RSB has several dependencies on Oracle Retail Application installations, as well as on the Oracle WebLogic servers. This section covers these requirements.
If you are unable to find the necessary version of the required Oracle infrastructure software (database server, application server, WebLogic, etc.) on the Oracle Software Delivery Cloud, you should file a non-technical 'Contact Us' Service Request (SR) and request access to the media. For instructions on filing a non-technical SR, see My Oracle Support Note 1071023.1 - Requesting Physical Shipment or Download URL for Software Media.
| Supported On | Versions Supported |
| Database Server OS | OS certified with Oracle Database 12c (12.1) Enterprise Edition. Options are:
| Database Server 12c | Oracle Database Enterprise Edition 12c (12.1) with the following specifications:
Components:
Patches:
Oneoff Patches:
Other Components:
| Application Server OS | OS certified with Oracle Fusion Middleware 11g Release 1 (11.1.1.7). Options are:
| Application Server | Oracle Fusion Middleware 11g Release 1 (11.1.1.7)
Components:
| Minimum required JAVA version for all operating systems | JDK 1.7.0+ latest security updates 64 bit |
Important: If there is an existing WebLogic installation on the server, you must upgrade to WebLogic 10.3.6. All middleware components associated with WebLogic server should be upgraded to 11.1.1.7.Back up the weblogic.policy file ($WLS_HOME/wlserver_10.3/server/lib) before upgrading your WebLogic server, because this file could be overwritten. Restore the weblogic.policy from backup file after the WebLogic upgrade is finished and the post patching installation steps are completed. |
The RIC model and view components require ADF runtime to run properly. Verify that ADF runtime 11.1.1.7 or higher is available in the WebLogic Application Server (10.3.6) and applied to the domain where RIC will be installed.
Other Resources
For information about WebLogic Application Server 11g, see the Oracle WebLogic Server Documentation Library.
WebLogic Application Server 11g - Index http://download.oracle.com/docs/cd/E15523_01/index.htm
WebLogic Application Server 11g - Documents http://download.oracle.com/docs/cd/E15523_01/wls.htm.
Note: See also the Oracle Database Administrator's Guide 12c (12.1) and the Oracle WebLogic Application Server 11g (10.3.6) documentation. |
| Retail Product | Version Supported |
| Oracle Retail Warehouse Management System (RWMS) 14.1 | RIB 14.1 |
| Oracle Retail Merchandising System (RMS) 14.1 | RIB 14.1 |
| Oracle Retail Price Management (RPM) 14.1 | RIB 14.1 |
| Oracle Retail Store Inventory Management (SIM) 14.1 | RIB 14.1 |
| Oracle Retail Advanced Inventory Planning (AIP) 14.1 | RIB 14.1 |
| Integration Gateway Services (IGS) 14.1 | RSB 14.1 |
| Oracle Retail Financial Integration (ORFI) 14.1 | RSB 14.1 |
| Oracle Retail Returns Management (RM) 14.1 | RSB 14.1 |
| Oracle Retail Invoice Matching (ReIM) 14.1 | RSB 14.1 |
| POS Suite 14.1 | RSB 14.1 |
| Rib4OMS 14.1 | RSB 14.1 |
Oracle Service Bus (OSB) supports three types of topologies: Admin-only topology, Admin + Managed Server topology and Cluster topology. The first two topologies are non-clustered topologies which are not high-available; therefore it is recommended that you use Cluster topology.
Clustering allows OSB to run on a group of servers that can be managed as a single unit. An OSB deployment can use clustering and load balancing to improve scalability by distributing the workload across nodes. A WebLogic server clustered domain consists of only one Admin Server, and one or more managed servers. The managed servers in an OSB domain can be grouped in a cluster. When OSB resources are configured, resources are targeted to the named cluster. The advantage of specifying a cluster as the target for resource deployment is that it makes it possible to dynamically increase capacity by adding Managed Servers to the cluster.
Singleton Resources
While most resources used by OSB are deployed homogeneously across the cluster, there are a few resources that must be pinned to a single Managed Server in order to operate correctly. The following table lists these components:
ALSB Cluster Singleton Marker Application
ALSB Domain Singleton Marker Application
Message Reporting Purger
configwiz-jms service
Load balancing in an OSB cluster
Load balancing distributes the workload proportionately across all the servers in a cluster so that each server can run at full capacity. Web services (SOAP or XML over HTTP) can use HTTP load balancing. External load balancing can be accomplished through the WebLogic HttpClusterServlet, a WebServer plug-in or a hardware router. In the steps described in this document, it uses a HTTP proxy server which is a managed server in the same domain and is not a part of the cluster.
