| Oracle® Retail Bulk Data Integration Installation Guide Release 16.0.030 E99914-01 |
![]() Previous |
![]() Next |
In 16.0.030 version, to accelerate the application performance, following indexes are newly created on the listed tables in JobAdmin, Processflow and SchedulerAdmin applications.
Process Flow Admin
| Table Name | Index Name |
BDI_ACTIVITY_EXEC_INSTANCE |
INDX_ACTIVITY_EXEC_INSTANCE_1 |
BDI_PROCESS_EXEC_INSTANCE |
INDX_PROCESS_EXECUTION_1 |
INDX_PROCESS_EXECUTION_2 |
INDX_PROCESS_EXECUTION_3 |
BDI_PROCESS_CALL_STACK |
INDX_PROCESS_CALL_STACK_1 |
INDX_PROCESS_CALL_STACK_2 |
Scheduler Admin
BDI_SCHEDULE_EXECUTION |
INDX_SCHEDULE_EXEC_1 |
INDX_SCHEDULE_EXEC_2 |
INDX_SCHEDULE_EXEC_3 |
INDX_SCHEDULE_EXEC_4 |
Job Admin
BDI_DWNLDR_IFACE_MOD_DATA_CTL |
INDX_DNLDR_IFACE_MD_DAT_CL_1 |
INDX_DNLDR_IFACE_MD_DAT_CL_2 |
INDX_DNLDR_IFACE_MD_DAT_CL_3 |
BDI_DWNLDR_TRNSMITR_EXE_DSET |
INDX_DT_TRANSMITR_EXE_DSET_1 |
INDX_DT_TRANSMITR_EXE_DSET_2 |
INDX_DT_TRANSMITR_EXE_DSET_3 |
INDX_DT_TRANSMITR_EXE_DSET_4 |
BDI_UPLOADER_TRANSACTION |
INDX_UPLOADER_TRANSACTION_1 |
INDX_UPLOADER_TRANSACTION_2 |
BDI_RECEIVER_TRANSACTION |
INDX_RECV_TRANSACTION_1 |
BDI_RECEIVER_TRANSMISSION |
INDX_RECEIVER_TRANSMISSION_1 |
BDI_UPLDER_IFACE_MOD_DATA_CTL |
INDX_UPLDR_IFACE_MD_DAT_CL_1 |
INDX_UPLDR_IFACE_MD_DAT_CL_2 |
BDI_UPLOADER_EXE_DATASET |
INDX_UPLOADER_EXE_DATASET_1 |
INDX_UPLOADER_EXE_DATASET_2 |
Migration Steps
During migration from 16.0.025 to 16.0.030, to accommodate for the above-created indexes run the following SQL scripts against respective schemas as listed below.
| Name | File Location | Database Schema for Execution |
migrate-schema-from-16.0.025-to-16.0.027.sql |
bdi-process-home/setup-data/ddl/migration |
Processflow Schema |
migrate-schema-from-16.0.28-to-16.0.030.sql |
bdi-edge-<app>-job-home/setup-data/ddl/migration |
Integration Schema |
bdi-<edge>-app-job-home/setup-data/ddl/migration |
Receiver Schema |
bdi-scheduler-home/setup-data/ddl/migration |
Scheduler Schema |
Note: If both integration schema and receiver schema are same, do not run the migration script twice from bdi-<edge>-app-job-home/setup-data/ddl/migration.If both schemas are different, the user may see the "SQL Error: ORA-00942: table or view does not exist" for the table that does not exist on that schema. For migrating from any version older than 16.0.025, the user needs to run the migration scripts incrementally. |
