| Oracle® Retail Financial Integration for Oracle Retail Merchandise Operations Management and Oracle Financials Installation Guide Installation Guide Release 16.0.030 E99915-01  |
![]() Previous  |
Table B-2 EBS – JSON Configuration
| RFI Configuration Property Name | Description | Example Value/Default Value | Value Editable? |
 RfiDeploymentEnvInfo  |
 integrationToEbsOrPsftOrCfin  |
 EBS  |
 N  |
 DataSourceDef  |
 EbsDataSource  |
 EBS database connection details  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to EBS  |
 EbsDataSource  |
 N  |
 dataSourceClass  |
 DataSource class the installer will configure for the data source  |
 oracle.jdbc.xa.client.OracleXADataSource  |
 N  |
 dataSourceJndiName  |
 JNDI Name used by the RFI application to connect to the database  |
 jdbc/EbsDataSource  |
 N  |
 jdbcUrl  |
 EBS JDBC connection URL. Specify the connection URL for your EBS installation.  |
 jdbc:oracle:thin:@//ebsdbhost.example.com:1521/orcl  |
 Y  |
 jdbcUserAlias  |
 EBS user name alias. Do not change the default value.  |
 ebsDataSourceUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the EBS database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the EBS database.  |
 GET_FROM_WALLET  |
 N  |
 RmsDataSource  |
 RMS database connection details  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to RMS database  |
 RmsDataSource  |
 N  |
 dataSourceClass  |
 oracle.jdbc.OracleDriver  |
 N  |
 JNDI name used by the RFI application to connect to the AQ database  |
 jdbc/RmsDataSource  |
 N  |
 jdbcUrl  |
 RMS JDBC connection URL. Specify the connection URL for RMS DB.  |
 jdbc:oracle:thin:@//rmsdbhost.example.com:1521/orcl  |
 Y  |
 jdbcUserAlias  |
 User name alias. Do not change the default value.  |
 rmsDataSourceUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the RMS database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the RMS database.  |
 GET_FROM_WALLET  |
 N  |
 RfiDataSource  |
 RFI database connection details  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to RFI database.  |
 RfiDataSource  |
 N  |
 dataSourceClass  |
 N  |
 jdbc/RfiDataSource  |
 N  |
 jdbcUrl  |
 RFI JDBC connection URL. Please specify the connection URL for your RFI DB.  |
 jdbc:oracle:thin:@//rfidbhost.example.com:1521/orcl  |
 Y  |
 jdbcUserAlias  |
 rfiDataSourceUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the RFI database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the RFI database.  |
 GET_FROM_WALLET  |
 N  |
 OdiMasterDataSource  |
 ODI Master Repository database connection details  |
 dataSourceName  |
 ODI database's data source name used to identify the data source to ODBC.  |
 N  |
 dataSourceClass  |
 DataSource class that the installer will use to configure the data source  |
 N  |
 JNDI name used by the RFI application to connect to the database  |
 jdbc/OdiMasterDataSource  |
 N  |
 jdbcUrl  |
 ODI JDBC connection URL  |
 jdbc:oracle:thin:@//odimasterhostname.us.custom.com:1521/plgdb  |
 Y  |
 jdbcUserAlias  |
 Jdbc user name alias. Do not change the default value.  |
 odiMasterDataSourceUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the ODI master repository database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the ODI master repository database.  |
 GET_FROM_WALLET  |
 N  |
 OdiWorkDataSource  |
 ODI work repository database connection details  |
 dataSourceName  |
 Data source name used to identify ODI work database Do not change the default value.  |
 OdiWorkDataSource  |
 N  |
 dataSourceClass  |
 Datasource class. Do not change the default value.  |
 N  |
 JNDI name, in case JNDI is used for connection. Do not change the default value.  |
 jdbc/OdiWorkDataSource  |
 N  |
 jdbcUrl  |
 ODI JDBC connection URL.  |
 jdbc:oracle:thin:@//odiworkhostname.us.custom.com:1521/plgdb  |
 Y  |
 jdbcUserAlias  |
 JDBC user name alias for work repository schema. Do not change the default value.  |
 odiWorkDataSourceUserAlias  |
 N  |
 jdbcUser  |
 DB user name for the ODI work repository schema.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the ODI ODI work repository schema.  |
 GET_FROM_WALLET  |
 N  |
 OdiStagingAreaDataSource  |
 ODI Staging Area database connection details  |
 dataSourceName  |
 ODI staging database connection details. It is recommended to have the ODI staging schema (RFI_ODI_TEMP) in the EBS or PeopleSoft database.  |
 N  |
 dataSourceClass  |
 ODI staging datasource class. Do not change the default.  |
 N  |
 ODI staging JNDI name. Do not change the default value.  |
 jdbc/OdiStagingAreaDataSource  |
 N  |
 jdbcUrl  |
 ODI RFI staging area JDBC connection URL.  |
 jdbc:oracle:thin:@//odistaginghostname.us.custom.com:1521/plgdb  |
 Y  |
 jdbcUserAlias  |
 JDBC user name alias for staging repository. Do not change the defaults.  |
 odiStagingAreaDataSourceUserAlias  |
 N  |
 jdbcUser  |
 DB User name for the ODI Staging Area schema.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the ODI Staging Area schema.  |
 GET_FROM_WALLET  |
 N  |
 MiddlewareServerDef  |
 RfiAppServer  |
 RfiAppServer- WebLogic domain configuration details  |
 weblogicDomainName  |
 RfiAppServer configuration, WebLogic domain name  |
 RFIDomain  |
 Y  |
 weblogicDomainHome  |
 RFI domain home.  |
 <WLS-HOME>/user_projects/domains/RFIDomain  |
 Y  |
 weblogicDomainAdminServerUrl  |
 WebLogic domain admin server URL.  |
 t3://rfiserver.example.com:19301  |
 Y  |
 weblogicDomainAdminServerProtocol  |
 WebLogic admin server protocol.  |
 t3  |
 N  |
 weblogicDomainAdminServerHost  |
 Weblogic server host name.  |
 rfiserver.example.com  |
 Y  |
 weblogicDomainAdminServerPort  |
 Port information of weblogic server.  |
 19301  |
 Y  |
 weblogicDomainAdminServerUserAlias  |
 Weblogic server User name alias.  |
 rfiAppServerAdminServerUserAlias  |
 N  |
 weblogicDomainTargetManagedServerName  |
 Weblogic Domain Target Managed Server name.  |
 rfi-server  |
 Y  |
 glAccountValidationServiceEndPointUrl  |
 End point URL for GL account validation Service without RSB configuration.  |
 http://myhostname:7001/GlAccountValidationBean/GlAccountValidationService?WSDL  |
 Y  |
 glAccountValidationServiceEndPointUserAlias  |
 User alias information for GL account validation service. Do not change the default value.  |
 N  |
 glAccountValidationServiceEndPointUser  |
 End point User name.  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationServiceEndPointPassword  |
 End point User password.  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationServiceEndPointSecurityPolicyName  |
 Security policy for the service. Valid values are PolicyA, PolicyB and unsecure.(Note: Use https for Policy A setting)  |
 unsecure  |
 Y  |
 rfiAdminUiUrl  |
 URL for RFI Admin UI.  |
 http://myhostname:7001/retail-financial-integration-web  |
 Y  |
 rfiAdminUiUserGroup  |
 Admin user group. Do not change the default value.  |
 RfiAdminGroup  |
 N  |
 rfiAdminUiUserAlias  |
 RFI admin UI user name alias. Do not change the default value.  |
 N  |
 rfiAdminUiUser  |
 RFI admin UI user name.  |
 GET_FROM_WALLET  |
 N  |
 rfiAdminUiPassword  |
 End point user password.  |
 GET_FROM_WALLET  |
 N  |
 smtpServerHost  |
 RFI SMTP (Simple Mail Transfer Protocol) server host information.  |
 smtp.example.com  |
 Y  |
 smtpServerPort  |
 RFI SMTP server port information.  |
 465  |
 Y  |
 smtpServerListenerType  |
 RFI SMTP server listener type (for example, SSL or TSL).  |
 SSL  |
 N  |
 smtpAuthenticationRequired  |
 Enter "TRUE" if authentication required for SMTP server, else "FALSE".  |
 TRUE  |
 Y  |
 smtpMailFromAddress  |
 Enter the sender email Address.  |
 sender_email_address@example.com  |
 Y  |
 smtpMailFromAddressAlias  |
 Alias for From Address. Do not change the default value.  |
 N  |
 smtpMailFromAddressPassword  |
 Password for the from email address.  |
 GET_FROM_WALLET  |
 N  |
 smtpMailToAddressList  |
 Comma seperated list of receipient email addresses.  |
 receiver_email_address@abc.com, receiver_email_address2@abc.com  |
 Y  |
 IgsAppServer  |
 RFI Integrated Gateway Services detail for Currency Rate service  |
 currencyRateServiceEndPointUrl  |
 IGS Currency Rate endpoint URL (if no RSB is configured).  |
 http://igshostname:19201/CurRatePublishingBean/CurRatePublishingService?wsdl  |
 Y  |
 IGS Currency Rate endpoint URL (If RSB is configured).  |
 http://igshostname:19201/igs-CurRatePublishing-AppServiceDecorator/ProxyService/CurRatePublishingAppServiceProxy?wsdl  |
 Y  |
 currencyRateServiceEndPointUserAlias  |
 Alias for Currency Rate service End point User Alias. Do not change default value.  |
 N  |
 currencyRateServiceEndPointUser  |
 UserName for Currency Rate service.  |
 GET_FROM_WALLET  |
 N  |
 currencyRateServiceEndPointPassword  |
 Password for Currency Rate service.  |
 GET_FROM_WALLET  |
 N  |
 currencyRateServiceEndPointSecurityPolicyName  |
 Security policy for the service. Valid values are PolicyA, PolicyB and unsecure. (Note: Use https for Policy A setting)  |
 unsecure  |
 Y  |
 currencyRateServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias  |
 WSKeyStore Password User Alias for Currency Rate service End point PolicyB.  |
 currencyRate#keystore-password-user-alias  |
 N  |
 currencyRateServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias  |
 WSKeyPublicPrivateKey Alias forCurrency Rate service End point User PolicyB.  |
 currencyRate#remote-host-public-private-key-alias  |
 N  |
 RmsAppServer  |
 RFI Integrated Gateway Services detail for Supplier service  |
 supplierServiceEndPointUrl  |
 Supplier service endpoint URL information (with no RSB).  |
 http://rmshostname.example.com:19203/SupplierBean/SupplierService?WSDL  |
 Y  |
 Supplier service endpoint URL (with RSB).  |
 http://rmshostname.example.com:19203/rms-Supplier-AppServiceDecorator/ProxyService/SupplierAppServiceProxy?wsdl  |
 Y  |
 supplierServiceEndPointUserAlias  |
 Alias for Supplier service. Do not change the default.  |
 N  |
 supplierServiceEndPointUser  |
 UserName for Supplier Service End point User.  |
 GET_FROM_WALLET  |
 N  |
 supplierServiceEndPointPassword  |
 Password for Supplier service.  |
 GET_FROM_WALLET  |
 N  |
 supplierServiceEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 supplierServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias  |
 WSKeyStore Password User Alias for Supplier Service End point User Alias.  |
 supplier#keystore-password-user-alias  |
 N  |
 supplierServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias  |
 WSKeyPublicPrivateKey Alias for Supplier Service End point User Alias.  |
 supplier#remote-host-public-private-key-alias  |
 N  |
 EbsAppServer  |
 EBS App Server Configuration Details  |
 ebsInstanceJavaTopLocation  |
 EBS server $JAVA_TOP folder path.Note: If EBS is installed on Oracle Application Server substitute the corresponding OAS/oc4j information instead of WebLogic server information  |
 /u01/applmgr/apps/apps_st/comn/java/classes  |
 Y  |
 EBS WebLogic Domain Name.  |
 ebs_domain  |
 Y  |
 EBS WebLogic Domain Home.  |
 /path/ebs_domain  |
 Y  |
 EBS WebLogic domain admin server URL.  |
 t3://ebshostname:7001  |
 Y  |
 EBS WebLogic domain admin server user alias  |
 ebsAppServerAdminServerUserAlias  |
 N  |
 weblogicDomainAdminServerUser  |
 EBS WebLogic admin server user name.  |
 GET_FROM_WALLET  |
 N  |
 weblogicDomainAdminServerPassword  |
 EBS WebLogic admin server password.  |
 GET_FROM_WALLET  |
 N  |
 RfiBulkServer  |
 RFI Bulk Server ODI Configuration Details  |
 odiHost  |
 ODI host name. Host name of the machine where ODI is installed.  |
 Odihostname  |
 Y  |
 odiUrl  |
 Path in machine name(odihostname), where ODI is installed.  |
 /path_where_odi_is_installed/oracledi/agent  |
 Y  |
 odiUserAlias  |
 ODI user alias. Do not change the default  |
 rfiBulkServerOdiUserAlias  |
 N  |
 odiUser  |
 ODI User Name.  |
 GET_FROM_WALLET  |
 N  |
 odiPassword  |
 ODI user name password.  |
 GET_FROM_WALLET  |
 N  |
 odiAgentHost  |
 ODI agent host name. Name of the machine where ODI agent is installed. Typically, this is the same machine which is a source.  |
 odihostname  |
 Y  |
 odiAgentPort  |
 ODI agent port information. Constant/ recommended to be 20910.  |
 20910  |
 Y  |
Table B-3 PeopleSoft – JSON Configuration
 PSFT  |
 N  |
 DataSourceDef  |
 PsftDataSource  |
 Peoplesoft database connection details  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to Peoplesoft  |
 PsftDataSource  |
 N  |
 dataSourceClass  |
 N  |
 jdbc/PsftDataSource  |
 N  |
 jdbcUrl  |
 Peoplesoft JDBC connection URL. Specify the connection URL for your Peoplesoft installation.  |
 Y  |
 jdbcUserAlias  |
 Peoplesoft user name alias. Do not change the default value.  |
 psftDataSourceUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the Peoplesoft database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the Peoplesoft database  |
 GET_FROM_WALLET  |
 N  |
 RmsDataSource  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to RMS  |
 RmsDataSource  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the RMS database  |
 GET_FROM_WALLET  |
 N  |
 RfiDataSource  |
 dataSourceName  |
 Name of the datasource that the installer creates to connect to RFI  |
 RfiDataSource  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 dataSourceName  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 OdiWorkDataSource  |
 dataSourceName  |
 OdiWorkDataSource  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 User name for the ODI work repository schema.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 Password for the ODI work repository schema.  |
 GET_FROM_WALLET  |
 N  |
 dataSourceName  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 ODI RFI staging area JDBC connection URL  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 RfiAppServer  |
 RFIDomain  |
 Y  |
 RFI domain home.  |
 Y  |
 Y  |
 t3  |
 N  |
 Y  |
 19301  |
 Y  |
 Weblogic server UserAlias name. Do not change defaults  |
 N  |
 rfi-server  |
 Y  |
 End point URL for GL account validation Service  |
 Y  |
 N  |
 GET_FROM_WALLET  |
 N  |
 End point User password. This information is sourced from a container that is used for storing authentication and signing credentials and is managed by Security Admins.  |
 GET_FROM_WALLET  |
 N  |
 unsecure  |
 Y  |
 drillBackForwardUrlServiceEndPointUrl  |
 End point URL for drillBackForward Service without RSB configuration.  |
 http://myhostname:7001/DrillBackForwardUrlBean/DrillBackForwardUrlService?WSDL  |
 Y  |
 End point URL for drillBackForward Service with RSB configuration.  |
 http://myhostname:7001/fin-DrillBackForwardUrl-AppServiceDecorator/ProxyService/DrillBackForwardUrlAppServiceProxy?wsdl  |
 Y  |
 drillBackForwardUrlServiceEndPointUserAlias  |
 N  |
 drillBackForwardUrlServiceEndPointUser  |
 DrillBackForward Url Service End point User name.  |
 GET_FROM_WALLET  |
 N  |
 drillBackForwardUrlServiceEndPointPassword  |
 DrillBackForward Url Service End point User password.  |
 GET_FROM_WALLET  |
 N  |
 drillBackForwardUrlServiceEndPointSecurityPolicyName  |
 Indicates how the Policy is secured. Options are Policy A, Policy B or Unsecure.  |
 unsecure  |
 Y  |
 supplierBusinessEventHandlerServiceEndPointUrl  |
 URL information that will be used in connection for Supplier Business Event handler Service.  |
 http://myhostname:7001/SupplierBusinessEventHandlerBean/SupplierBusinessEventHandlerService?WSDL  |
 Y  |
 supplierBusinessEventHandlerServiceEndPointUserAlias  |
 User Alias. Constant at Supplier Business Event handler Service User Alias.  |
 N  |
 supplierBusinessEventHandlerServiceEndPointUser  |
 Supplier Business Event handler Service User name.  |
 GET_FROM_WALLET  |
 N  |
 supplierBusinessEventHandlerServiceEndPointPassword  |
 Supplier Business Event handler Service End point User password.  |
 GET_FROM_WALLET  |
 N  |
 supplierBusinessEventHandlerServiceEndPointSecurityPolicyName  |
 Indicates how the Policy is secured. Options are Policy A, Policy B or Unsecure. (Note: Use https for Policy A setting)  |
 unsecure  |
 Y  |
 payTermBusinessEventHandlerServiceEndPointUrl  |
 End point URL for PaytermBusiness Event Handler Service.  |
 http://myhostname:7001/PayTermBusinessEventHandlerBean/PayTermBusinessEventHandlerService?WSDL"  |
 Y  |
 payTermBusinessEventHandlerServiceEndPointUserAlias  |
 User Alias. Constant at payTermBusinessEventHandlerServiceEndPointUserAlias.  |
 N  |
 payTermBusinessEventHandlerServiceEndPointUser  |
 PaytermBusiness Event Handler Service End point User name.  |
 GET_FROM_WALLET  |
 N  |
 payTermBusinessEventHandlerServiceEndPointPassword  |
 PaytermBusiness Event Handler Service End point User password.  |
 GET_FROM_WALLET  |
 N  |
 payTermBusinessEventHandlerServiceEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 rfiAdminUiUrl  |
 Y  |
 RfiAdminGroup  |
 N  |
 N  |
 rfiAdminUiUser  |
 RFI Admin UI User name.  |
 GET_FROM_WALLET  |
 N  |
 GET_FROM_WALLET  |
 N  |
 smtpServerHost  |
 smtp.example.com  |
 Y  |
 smtpServerPort  |
 465  |
 Y  |
 SSL  |
 N  |
 TRUE  |
 Y  |
 Y  |
 N  |
 GET_FROM_WALLET  |
 N  |
 Y  |
 IgsAppServer  |
 Y  |
 Y  |
 N  |
 GET_FROM_WALLET  |
 N  |
 Password for for Currency Rate service.  |
 GET_FROM_WALLET  |
 N  |
 unsecure  |
 Y  |
 N  |
 N  |
 RmsAppServer  |
 Y  |
 Y  |
 N  |
 GET_FROM_WALLET  |
 N  |
 GET_FROM_WALLET  |
 N  |
 unsecure  |
 Y  |
 N  |
 N  |
 PsftAppServer  |
 PSFT App Server Configuration Details  |
 PSFT WebLogic Domain Name.  |
 ebs_domain  |
 Y  |
 PSFT WebLogic Domain Home.  |
 /path/ebs_domain  |
 Y  |
 PSFT WebLogic domain admin server URL.  |
 Y  |
 PSFT WebLogic domain admin server user alias  |
 psftAppServerAdminServerUserAlias  |
 N  |
 PSFT WebLogic admin server user name.  |
 GET_FROM_WALLET  |
 N  |
 PSFT WebLogic admin server password.  |
 GET_FROM_WALLET  |
 N  |
 psftApplicationUrl  |
 Peoplesoft Application URL.  |
 http://psfthostname:7777/psp  |
 Y  |
 psftApplicationUrlSite  |
 Path of Application URL in peoplesoft domain  |
 ps  |
 N  |
 psftApplicationUrlPortalNodeContent  |
 Peoplesoft Application URL portal node content.  |
 EMPLOYEE/ERP/c  |
 N  |
 psftApplicationUserAlias  |
 Peoplesoft Application URL domain admin server useralias  |
 N  |
 psftApplicationUser  |
 Peoplesoft Application URL UserName.  |
 GET_FROM_WALLET  |
 N  |
 psftApplicationPassword  |
 Peoplesoft Application URL User Password.  |
 GET_FROM_WALLET  |
 N  |
 comboChartFieldServiceEndPointUrl  |
 PeopleSoft comboChart Field service End point URL.  |
 http://psfthostname:7777/PSIGW/PeopleSoftServiceListeningConnector/COMBO_CF_EDIT_REQUEST.1.wsdl  |
 Y  |
 comboChartFieldServiceEndPointUserAlias  |
 PeopleSoft comboChart Field service End point User Alias.  |
 N  |
 comboChartFieldServiceEndPointUser  |
 PeopleSoft comboChart Field service End point Username.  |
 GET_FROM_WALLET  |
 N  |
 comboChartFieldServiceEndPointPassword  |
 PeopleSoft comboChart field service End point Username Password.  |
 GET_FROM_WALLET  |
 N  |
 comboChartFieldServiceEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 comboChartFieldServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias  |
 PeopleSoft comboChart field service End point WebserviceKeyStore Password User alias.  |
 payTerm#keystore-password-user-alias  |
 N  |
 comboChartFieldServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias  |
 PeopleSoft comboChart field service End point Web service Keyprivate key alias.  |
 payTerm#remote-host-public-private-key-alias  |
 N  |
 rfiInvoiceDrillForwardServiceEndPointUrl  |
 RFI Invoice drill forward service End point URL  |
 http://psfthostname:7777/PSIGW/PeopleSoftServiceListeningConnector/RFI_INV_DRILLFORWARD_SERVICE.1.wsdl  |
 Y  |
 rfiInvoiceDrillForwardServiceEndPointUserAlias  |
 RFI Invoice drill forward service EndPointUser Alias. Constant at rfiInvoiceDrillForwardServiceEndPointUserAlias.  |
 N  |
 rfiInvoiceDrillForwardServiceEndPointUser  |
 RFI Invoice drill forward service EndPoint Username.  |
 GET_FROM_WALLET  |
 N  |
 rfiInvoiceDrillForwardServiceEndPointPassword  |
 RFI Invoice drill forward service EndPoint Username Password.  |
 GET_FROM_WALLET  |
 N  |
 rfiInvoiceDrillForwardServiceEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 rfiInvoiceDrillForwardServiceEndPointPolicyBSecurityPolicy.wsKeystorePasswordUserAlias  |
 RFI Invoice drill forward service EndPoint WebserviceKeyStore Password User alias.  |
 N  |
 rfiInvoiceDrillForwardServiceEndPointPolicyBSecurityPolicy.wsKeyPublicPrivateKeyAlias  |
 RFI Invoice drill forward service EndPoint Web service Keyprivate key alias.  |
 N  |
 RfiBulkServer  |
 N  |
 odiHost  |
 Odihostname  |
 Y  |
 odiUrl  |
 Y  |
 odiUserAlias  |
 N  |
 odiUser  |
 ODI User Name.  |
 GET_FROM_WALLET  |
 N  |
 odiPassword  |
 GET_FROM_WALLET  |
 N  |
 odiAgentHost  |
 ODI agent host name. Name of the machine where ODI agent is installed.  |
 odihostname  |
 Y  |
 odiAgentPort  |
 20910  |
 Y  |
Table B-4 Cloud Financials – JSON Configuration
 integrationToEbsOrPsft OrCfin  |
 CFIN  |
 N  |
 DataSourceDef  |
 RmsDataSource  |
 dataSourceName  |
 RmsDataSource  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 jdbc:oracle:thin:@//rmsdbhost.ex ample.com:1521/orcl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 RfiDataSource  |
 dataSourceName  |
 RfiDataSource  |
 N  |
 dataSourceClass  |
 oracle.jdbc.xa.client.OracleXADat aSource  |
 N  |
 N  |
 jdbcUrl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 RfiDataSource  |
 dataSourceName  |
 RfiDataSource  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 jdbc:oracle:thin:@//rfidbhost.exa mple.com:1521/orcl  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 dataSourceName  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 jdbc:oracle:thin:@//odimasterhos tname.us.custom.com:1521/plgdb  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 User (schema name) for the ODImaster repository database.  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 OdiWorkDataSource  |
 dataSourceName  |
 OdiWorkDataSource  |
 N  |
 N  |
 jdbcUrl  |
 jdbc:oracle:thin:@//odiworkhost name.us.custom.com:1521/plgdb  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 OdiStagingAreaDataSou rce  |
 dataSourceName  |
 N  |
 dataSourceClass  |
 N  |
 N  |
 jdbcUrl  |
 jdbc:oracle:thin:@//odistagingho stname.us.custom.com:1521/plgd b  |
 Y  |
 jdbcUserAlias  |
 N  |
 jdbcUser  |
 GET_FROM_WALLET  |
 N  |
 jdbcPassword  |
 GET_FROM_WALLET  |
 N  |
 RfiAppServer  |
 RFIDomain  |
 Y  |
 RFI domain home.  |
 Y  |
 WebLogic domain admin serverURL.  |
 Y  |
 t3  |
 N  |
 Y  |
 19301  |
 Y  |
 rfiAppServerAdminServerUserAl ias  |
 N  |
 Weblogic Domain TargetManaged Server name.  |
 rfi-server  |
 Y  |
 glAccountValidationServ iceEndPointUrl  |
 http://myhostname:7001/GlAcc ountValidationBean/GlAccountV alidationService?WSDL  |
 Y  |
 glAccountValidationServ iceEndPointUserAlias  |
 N  |
 glAccountValidationServ iceEndPointUser  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationServ iceEndPointPassword  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationServ iceEndPointSecurityPoli cyName  |
 unsecure  |
 Y  |
 drillBackForwardUrlSer viceEndPointUrl  |
 http://myhostname:7001/DrillBa ckForwardUrlBean/DrillBackFor wardUrlService?WSDL  |
 Y  |
 http://myhostname:7001/fin-Dri llBackForwardUrl-AppServiceDe corator/ProxyService/DrillBackF orwardUrlAppServiceProxy?wsdl  |
 Y  |
 supplierExportOutboundServiceEndPointUrl  |
 URL information that will be used in connection for Supplier Export Outbound Service.  |
 http://myhostname:7001/Suppli erExportOutboundService/Su pplierExportOutboundServi ce?WSDL  |
 Y  |
 supplierExportOutboundServiceEndPointU serAlias  |
 User Alias. Constant at Supplier Export Outbound Service User Alias.  |
 supplierExportOutboundSe rviceEndPointUserAlias  |
 N  |
 supplierExportOutboundServiceEndPointUser  |
 Supplier Export OutboundService User name.  |
 GET_FROM_WALLET  |
 N  |
 supplierExportOutboundServiceEndPointP assword  |
 Supplier Export OutboundService End point User password.  |
 GET_FROM_WALLET  |
 N  |
 supplierExportOutboundServiceEndPointS ecurityPolicyName  |
 unsecure  |
 Y  |
 invoiceEntryInputDirectory  |
 Directory to place ODI created csv files that will be imported for Cfin regarding Invoice Entry  |
 /directory/example  |
 Y  |
 rmsAccountEntryInputDirectory  |
 Directory to place ODI created csv files that will be imported for Cfin regarding RMS Acco unt Entry  |
 Y  |
 reimAccountEntryInputDirectory  |
 Directory to place ODI created csv files that will be imported for Cfin regarding ReIM Account Entry  |
 Y  |
 rfiAdminUiUrl  |
 http://myhostname:7001/retail-f inancial-integration-web  |
 Y  |
 RfiAdminGroup  |
 N  |
 N  |
 rfiAdminUiUser  |
 GET_FROM_WALLET  |
 N  |
 GET_FROM_WALLET  |
 N  |
 smtpServerHost  |
 smtp.example.com  |
 Y  |
 smtpServerPort  |
 465  |
 Y  |
 SSL  |
 N  |
 smtpAuthenticationReq uired  |
 TRUE  |
 Y  |
 Y  |
 N  |
 GET_FROM_WALLET  |
 N  |
 Comma separated list of recipient email addresses.  |
 receiver_email_address@abc.com, receiver_email_ address2@abc.com  |
 Y  |
 IgsAppServer  |
 http://igshostname:19201/CurRa tePublishingBean/CurRatePublis hingService?wsdl  |
 Y  |
 http://igshostname:19201/igs-C urRatePublishing-AppServiceDec orator/ProxyService/CurRatePu blishingAppServiceProxy?wsdl  |
 Y  |
 currencyRateServiceEndPointUse rAlias  |
 N  |
 GET_FROM_WALLET  |
 N  |
 GET_FROM_WALLET  |
 N  |
 currencyRateServiceEnd PointSecurityPolicyNam e  |
 unsecure  |
 Y  |
 currencyRateServiceEnd PointPolicyBSecurityPoli cy.wsKeystorePassword UserAlias  |
 currencyRate#keystore-password- user-alias  |
 N  |
 currencyRateServiceEnd PointPolicyBSecurityPoli cy.wsKeyPublicPrivateK eyAlias  |
 currencyRate#remote-host-public- private-key-alias  |
 N  |
 RmsAppServer  |
 http://rmshostname.example.co m:19203/SupplierBean/SupplierS ervice?WSDL  |
 Y  |
 http://rmshostname.example.co m:19203/rms-Supplier-AppServic eDecorator/ProxyService/Suppli erAppServiceProxy?wsdl  |
 Y  |
 supplierServiceEndPointUserAlia s  |
 N  |
 GET_FROM_WALLET  |
 N  |
 GET_FROM_WALLET  |
 N  |
 unsecure  |
 Y  |
 supplierServiceEndPoint PolicyBSecurityPolicy.ws KeystorePasswordUserA lias  |
 supplier#keystore-password-user- alias  |
 N  |
 supplierServiceEndPoint PolicyBSecurityPolicy.ws KeyPublicPrivateKeyAli as  |
 supplier#remote-host-public-priv ate-key-alias  |
 N  |
 CfinAppServer  |
 Cfin App Server Configuration Details  |
 financialUtilServiceEndPointUrl  |
 Cfin Financial Util Service End Point URL  |
 https://cfinhostname/finFunShared/FinancialUtilService?WSDL  |
 Y  |
 financialUtilServiceEndPointUserAlias  |
 Cfin Financial Util Service User Alias  |
 financialUtilServiceUserNameAlias  |
 N  |
 financialUtilServiceEndPointUser  |
 UserName for Financial Util Service End point User.  |
 GET_FROM_WALLET  |
 N  |
 financialUtilServiceEndPointPassword  |
 Password for Financial Util Service service.  |
 GET_FROM_WALLET  |
 N  |
 financialUtilServiceEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 glAccountValidationEndPointUrl  |
 Cfin General Ledger Validation Service End Point URL  |
 https://cfinhostname/fscmService/AccountCombinationService?WSDL  |
 Y  |
 glAccountValidationEndPointUserAlias  |
 Cfin General Ledger Validation Service User Alias  |
 N  |
 glAccountValidationEndPointUser  |
 UserName for General Ledger Validation Service End point User.  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationEndPointPassword  |
 Password for General Ledger Validation Service service  |
 GET_FROM_WALLET  |
 N  |
 glAccountValidationEndPointSecurityPolicyName  |
 unsecure  |
 Y  |
 RfiBulkServer  |
 N  |
 odiHost  |
 Odihostname  |
 Y  |
 odiUrl  |
 Path in machine name (odihostname), where ODI is installed.  |
 Y  |
 odiUserAlias  |
 N  |
 odiUser  |
 ODI User Name.  |
 GET_FROM_WALLET  |
 N  |
 odiPassword  |
 GET_FROM_WALLET  |
 N  |
 odiAgentHost  |
 odihostname  |
 Y  |
 odiAgentPort  |
 20910  |
 Y  |
