| Oracle® Retail Service Backbone Oracle Retail Integration Console Guide 14.1 E57332-01 |
![]() Previous |
![]() Next |
The following is an overview of the technical design of RIC product:
RIC is an ADF UI application.
When installed (in rsb-home), RIC reads and uses the configurations of RSB (rsb-home) and if available the RIB (RIB-home) configurations.
RIC uses the WebLogic Diagnostic framework to forward all of the logs pertinent to RSB where RIC is installed (AdminServer).
All RSB paks are created using the RSE tool. The tool includes instrumentation with OSB configurations.
The RSB instrumentation is asynchronously writing events to RSB schema.
RIC uses the RSB service activity schema and OSB instrumentation to present data and data summaries to the UI.
RIC directly integrates with the RRA/IG through context hyperlinks.
