Once the deployment process is completed and all the servers are restarted, verify the success by accessing the rsb-admin app i.e. Retail Integration Console (RIC)
Open the link: http://hostname:port/rsb-admin, where hostname and port are of the Admin Server.
Check if all the tabs are opening without error.
-bash: sqlplus command not found
Solution: sqlplus command should be run on machine where Oracle database is installed.
Set Oracle Database Home directory path in a variable say ORACLE_HOME and export ORACLE_HOME/bin in the classpath. To add entries into path perform the following steps:
ORACLE_HOME= /u00/oracle/app/oracle/product/11.2.0/dbhome_1
export ORACLE_HOME
PATH=$PATH:$ORACLE_HOME/bin
export PATH
Decorators not getting deployed in non-secure deployment.
Solution: OWSM is required even in non-secure deployment. Make sure that OWSM is configured for WebLogic domain where decorators are being deployed. User must make sure that Oracle Service Bus OWSM Extension is selected while WebLogic domain is created/extended.
Admin app was showing the error "Could not initialize class au.awt.GraphicsEnvironment".
Solution: Issue can be resolved by setting the variable java.awt.headless to true.
(-Djava.awt.headless=true)
