value of “Y” or a gift certificate with a value of “Y”, then the message will be published without changes to the supplier topic associated with the TAFR. This message will not be forwarded to a warehouse specific topic. The name of this topic will assume to come from the TAFR MDB deployment configuration.
Outbound messages will have the same values as the input messages for the RIB message envelope tags of : <ribmessageID>, <customFlag>, <customData>, <hospitalRef>, <hospitalID>, <failure>, <id>. If one of these input fields are not present, then the output message will also not contain this tag. Nested tags within these fields will also be copied. An input message may contain a null or missing <publishTime>, while the output message may contain a set publishTime. All output message <publishTime> fields must be set to a date/time equal to or after the input publishTime.
The <messageData> or “payload” string will contain a <DOCTYPE> tag detailing the URL of a document type definition file. The directory specification in this URL will reside in the configuration, thus allowing the customer to configure his/her own value. The name of the DTD file specified will be “SODesc.dtd” for output messages of the type “socre” and “SORef.dtd” for output message of the type “sodel”.
Input message fields assumed to be numeric will cause the TAFR to fail if a non-numeric value is found.
Capitalization differences of the input message <type> value will be ignored. Input messages having a <type> value of “cocre” will be mapped to an output type of “socre”. The output payload class type for this set of messages will be the com.retek.payload.SODesc class. The input payload class will be the com.retek.payload.CODesc class. This class contains a COHdrDesc object used for all of the SODesc element values.
The table below details the conversion between the COHdrDesc fields and the SODesc fields. Any CODesc field not contained in the table will be ignored. Note that some fields are input as strings and are mapped to numbers. In these cases, the input is assumed to be a numeric string.
COHdrDesc field
SODesc field
Required for
Comment
amount1
amount1
Neither
COHdrDesc uses string, SODesc is number. Implementation assumes input is string of a decimal number
amount2
amount2
Neither
 Same as amount1
amount3
amount3
Neither
 Same as amount1
amount4
amount4
Neither
 Same as amount1
amount5
amount5
Neither
 Same as amount1
amount6
amount6
Neither
 Same as amount1
base_code
priority
Both
base_code is string, priority is number. Implementation assumes an integer number string
bill_address4
bill_address4
Neither
bill_address5
bill_address5
Neither
bill_to_address_line_2
bill_address2
COHdrDesc only
bill_to_address_line_3
bill_address3
COHdrDesc only
bill_to_city
bill_city
COHdrDesc only
bill_to_country_code
bill_country_id
COHdrDesc only
bill_to_full_name
bill_address_desc
COHdrDesc only
bill_to_postal_code
bill_zip
COHdrDesc only
bill_to_state_province
bill_state
COHdrDesc only
bill_to_street_address
bill_address1
COHdrDesc only
break_by_distro
break_by_distro
COHdrDesc only
calculated_shipping_amount
shipping_total
COHdrDesc only
shipping_total is a number, implementation assumes calculated_shipping_amount is a decimal string
carrier_code
carrier_code
Both
carrier_service_type_code
carrier_service_code
COHdrDesc only
chute_type
chute_type
Neither
cartonization _flag
cartonization
COHdrDesc only
consumer_direct_flag
consumer_direct
COHdrDesc only
document_type
document_type
Both
event_code
event_code
Neither
event_description
event_description
Neither
message
message
Neither
order_line_cost
order_line_costs
COHdrDesc only
order_number
parent_customer_order
COHdrDesc only
order_total
total
COHdrDesc only
Total is a number, order_total is a string.
order_type
order_type
Both
dc_destid
Both
pick_complete
pick_complete
COHdrDesc only
pick_not_after_date
pick_not_after_date
Both
pick_not_before_date
Both
po_nbr
po_nbr
Neither
promotions_total
promotion_total
COHdrDesc only
promotion_total is number, promotions_total is string.
rollback_allocation
rollback_allocation
COHdrDesc only
route
route
COHdrDesc only
ship_address4
ship_address4
Neither
ship_address5
ship_address5
Neither
ship_to_city
ship_city
COHdrDesc only
ship_request_id
distro_nbr
Both
distro_nbr is a long, ship_request_id is a string. The implementation will assume ship_request_id is an integer in string form.
ship_to_address_line_3
ship_address3
Neither
ship_to_address_line_2
ship_address2
Neither
ship_to_country_code
ship_country_id
COHdrDesc only
ship_to_fullname
ship_address_desc
COHdrDesc only
ship_to_postal_code
ship_zip
COHdrDesc only
ship_to_state_province
ship_state
COHdrDesc only
ship_to_street_address
ship_address1
COHdrDesc only
taxable_total
tax_total
COHdrDesc only
tax_total is number, implementation assumes taxable_total is a decimal numeric string.
CODesc records also contain one or more CODtlDesc records which are mapped to SODtlDesc records contained within an SODesc. The table below maps source CODtlDesc fields to output SODtlDesc fields. These fields are only copied when the input CODtlDesc record contains an item_status element with a case-insensitive value of “L”. All other CODtlDesc records are filtered and not copied.
Any CODtlDesc field not included in the table below will be ignored.
CODtlDesc field
SODtlDesc field
Required for
Comment
amount1
amount1
 Neither
CODtlDesc uses string, SODtlDesc is number. Implementation assumes input is string of a decimal number
amount2
amount2
 Neither
 Same as amount1
amount3
amount3
 Neither
 Same as amount1
amount4
amount4
 Neither
 Same as amount1
amount5
amount5
 Neither
 Same as amount1
amount6
amount6
 Neither
 Same as amount1
gift_services_line_amt
gift_cost
CODtlDesc Only
gift_cost is a decimal number
item_number
item_id
Both
item_status
item_status
Both
order_line_nbr
order_line_nbr
CODtlDesc Only
order_line_nbr is a 3-digit integer number for SODtlDesc and is a String for order_line_nbr in CODtlDesc
prom_line_amt
promotion
CODtlDesc Only
promotion is an Long (integer) number, prom_line_amt is a string
rdm_dest_id
dest_id
Both
requested_quantity
requested_unit_qty
Both
requested_unit_qty is a decimal number, requested_quantity is a string
sh_additional_line_amt
shipping
CODtlDesc Only
Shipping is a decimal number, sh_additional_line_amt is a string
tax_line_amt
tax
CODtlDesc Only
Tax is a decimal number, tax_line_amt is a string.
total_line_merch_amt
sub_total
CODtlDesc Only
sub_total is a decimal number, total_line_merch_amt is a string.
unit_selling_price
retail_price
CODtlDesc Only
 retail_price is a decimal number, unit_selling_price is a string.
unit_tax_percent
tax_percent
 CODtlDesc Only
 TAX_PERCENT is a decimal number, unit_tax_percent is a string.
Capitalization differences of the input message <type> value will be ignored. Input messages having a <type> value of “codel” will be mapped to an output type of “sodel”. The output payload class type for this set of messages will be the com.retek.payload.SORef class. The input payload class will be the com.retek.payload.CORef class. The table below details the conversion between the CORef fields and the SORef fields. Any CORef field not contained in the table will be ignored.
CORef field
SORef field
Required for
Comment
ship_request_id
distro_nbr
Both
document_type
SORef Only
Set to a hard-coded value of “C”
rdm_dest_id
dc_dest_id
SORef Only
Implementation will assume that RdmDestId is always set.
The SORef element may contain an array of SODtlRef elements. Certain fields of the CORef input payload will be mapped to a single SODtlRef element added to the SORef payload element. These fields are detailed in the table below
CORef field
SODtlRef field
Required for
Comment
item_number
item_id
Both
dest_id
SODtlRef Only
Set to a hard-coded value of “-1”
Disclaimer: This document is a general data mapping and reference guide for data coming in and out of Oracle Retail application systems via RIB messages; it is not meant to give detailed information about every possible data scenario.
