| Oracle® Retail Bulk Data Integration Implementation Guide Release 16.0.027 E94818-01 |
![]() Previous |
![]() Next |
Batch service is a RESTful service that provides various endpoints to manage batch jobs in Job Admin.
The endpoint "discover" can be used to identify all endpoints provided by Job Admin.
| REST Resource | HTTP Method | Description |
| /discover | GET | Lists all available endpoints in Job Admin |
| /batch/jobs | GET | Gets all available batch jobs |
| /batch/jobs/enable-disable | POST | Enable or disable jobs |
| /batch/jobs/{jobName} | GET | Gets all instances for a job |
| /batch/jobs/{jobName}/executions | GET | Gets all executions for a job |
| /batch/jobs/executions | GET | Gets all executions |
| /batch/jobs/currently-running-jobs | GET | Gets currently running jobs |
| /batch/jobs/{jobName}/{jobInstanceId}/executions | GET | Gets job executions for a job instance |
| /batch/jobs/{jobName}/{jobExecutionId} | GET | Gets job instance and execution for a job execution id |
| /batch/jobs/{jobName} | POST | Starts a job asynchronously |
| /batch/jobs/executions/{jobExecutionId} | POST | Restarts a stopped or failed job |
| /batch/jobs/executions | DELETE | Stops all running job executions |
| /batch/jobs/executions/{jobExecutionId} | DELETE | Stops a job execution |
| /batch/jobs/executions/{jobExecutionId} | GET | Gets execution steps with details |
| /batch/jobs/executions/{jobExecutionId}/steps | GET | Gets execution steps |
| /batch/jobs/executions/{jobExecutionId}/steps/{stepExecutionId} | GET | Gets step details |
| /batch/jobs/job-def-xml-files | GET | Gets all job xml files |
| /telemetry/jobs | GET | Returns runtime job metrics between fromTime and toTime |
