This appendix includes a code sample for configWss.py.
userName = sys.argv[1] passWord = sys.argv[2] url="t3://"+sys.argv[3]+":"+sys.argv[4] print "Connect to the running adminSever" connect(userName, passWord, url) edit() startEdit() #Enable assert x509 in SecurityConfiguration rlm = cmo.getSecurityConfiguration().getDefaultRealm() ia = rlm.lookupAuthenticationProvider("DefaultIdentityAsserter") activeTypesValue = list(ia.getActiveTypes()) existed = "X.509" in activeTypesValue if existed == 1: print 'assert x509 is aleady enabled' else: activeTypesValue.append("X.509") ia.setActiveTypes(array(activeTypesValue,java.lang.String)) ia.setDefaultUserNameMapperAttributeType('CN'); ia.setUseDefaultUserNameMapper(Boolean('true')); #Create default WebServcieSecurity securityName='default_wss' defaultWss=cmo.lookupWebserviceSecurity(securityName) if defaultWss == None: print 'creating new webservice security bean for: ' + securityName defaultWss = cmo.createWebserviceSecurity(securityName) else: print 'found exsiting bean for: ' + securityName #Create credential provider for DK cpName='default_dk_cp' wtm=defaultWss.lookupWebserviceCredentialProvider(cpName) if wtm == None: wtm = defaultWss.createWebserviceCredentialProvider(cpName) wtm.setClassName('weblogic.wsee.security.wssc.v200502.dk.DKCredentialProvider') wtm.setTokenType('dk') cpm = wtm.createConfigurationProperty('Label') cpm.setValue('WS-SecureConversationWS-SecureConversation') cpm = wtm.createConfigurationProperty('Length') cpm.setValue('16') else: print 'found exsiting bean for: DK ' + cpName #Create credential provider for x.509 cpName='default_x509_cp' wtm=defaultWss.lookupWebserviceCredentialProvider(cpName) if wtm == None: wtm = defaultWss.createWebserviceCredentialProvider(cpName) wtm.setClassName('weblogic.wsee.security.bst.ServerBSTCredentialProvider') wtm.setTokenType('x509') else: print 'found exsiting bean for: x.509 ' + cpName #Custom keystore for xml encryption cpName='ConfidentialityKeyStore' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty(cpName) keyStoreName=sys.argv[5] cpm.setValue(keyStoreName) cpName='ConfidentialityKeyStorePassword' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty(cpName) cpm.setEncryptValueRequired(Boolean('true')) KeyStorePasswd=sys.argv[6] cpm.setEncryptedValue(KeyStorePasswd) cpName='ConfidentialityKeyAlias' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty(cpName) keyAlias=sys.argv[7] cpm.setValue(keyAlias) cpName='ConfidentialityKeyPassword' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty('ConfidentialityKeyPassword') cpm.setEncryptValueRequired(Boolean('true')) keyPass=sys.argv[8] cpm.setEncryptedValue(keyPass) #Custom keystore for xml digital signature cpName='IntegrityKeyStore' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty(cpName) keyStoreName=sys.argv[5] cpm.setValue(keyStoreName) cpName='IntegrityKeyStorePassword' cpm=wtm.lookupConfigurationProperty(cpName) if cpm == None: cpm = wtm.createConfigurationProperty(cpName) cpm.setEncryptValueRequired(Boolean('true'))KeyStorePasswd=sys.argv[6]cpm.setEncryptedValue(KeyStorePasswd)cpName='IntegrityKeyAlias'cpm=wtm.lookupConfigurationProperty(cpName)if cpm == None: cpm = wtm.createConfigurationProperty(cpName)keyAlias=sys.argv[7]cpm.setValue(keyAlias)cpName='IntegrityKeyPassword'cpm=wtm.lookupConfigurationProperty(cpName)if cpm == None: cpm = wtm.createConfigurationProperty(cpName)cpm.setEncryptValueRequired(Boolean('true'))keyPass=sys.argv[8]cpm.setEncryptedValue(keyPass)#Create token handler for x509 token#cpName='default_x509_handler'th=defaultWss.lookupWebserviceTokenHandler(cpName)if th == None: th = defaultWss.createWebserviceTokenHandler(cpName) th.setClassName('weblogic.xml.crypto.wss.BinarySecurityTokenHandler') th.setTokenType('x509') cpm = th.createConfigurationProperty('UseX509ForIdentity') cpm.setValue('true')save()activate(block="true")disconnect()exit()
