This section describes the RSB JMX infrastructure. JMX is a specification that provides capability for runtime management of Java components. WebLogic server implements JMX specification. RSB uses JMX for collecting useful information for monitoring the functioning of the integration infrastructure.
Any third party JMX console compatible with the Java EE container can be used to manage RSB components. In RSB some of information captured by OSB MBeans are collected and reported in context through the RSB admin application (RIC).
Note: See also JMX Specificationhttp://docs.oracle.com/javase/7/docs/technotes/guides/jmx/JMX_1_4_specification.pdf. |
In RIC, the following metrics are captured using JMX. The metrics data is collected by OSB from all the managed servers on regular interval. The default interval is 10 minutes. The interval for each service (Proxy and Business) can be changed in OSB console. Following screenshot shows a Proxy service aggregation interval field location, in case it is required to change.
RIC retrieves the metric data from OSB when the user visits the Metrics Graphs tab. Since OSB metric collection is decided by the collection interval, the data shown in RIC can be out of sync by a maximum delay of the interval. So, in a default configuration the metric data can be outdated by a maximum of 10 minutes.
In order for the alerts to work, it should be enabled in the global settings. These are enabled by default. Following screen shows the location to enable alerts in the OSB Console.
Success and failure count
This count shows the number of successful invocations and number of failures of decorator and app service for the past 24 hours.
Min, max and average response time
This information shows minimum, maximum and average response time of service operations for the past 24 hours.
Success and Failure count for operations
This is a count of success and failure by operations for the past 24 hours.
See RSB Developers Guide for instructions for adding Business and System Alerts.
The performance of alert retrieval is affected by the number of alerts in the system. As the number of alerts grows, the retrieval becomes slow. This becomes evident in the alert screen of RIC application. The screen rendering gets slower as the number of alerts increases over time. Here are a couple of ways to purge the alert.
Purge the alert through OSB console. From the OSB console dashboard navigate to operations and then extended alert history for SLA and Pipeline alerts. You can purge alerts by clicking on Purge SLA Alerts History and Purge Pipeline Alerts History links.
The following screenshot shows how to reset statistics using OSB Console
Choose Operations link
Select Service Health tab
Choose Since Last Reset option for Display Statistics dropdown
Click the Reset All Statistics link
Click OK on the confirm dialog box
Note: See also Oracle Service Bus Guides. |
