Go to primary content
Oracle® Retail Service Backbone Security Guide
16.0
E80534-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
B Sample Java Policy B Consumer Using WebLogic Policy
package com.test;
import weblogic.security.SSL.TrustManager;
import java.io.File;
import java.io.FileInputStream;
import java.io.IOException;
import java.io.InputStream;
import java.net.URL;
import java.security.KeyStore;
import java.security.cert.X509Certificate;
import java.util.ArrayList;
import java.util.List;
import java.util.Map;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import javax.xml.namespace.QName;
import javax.xml.ws.BindingProvider;
import weblogic.jws.jaxws.ClientPolicyFeature;
import weblogic.jws.jaxws.policy.InputStreamPolicySource;
import weblogic.xml.crypto.wss.WSSecurityContext;
import weblogic.xml.crypto.wss.provider.CredentialProvider;
import weblogic.wsee.security.bst.ClientBSTCredentialProvider;
import weblogic.wsee.security.unt.ClientUNTCredentialProvider;
import com.oracle.retail.cm.integration.services.customerservice.v1.CustomerPortType;
import com.oracle.retail.cm.integration.services.customerservice.v1.CustomerService;
import com.oracle.retail.integration.base.bo.customerref.v1.CustomerRef;
import com.oracle.retail.integration.base.bo.invocationsuccess.v1.InvocationSuccess;
public class CustomerServlet extends HttpServlet {
 private static final long serialVersionUID = 5798562566372551297L;
 protected void doGet(HttpServletRequest request,
                     HttpServletResponse response)
                     throws ServletException, IOException {
  doPost(request, response);
 protected void doPost(HttpServletRequest request,
  response.getWriter().write("<html><body> Policy B testing with WebLogic policy </body></html>");
  try {
   // Key store information
   String hostName = getHostName();
   String clientKeyStore = "config/" + hostName + "-keystore.jks";
   String clientKeyStorePass = "123456"; // From wallet in production
   String clientKeyAlias = hostName + "-public-private-key-alias";
   String clientKeyPass = "123456";      // From wallet in production
   // Hostname for remote host alias can be found from the URL of the OSB service
   String remoteHostAlias = "rsbhost-remote-host-public-key-alias";
   // Get remote server certificate from key store
   FileInputStream fis = new FileInputStream(new File(clientKeyStore));
   KeyStore keystore = KeyStore.getInstance("JKS");
   keystore.load(fis, clientKeyStorePass.toCharArray());
   final X509Certificate serverCert =
           (X509Certificate) keystore.getCertificate(remoteHostAlias);
   serverCert.checkValidity();
   // Set security policies
   InputStream encryptBodyPolicy = this.getClass().getClassLoader().getResourceAsStream("weblogic/wsee/policy/runtime/Wssp1.2-2007-EncryptBody.xml");
   InputStream signBodyPolicy = this.getClass().getClassLoader().getResourceAsStream("weblogic/wsee/policy/runtime/Wssp1.2-2007-SignBody.xml");
   InputStream usernameTokenPolicy = this.getClass().getClassLoader()
.getResourceAsStream("weblogic/wsee/policy/runtime/Wssp1.2-2007-Wss1.1-UsernameToken-Plain-EncryptedKey-Basic128.xml");
   ClientPolicyFeature clientPolicyFeature = new ClientPolicyFeature();
   clientPolicyFeature.setEffectivePolicy(new
             InputStreamPolicySource(encryptBodyPolicy, signBodyPolicy,
                                     usernameTokenPolicy));
   // Prepare credential providers
   List<CredentialProvider> credProviders = new
            ArrayList<CredentialProvider>();
   CredentialProvider messageProtectionProvider = new
            ClientBSTCredentialProvider(clientKeyStore, clientKeyStorePass,
                clientKeyAlias, clientKeyPass, "JKS",           serverCert);
   credProviders.add(messageProtectionProvider);
   ClientUNTCredentialProvider userNameTokenProvider = new
         ClientUNTCredentialProvider("rsbuser".getBytes(),
                                     "rsbuser1".getBytes());
   credProviders.add(userNameTokenProvider);
   // Prepare service context
   String wsdlUrl = "http://rsbhost:9004/cm-Customer-AppServiceDecorator/ProxyService/CustomerAppServiceProxy?wsdl";
   CustomerService service = new CustomerService(
                new URL(wsdlUrl),
                new QName(
"http://www.oracle.com/retail/cm/integration/services/CustomerService/v1", "CustomerService"));
   CustomerPortType servicePort =
               service.getCustomerPort(clientPolicyFeature);
   Map<String, Object> reqContext =
               ((BindingProvider) servicePort).getRequestContext();
   reqContext.put(WSSecurityContext.CREDENTIAL_PROVIDER_LIST, credProviders);
   reqContext.put(WSSecurityContext.TRUST_MANAGER, new TrustManager() {
        public boolean certificateCallback(X509Certificate[] chain,
                    int validateErr) {
        // Check that the server cert matches
        boolean result = chain[0].equals(serverCert);
        return result;
   // Invoke the service
   CustomerRef customerRef = new CustomerRef();
   customerRef.setCustomerId("1");
   InvocationSuccess invSuccess = servicePort.deleteCustomer(customerRef);
   response.getWriter().write("<html><body>Got Response : "
                + invSuccess.getSuccessMessage() + "</body></html>");
  } catch (Exception e) {
        e.printStackTrace();
  response.getWriter().flush();
  response.getWriter().close();
// This method returns the hostname of the server where application is running
   private String getHostName(){
        String wlsHostName = null;
        try {
        String hostName = java.net.InetAddress.getLocalHost().getHostName();
        wlsHostName = hostName.split("\\.")[0];
        } catch (UnknownHostException e) {
        throw new RuntimeException(e);
        return wlsHostName;
