| Oracle® Retail Integration Bus Service-Oriented Architecture Enabler Tool Guide Release 16.0.023 E89674-01 |
![]() Previous |
![]() Next |
This chapter includes standards and conventions for Web service naming and versioning.
The following standards and conventions apply to the naming of Web services.
The Web service name should be a business noun, concept or process.
| Item | Description |
| Recommendation | The Web service name should be a business noun, a business concept, or a business process. |
| Rationale | To be in alignment with other Web service standards. |
| Example | Supplier Service |
Avoid verbs when naming Web services.
| Rationale | Verbs generally are at the operation level, not at the service level. |
| Example | Avoid names such as CreateSupplierService. |
The first 30 characters of the Web service name must be unique.
| Recommendation | The first 30 characters of the Web service name must be unique. |
| Rationale | Some systems truncate names at 30 characters. |
| Example | N/A |
The integration/services qualifier should be in the namespace.
| Recommendation | The integration/services qualifier should be in the namespace. |
| Rationale | |
| Example | http://www.oracle.com/retail/rms/integration/services/PayTermService. |
The Web service namespace should contain the application short name.
| Recommendation | The Web service namespace should contain the application short name. |
| Rationale | Multiple applications may publish services with similar names. To categorize and identify which application is hosting what service, the service namespace should contain the application short name. |
The Web service type should be document/literal wrapped.
| Recommendation | The Web service type should be document/literal wrapped. |
| Rationale | This is defined in the WSDL. |
| Example |
<soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document"/> <operation name="createPayTermBO"> <ns21:PolicyReference xmlns:ns21="http://www.w3.org/ns/ws-policy" URI="#PayTermServicePortBinding_createPayTermBO_WSAT_Policy"/> <soap:operation soapAction=""/> <input> <soap:body use="literal"/> </input> |
The Web service must comply with Web Service Basic Profile 1.1.
| Recommendation | The Web service must comply with Web Service Basic Profile 1.1. |
| Rationale | The specification is called the WS-I Basic Profile 1.1. It consists of a set of non-proprietary Web services specifications, clarifications, refinements, interpretations, and amplifications of those specifications which promote interoperability. |
| Example | N/A |
The Web service operation naming pattern should be verb<TopLevelComplexType>(TopLevelComplexType variable).
| Recommendation | The operation name pattern should be either of the following:
| Rationale | The operation name should reflect the Top Level Complex Type of the service's primary entity object to ensure the name is unambiguous. |
| Example | createItemListBO |
Service versioning is in the namespace, including the application and the version identifier.
The service namespace is versioned.
| Recommendation | The WSDL for the RBS will have the namespace versioned. |
| Rationale | For breaking changes only, the WSDL for the RBS will have the namespace versioned.
http://www.oracle.com/retail/<retail app>/integration/services/<service name>/V<incremental change number> |
| Example | http://www.oracle.com/retail/rms/integration/services/PayTermService/V2 |
