Go to primary content
Oracle® Retail Functional Artifacts Guide
Release 16.0
E78846-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
5 XML Standards and Conventions
This chapter defines standards in the areas of naming conventions, XML standards, and customization/extension.
The standards in this document are for the artifacts used in Oracle Retail integration products, such as the RIB, Integration Gateway Services and Web Service Providers created by the Retail SOA Enabler tool. For Oracle AIA this section applies to edge-application Web services and integration patterns. These standards do not overlap the AIA standards for middle layer integrations. For those integrations, the AIA standards are directly applicable.
The standards and conventions described in this section are retail domain specific. The naming conventions and standards are only patterned after AIA concepts.
This section describes XML standards and conventions.
The underscore (_) must be used for readability in naming simple elements
This standard is a significant deviation from generally accepted WS standards, including AIA. The underscore is used by the Business Objects in the RIB and by Oracle Retail PL/SQL applications.
Topic Description
Recommendation The underscore must be used for readability in naming simple elements, with no spaces or hyphens between words; lower camel case cannot be used (for example, supplierName). Lower case must be used. The simple element names must not be more than 30 characters in length.
Rationale This is not the generally accepted recommendation in other XML standards.
Because Business Objects are translated into Oracle Objects for use within the database by PL/SQL APIs, all elements are made uppercase by default. Readability is enhanced by using the underscore instead of the industry standard lower camel case.
Example
<xsd:element name="supplier_name" type="varchar2240"/>
Names must not contain special characters
Topic Description
Recommendation Names must not contain special characters.
Rationale This is recommended to be similar to other XML standards.
Note that the underscore is allowed. This is not the same as other standards.
Examples
space, '-', '.', '$', '%', '#',<, >, &, ?
UpperCamel case must be used for naming complex types
Topic Description
Recommendation Upper camel case must be used for naming complex types with no spaces, hyphens or underscores between words. The complex type elements must not be more than 22 characters in length.
Rationale This is recommended to be similar to other XML standards..
Example
<xsd:complexType name="SupplierType"/>
Avoid XML schema keywords as element names
Topic Description
Recommendation Avoid XML schema keywords as element names. Do not use XSD keywords, such as element, sequence, and complexType as element names.
Example
<xs:element name="element" type="xs:integer"/>
Avoid Java keywords
Topic Description
Recommendation Avoid Java keywords as element names.
Examples abstract, assert, boolean, break, byte, case, catch, char, class, const, continue, default, do, double, else, enum, extends, false, final, finally, float, for, goto, if, implements, import, instanceof, int, interface, long, native, new, null, package, private, protected, public, return, short, static, strictfp, super, switch, synchronized, this, throw, throws, transient, true, try, void, volatile, while.
Avoid PLSQL keywords
Topic Description
Recommendation Avoid PLSQL keywords as element names.
Example
comment,clob
Avoid having numeric characters in the name
Topic Description
Recommendation Avoid having numeric characters in the name.
Example
<xsd:element name="supplier1Name" type="varchar2240"/>
All XSD elements should be annotated
Topic Description
Recommendation The definitions of all elements/attributes/enumerations should be included in the schema as notations.
Each XSD file should declare as a namespace:
xmlns:retailDoc="http://www.w3.org/2001/XMLSchema
The XSD should be the source of truth and include the business functional documentation of the element.
The annotation standard should be independent of any repository specific requirements.
The retailDoc namespace will allow intelligent processing in the XML/XSD parser in the future. There can be different behavior for a documentation element when the prefix is retailDoc versus anything else (including xs: or xsd:), even though all of them belong to same namespace.
Example
xmlns:retailDoc="http://www.w3.org/2001/XMLSchema"
                <xs:element name="unit_qty" type="number12_4">
                    <retailDoc:annotation>
                        <retailDoc:documentation>Contains the number of items expected to be received based on the supplier's ASN for this Item/Shipment combination.</retailDoc:documentation>
                    </retailDoc:annotation>
                </xs:element>
All XSDs should use the date type, xsd:dateTime, and the XML format, 2002-05-30T09:00:00
Topic Description
Recommendation All XSDs should use the date type, xsd:dateTime, and the XML format, 2002-05-30T09:00:00
Example
<xs:element name="ship_date" type="xs:dateTime">
All XSDs should use only these supported types
date: dateTime
boolean: boolean
text: varchar2N
integer: number6
decimal: numberN_N
long: number10
example:
varchar24
number12_4
Non top level complex type can not be empty
Topic Description
Recommendation Non top level CompleType cannot be empty, that is in xml we cannot have something like
<ExtOfReportLocDesc></ExtOfReportLocDesc> or
<ExtOfReportLocDesc/>. So validation error is correct.
Example
Retail Business Objects Schema
The logical representation of an Oracle Retail business entity is known as the Oracle Retail Business Object. For the purposes of this document, it describes the definition of that object in the form of an XML Schema (XSD). The schema represents the common object definition for business concepts such as Account, Supplier, Purchase Order, and Item.
Business Object (XSD) names should not contain names
Topic Description
Recommendation The Business Object name should not contain message related operations or actions, such as Request or Response.
Rationale The name should be only a business noun and should not necessarily reference the usage of the object.
Example Do not use Business Object names like ItemRequest.xsd or ItemResponse.xsd.
Business Object (XSD) names should not contain CRUD operations
Topic Description
Recommendation The Business Object name should not contain message related operations or actions, such as Create, Update, Process, and Get.
Rationale The name should be only a business noun and should not necessarily reference the usage of the object CRUD operations.
Example Do not use Business Object names like ItemCreate.xsd or ItemMod.xsd.
The Business Object (XSD) file must match the name of the top level element
Topic Description
Recommendation Every XSD file must define only one top level/global element, and the file name must match the name of the top level element.
Example
SupplierBO.xsd
   <xs:element name="SupplierBO">
            <retailDoc:documentation></retailDoc:documentation>
    <xs:complexType>
Each Business Object (XSD) must have its own namespace
Topic Description
Recommendation Each Business Object must have its own namespace.
Rationale This is to eliminate conflicts when a service consumer will consume multiple from the same provider and the generate client side code should not have conflict.
Each BO having its own namespace also allows versioning of each BO.
The file will be located in a directory structure that matches the path portion of the namespace URLs for the top level type that is defined in that file.
Example
targetNamespace="http://www.oracle.com/retail/integration/base/bo/SupplierBO/v1"
version="1.0"
xmlns="http://www.oracle.com/retail/integration/base/bo/SupplierBO/v1"
Each Business Object (XSD) namespace should not contain application identifiers
Topic Description
Recommendation Each Business Object namespace should not contain application identifiers.
Rationale Business Objects are not tied to any specific retail applications. These are generic business objects that belong to the full retail domain. So the Business Object namespace should not contain application identifiers.
Example
version="1.0"
Each Business Object (XSD) root should be annotated
Topic Description
Recommendation The XSD should be the source of truth and include the business functional documentation of the element.
The annotation standard is independent of any repository specific requirements for the Business Objects.
Example
      < retailDoc:annotation>
         < retailDoc:documentation>
            Merchandise Suppliers are suppliers of goods and services to be sold by the retailer to customers
         </ retailDoc:documentation>
      </ retailDoc:annotation>
Avoid Business Object (XSD) to have maxOccurs="unbounded" for elements
Topic Description
Recommendation Avoid maxOccurs="unbounded" unless it is absolutely required.
Rationale Setting a maxOccurs value to unbounded can lead to resources exhaustion and ultimately a denial of service. Processing XML documents can be expensive. Attackers can take advantage of the schemas that allow unbounded elements by supplying an application with a very large number elements causing the application to exhaust system resources.
Example The following is an example of a schema that allows unbounded bar elements.<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" > <xs:element name="foo" > <xs:complexType> <xs:sequence> <xs:element name="bar" maxOccurs="unbounded" /> </xs:sequence> </xs:complexType> </xs:element></xs:schema>
