Go to primary content
Oracle® Retail Integration Console User Guide
16.0.023
E90676-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
14 Enterprise Integration Guide
The RIC application has the Oracle Retail Enterprise Integration Guide built in, for ease of access. This tab is an entry point to the Integration Guide.
The Integration Guide is the master document that has in-depth information about Oracle Retail Integration Interfaces including RIB, RSL, IGS and RSB. This gives an enterprise view of integration points across different integration patterns. You can find the information on a particular message flow/an application/or an integration pattern.
For detailed information about a particular message flow execution path in the Integration Guide, you can select the flow ID. The control navigates to Flow information in the Integration guide tab.
