| Oracle® Retail Omnichannel Cloud Data Service Installation Guide Release 16.0.030 F12629-01 |
![]() Previous |
![]() Next |
This chapter describes the instructions for building the OCDS schemas on an Oracle 12c Pluggable Database (PDB).
Oracle Database 12c (Release 12.1.0.2) has been installed.
Container Database (CDB) has been created.
Pluggable Database (PDB) for OCDS schema has been created.
Configured ORDS 18.2 for the OCDS database:
Set the location of the ORDS configuration files
java -jar ords.war configdir </path/to/ords/config>
Configure database connection to the OCDS database
java -jar ords.war setup --database <database name>
Configure the request routing rule for OCDS services
java -jar ords.war map-url --type base-path <path prefix> <database name>
The two OCDS database users have been created with the following names:
ocds_ifc
ocds_txn
Perform the following procedure to prepare for these schema creation of the OCDS database. This archive file contains scripts to populate the two OCDS schemas, enable and secure the OCDS REST services.
Unzip ocds-database-creation.zip
Perform the following procedure to populate each of the OCDS schemas.
Execute each schema's db-define script as a DBA role database user:
Specify OCDS database as container.
alter session set container = <database name>;
Execute each db-define:
<database scripts root folder>/scripts/ocds_txn/db-define.sql
<database scripts root folder>/scripts/ocds_ifc/db-define.sql
