This figure depicts the actual files that comprise the RIB and where they are located in the deployment picture.
This file specifies all the adapter instances needed by RIB to interact with an application. Each rib-<app_name> has its own rib-<app-name>_adapter.xml.
The file is located in the rib-home/application-assembly/rib-<app> directory. After deployment it is found in the path $application_instance_home/$application_name where $application_instance_home is the oc4j instance path where the application is deployed.
These are the standard RIB defined adapter types.
<subscribers> elements consist of multiple occurrences of <message-driven> elements, that define all the subscribers available for a particular application. Each <message-driven> element consists of id (specifies id for the adaptor) and initialState (specifies the initial state of the adaptor) attributes. The initialState attribute for <message-driven> adaptors accepts two values; running and stopped.
<subscribers>
<message-driven id="ASNIn_sub_1" initialState="running"/>
<message-driven id="ASNOut_sub_1" initialState="running"/>
Note: Running and stopped are the ONLY valid states and are case sensitive. |
<publisher> elements consist of multiple occurrences of <timer-driven> or <request-driven> elements, used to define all the publishers available for a particular application.
<timer-driven> is used to define publishers for PL/SQL (RMS and RWMS) applications. Each <timer-driven> element consists of an id (specifies id for adaptor), initialState (specifies the initial state of the adaptor) and timeDelay (delay after which the GETNXT needs to call each time) attributes. The initialState attribute for <timer-driven> adaptors accepts two values; running and stopped. This consists of an element called <timer-task> which specifies the implementation details of the adaptor. The <timer-task> element specifies the GETNXT implementation through the <class> element.
<publishers>
<timer-driven id="Alloc_pub_1" initialState="running" timeDelay="10">
<timer-task>
<class name="com.retek.rib.app.getnext.impl.GetNextTimerTaskImpl"/>
<property name="maxChannelNumber" value="1" />
</timer-task>
</timer-driven>
<request-driven> is used to define publishers for javaee (Oracle Retail Price Management (RPM), Oracle Retail Store Inventory Management (SIM), Oracle Retail Advanced Inventory Planning (AIP)) applications. Each <request-driven> element consists of id (specifies id for adaptor) and initialState (specifies the initial state of the adaptor) attributes. The initialState attribute has a value of notConfigurable.
<publishers>
<request-driven id="ASNOut_pub_1" initialState="notConfigurable"/>
<request-driven id="DSDReceipt_pub_1" initialState="notConfigurable"/>
<hospital> element specifies hospital related adaptor information. The structure is very similar to the <publisher> element except that the name and value attribute in the property element defines the different hospital adaptor types.
<hospitals>
<timer-driven id="sub_hosp_2" initialState="running" timeDelay="10">
<timer-task>
<class name="com.retek.rib.j2ee.ErrorHospitalRetryTimerTask"/>
<property name="reasonCode" value="SUB"/>
</timer-task>
</timer-driven>
These are internationalizable strings for internal rib adapter key names.
Example:
sub_all.name=Subscribers sub_all.desc=Manages all subscribers at the same time. ASNIn_sub_1.name=ASNIn Subscriber, channel 1 ASNIn_sub_1.desc=Subscriber for the ASNIn family through channel 1. ASNOut_sub_1.name=ASNOut Subscriber, channel 1 ASNOut_sub_1.desc=Subscriber for the ASNOut family through channel 1.
This configuration file is specific to RMS and RWMS. The RIB interfaces with RMS and RMWS through two database procedures; GETNXT and CONSUME. This file contains the calling signatures for these procedures, the parameters to be configured before calling these procedures, and the implementation class for handling the objects returned from these procedures.
| Property Name and Default Value | Description |
| facility_id
defaultValue = "facility_id"; |
This property is used to refer to the warehouse routing configuration. The value of this property is used to construct the facility type |
| dc_dest_id
defaultValue = "*"; |
This property is used to refer to the warehouse distribution center. Destination ID |
| facility_type_default
defaultValue = "PROD"; |
Specifies the default facility type to be used by RWMS publishing adapters for calls to RWMS. |
All properties for RIB have been classified into kernel properties and application properties. This file contains kernel properties that are used specifically for the functioning of the RIB kernel. They are mostly related to hospital retry configuration, payload locations, or alerting.
| hospital_attempt_max
defaultValue = "5" |
This property refers to the maximum number of attempts to try to push this record through the RIB automatically. Once this retry count is exceeded, the message remains in the RIB Hospital DB but is no longer retried automatically |
| hospital_attempt_delay
defaultValue = "10" |
This property refers to the value (in seconds) used to calculate the next attempt time. |
| hospital_attempt_delayIncrement
This property refers to the value (in seconds) used to calculate the next attempt time. The next attempt time is calculated as: hospitalAttemptDelay + (hospitalAttemptDelyIncrement * attempt count). This is done so that the delay between each attempt is longer than the previous delay. |
| numOfRecordsToRetry
defaultValue = "20" |
This property refers to the maximum number of RIB Hospital records to be retried in one RIB Hospital retry attempt. |
| xml_schema_base_url
defaultValue = "http://localhost:8888/rib-func-artifact" |
This property refers to the location of web application (rib-func-artifact) which has RIB related XML Schema (XSD) files. |
| mail_smtp_host
defaultValue = "mail.smtp.host" |
This property is used to identify the smtp host from which to send out emails. |
| mail_smtp_port
defaultValue = "25" |
This property is used to identify the smtp port from which to send out emails. |
| mail_smtp_from
defaultValue = "admin@company.com" |
This property refers to the email id that the RIB platform needs to use to send the emails for administrative purposes. |
| war_http_port
defaultValue = "9080" |
This property refers to the port number used by the web based Hospital Retry Admin Tool. |
This file is the single source of all values used by the RIB Application Builder tools to define and configure the JMS topics as well as perform start and stop activities, including subscriber checks. For RIB deployments this file should not be edited.
This file is packaged and deployed as part of the rib-func-artifacts war file.
Example:
<message-flow id="1">
<node id="rib-rms.Alloc_pub" app-name="rib-rms"
adapter-class-def="Alloc_pub" type="DbToJms">
<in-db>default</in-db>
<out-topic>etAllocFromRMS</out-topic>
</node>
<node id="rib-tafr.Alloc_tafr" app-name="rib-tafr"
adapter-class-def="Alloc_tafr" type="JmsToJms">
<in-topic>etAllocFromRMS</in-topic>
<out-topic name="topic-name-key-iso">etStockOrdersISO</out-topic>
<out-topic name="topic-name-key-wh">etStkOrdersFromRIBToWH{*}</out-topic>
</node>
<node id="rib-sim.StockOrder_sub" app-name="rib-sim"
adapter-class-def="StockOrder_sub" type="JmsToDb">
<in-topic>etStockOrdersISO</in-topic>
<out-db>default</out-db>
</node>
<node id="rib-rwms.StockOrder_sub" app-name="rib-rwms"
<in-topic>etStkOrdersFromRIBToWH1</in-topic>
</node>
</message-flow>
This file is the single source of all values used in the RIB App Builder tools and is the only (or should the only) file that requires editing for using them. The RIB Installer gathers the appropriate values from the user, constructs the file, and invokes the appropriate tools.
For example, when the RIB Application Builder is used to extract error hospital tables from an application schema, this file supports those tables.
The RIB Application Builder tools can be executed independent of the RIB installer tool. In some cases it is necessary to edit this file manually.
This section defines what applications are in scope for this environment.
Example:
<app-in-scope-for-integration>
<app id="rms" type="plsql-app"/>
<app id="tafr" type="tafr-app"/>
<app id="sim" type="javaee-app"/>
<app id="rwms" type="plsql-app"/>
<app id="rpm" type="javaee-app"/>
<app id="aip" type="javaee-app"/>
</app-in-scope-for-integration>
This section defines the JMS server information.
Example:
<jms-server-home>linux1@linux1:/home/oracle/oracle/product/10.2.0/db_1</jms-server-home>
<jms-url>jdbc:oracle:thin:@linux1:1521:ora10g</jms-url>
<jms-port>1521</jms-port>
<jms-user>ribaq</jms-user>
<jms-password>ribaq</jms-password>
This section defines the Oracle Application Server information.
Example:
<oas-instance-name> AS4.linux1.localdomain </oas-instance-name> <oas-instance-home>soa1@linux1:/home/soa1/product/10.1.3.1/OracleAS_6</oas-instance-home> <oas-opmn-request-port>6003</oas-opmn-request-port> <oas-ohs-port protocol="http" >7777</oas-ohs-port> <java-home>/usr/java/jdk1.5.0_01</java-home>
This section defines the oc4j instances for each of your rib-<app> applications that are in-scope.
Example:
<oc4j id="rib-rms-app-server-instance">
<oc4j-instance-name>rib-rms-oc4j-instance</oc4j-instance-name>
<oc4j-instance-home>soa1@linux1:/home/soa1/product/10.1.3.1/OracleAS_4/j2ee/rib-rms-oc4j-instance</oc4j-instance-home>
<oc4j-user>riboc4jadmin</oc4j-user>
<oc4j-password>riboc4jadmin</oc4j-password>
</oc4j>
This section defines the rib-<app> specific information for each applicable rib-<app>.
Example 1: RIB-RMS (for app-type=PL/SQL)
<rib-app id="rib-rms" type="plsql-app">
<url>jdbc:oracle:thin:@linux11521:soa1</url>
<user>rms13en</user>
<password>rms13</password>
<notifications>
<email>
<email-server-host>mail.oracle.com</email-server-host>
<email-server-port>25</email-server-port>
<from-address>rib@oracle.com</from-address>
<to-address-list>rib@oracle.com</to-address-list>
</email>
<jmx/>
</notifications>
Example 2: Error Hospital Database (for app-type=PL/SQL)
<error-hospital-database>
<hosp-url>DB host URL for error-hospital tables</hosp-url>
<hosp-user>errorhospitaluser </hosp-user>
<hosp-password>password </hosp-password</error-hospital-database> <app-database>
<app-url> DB host URL for pl/sql application</app-url>
<app-user>appuser </app-user>
<app-password>password </app-password></app-database>
Example 3: JavaEE application with JNDI information defined
<jndi>
<url>opmn:ormi://linux1:6003:sim-oc4j-instance/javaee-api-stubs</url>
<factory>oracle.j2ee.rmi.RMIInitialContextFactory</factory>
<user>oc4jadmin</user>
<password>welcome1</password>
</jndi>
Example 4: Error Hospital Database (for app-type=JavaEE/TAFR)
</hosp-user>
</hosp-password
There are several - insert locations and use. The RIB uses the Apache Commons Logging subsystem as the logging interface. For RIB deployments this file should not be edited.
The log4j Open Source software is used to control all RIB logging. This software requires the log4j.xml file to configure the file name, logging level, and type of file used.
This is a non editable file that describes the structure of the rib-<app>.ear and the resources it uses.
All logging in the RIB is through log4j, the Apache Software Foundation's Open Source software. For details about log4j visit the Apache Software Foundation's log4j home page.
For additional information on how the RIB uses log4j, see "log4j.xml".
The logging level will need to be adjusted for the phase of the deployment. What is appropriate in development and test (DEBUG) is not appropriate in production (INFO).
There are some logs such as audit and timing that may be used differently at certain phases as well. Audit is either on (DEBUG) or off (INFO), the same is true with timings.
As a rule the appropriate level will always be INFO.
The RIB's use of log4j allows the control of logging levels to suit the deployment and situation. There are two methods of setting the logging levels; directly manipulating the log4.xml file using a text editor, and the RIB Administration GUI.
The RIB Administration GUI allows control of the logging levels for each adapter individually. It permits the change to affect only the runtime logging and is dynamic. It also provides the ability to persist the change so that the adapter(s) retains that level when restarted. This is the recommended approach.
The RIB adapter code contains logging logic that writes all of it runtime logs to the RIBLOG log files. The logs are written to the path <rib-application_instance_home>/<rib-app>/logs/<rib-app>.
Example:
/home/rib/product/10.1.3.3/OracleAS_6/j2ee/rib-rms-oc4j-instance/log/rib-rms
The RIBLOG filenames are in the format <adapter-instance-name>.rib.log.
Example:
Alloc_pub_1.rib.log ASNIn_sub_1.rib.log ASNOut_sub_1.rib.log
To enable this function, parameters must be set per adapter.
Be careful because there are multiple entries for each adapter instance in the log4j.xml file. Search for the section of the log4j.xml file:
<!--RIB Appender for adapterInstance: Alloc_pub_1-->
The RIB messaging components code is instrumental to log timing entries on the internal activities whenever they create, transform, route, filter, or subscribe to messages on the RIB. These timings logs are written using the log4j logging mechanism.
The timings log files follow the name convention <adaptor-instance-name>.timings.log and are found in the same locations as the RIBLOGS.
Typically, one timings log file is created per component (EJB or other) which holds the entries for that component. These files are cumulative, meaning that they do not get overwritten with every initialization of the component, but they append new entries to the current information already recorded. The files do roll over after they reach a certain configurable size and backup files are created to preserve previous entries.
Each entry in the timings log represents a timestamp of a particular event in the RIB component, listing the date and time information, name of the component, thread id and a distinct message for each event. The list of time stamped events includes such items as the start time and/or end time of the following actions:
Overall publication, subscription, routing, or transformation process
Calls to store procedures (getnxt and consume)
Actual publication and subscription of messages to and from the JMS server
Calls to the RIB Hospital to check for dependencies and insert messages
Calls to other applications to process messages after subscription (injectors)
The log4j.xml file must have the "level value" property set to DEBUG. This tag is not normally present in the standard log4j.xml file, it must be added. The example below shows how and where.
<!--Timings Logger for adapterInstance: -->".
Before:
<logger additivity="false" name="rib.pub.timings.Order_pub_1">
<!-- Possible levels are TRACE, DEBUG, INFO, WARN, ERROR and FATAL -->
<level value="INFO"/>
<appender-ref ref="appender.rib.pub.timings.Order_pub_1"/>
</logger>
After:
<level value="DEBUG"/>
</logger>
The RIB has an auditing feature that logs a message as it passes though the RIB infrastructure. Each messaging component can be set to write the message, and only the message, to a separate log file. This allows the tracing of message content from publication to subscription, and all steps, such as a TAFR, in between.
There are two benefits to this mechanism; the ability to audit each step, and the ability to create a recovery plan. The messages can be played back, without effort being spent to extract them from inside other more systemic log files.
The log4j.xml can be edited to remove the <audit-entry> tag from the output and to have only the message in the file.
<!--Audit Appender for adapterInstance: ASNIn_sub_1-->
<appender class="org.apache.log4j.FileAppender"
name="appender.rib.sub.audit.ASNIn_sub_1">
<param name="File" value="/u00/webadmin/product/10.1.3/OracleAS_1/j2ee/rib-rms-oc4j-instance/log/rib-rms/ASNIn_sub_1.audit.log"/>
<!--param name="MaxFileSize" value="2048KB"/-->
<!--param name="MaxBackupIndex" value="1"/-->
<layout class="org.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="<audit-entry audit-time="%d{yyyy.MM.dd
HH.mm.ss,SSS}">%n%m%n</audit-entry>%n"/>
</layout>
</appender>
Remove the “value=” in the ConversionPattern with %m%n
The RIB can also log a set of audit logs used to audit all the events processed by RIB. To enable this function, parameters must be set per adapter.
Proceed cautiously because there are multiple entries for each adapter instance in the log4j.xml file. Search for the section of the log4j.xml file:
<!--Audit Logger for adapterInstance: ItemLoc_pub_1-->.
Before:
<logger additivity="false" name="rib.pub.audit.ItemLoc_pub_1">
<level value="INFO "/>
<appender-ref ref="appender.rib.pub.audit.ItemLoc_pub_1"/>
</logger>
After:
Sample Log Entry:
<audit-entry audit-time="2008.01.28 11.37.57,642"> <?xml version="1.0" encoding="UTF-8"?> <RibMessages xmlns="http://www.oracle.com/retail/integration/rib/RibMessages" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.oracle.com/retail/integration/rib/RibMessages http://mspdev85:7777/rib-func-artifact/integration/xsd/RibMessages.xsd" > <ribMessage><family>Banner</family><type>BannerCre</type> <id>1</id> <ribmessageID>Banner_pub_1|2008.01.28 11:37:57.500|6936</ribmessageID> <publishTime>2008-01-28 11:37:57.500 CST</publishTime> <messageData><BannerDesc xmlns="http://www.oracle.com/retail/integration/payload/BannerDesc" xmlns:ribdate="http://www.oracle.com/retail/integration/payload/RIBDate" ; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.oracle.com/retail/integration/payload/BannerDe sc http://mspdev81:7777/rib-func-artifact/payload/xsd/BannerDesc.xsd http://www.oracle.com/retail/integration/payload/RIBDate http://mspdev81:7777/rib-func-artifact/payload/xsd/RIBDate.xsd"> <banner_id>1</banner_id> <banner_name>B&amp;M</banner_name></BannerDesc> </messageData> <customData></customData><customFlag>F</customFlag> </ribMessage> </RibMessages>
This log will track the source rib-app-builder home that pushed the changes to this OC4J instance.
Example:
Uploading configuration file from machine(mspdev81) dir(/stage/Rib1300-ms7.1/Rib1300ForAll13xxApps/rib-home/deployment-home/bin/../../../rib-home) at(Mon Jan 28 11:15:57 PST 2008).
The RIB maintains a management log which is used to keep track of the oc4j instance on the whole.
This is usually written during the startup of an oc4j instance. The recommendation is that each rib-app be deployed in a separate oc4j instance, so management logs are specific to a rib-app.
The management log writes RIB information common to all the components like loading property files and creating logging files.
Example:
2008-02-01 14:33:23,928 [AJPRequestHandler-RMICallHandler-6] DEBUG com.retek.rib.management.adapters.client.action.StopAdapterAction - Invoking operation to stop the adapters 2008-02-01 14:33:23,928 [AJPRequestHandler-RMICallHandler-6] DEBUG com.retek.rib.monitor.engine.MBeanAbstractFactory - Invoking MBean operation domain(rib-rms) objectNameProperty(level=adapters,type=sub,name=Receiving_sub_1) methodName(stop) parameter([Ljava.lang.Object;@1452a1) signature([Ljava.lang.String;@3d06a4).
Example:
2008-02-06 10:14:26,688 [AJPRequestHandler-RMICallHandler-7] DEBUG retek.com.retek.rib.ui.view.tags.IteratePropertyTag.com.retek.rib.management.adap ters.model.AdapterTypes - Invoking Operation returnStatusForAll of MBean. 2008-02-06 10:14:26,777 [AJPRequestHandler-RMICallHandler-7] DEBUG retek.com.retek.rib.ui.view.tags.IteratePropertyTag.com.retek.rib.monitor.engine.M BeanAbstractFactory - Invoking MBean operation domain(rib-rms) objectNameProperty(level=types,type=pub,name=pub_all) methodName(returnStatusForAll) parameter(null) signature(null). 2008-02-06 10:14:26,780 [AJPRequestHandler-RMICallHandler-7] DEBUG retek.com.retek.rib.ui.view.tags.IteratePropertyTag.com.retek.rib.management.adapt ers.model.AdapterTypes - Operation returnStatusForAll for type pub invoked successfully :<type name="pub"><adapter id="Alloc_pub_1" name="Alloc Publisher, channel 1" state="running" /><adapter id="SeedData_pub_1" name="SeedData Publisher, channel 1" state="running" /><adapter id="SeedObj_pub_1" name="SeedObj Publisher, channel 1" state="running" /><adapter id="WOOut_pub_1" name="WOOut Publisher, channel 1" state="running" /><adapter id="Banner_pub_1" name="Banner Publisher, channel 1" state="running" /><adapter id="Transfers_pub_1" name="Transfers Publisher, channel 1" state="running" /><adapter id="RcvUnitAdj_pub_1" name="RcvUnitAdj Publisher, channel 1" state="running" /><adapter id="Vendor_pub_1" name="Vendor Publisher, channel 1" state="running" /><adapter id="WH_pub_1" name="WH Publisher, channel 1" state="running" /><adapter id="RTVReq_pub_1" name="RTVReq Publisher, channel 1" state="running" /><adapter id="MerchHier_pub_1" name="MerchHier Publisher, channel 1" state="running" /><adapter id="UDAs_pub_1" name="UDAs Publisher, channel 1" state="running" /><adapter id="Order_pub_1" name="Order Publisher, channel 1" state="running" /><adapter id="Items_pub_1" name="Items Publisher, channel 1" state="running" /><adapter id="DiffGrp_pub_1" name="DiffGrp Publisher, channel 1" state="running" /><adapter id="Item Loc_pub_1" name="ItemLoc Publisher, channel 1" state="running" /><adapter id="Partner_pub_1" name="Partner Publisher, channel 1" state="running" /><adapter id="Diffs_pub_1" name="Diffs Publisher, channel 1" state="running" /><adapter id="WOIn_pub_1" name="WOIn Publisher, channel 1" state="running" /><adapter id="Stores_pub_1" name="Stores Publisher, channel 1" state="running" /></type>
