| Oracle® Retail Functional Artifact Generator Guide Release 16.0.023 E89609-01 |
![]() Previous |
![]() Next |
This appendix provides a sample customization and localization of ASNInDesc, which is used as input to create custom and localization templates in various examples in this document.
Note that the XSD contains no extension hooks (such as import statements and reference elements). After the custom template is created, the extension hook for customization is added to ASNInDesc.xsd.
The reference element is added to ASNInDesc complex type, as shown in the following screen.
Similarly, for localization (such as Brazil), the import statement and reference elements are added to ASNInDesc.xsd, as shown in the following screen.
The custom template, ExtOfASNInDesc.xsd, is created from the tool, as shown in the following screen.
The localization template created from the tool appears as follows in the illustrations of LOCOfASNInDesc.xsd, BrASNInDesc.xsd, and EOfBrASNInDesc.xsd.
LocOfASNInDesc.xsd
BrASNInDesc.xsd
EOfBrASNInDesc.xsd
