Go to primary content
Oracle® Retail Functional Artifacts Guide
Release 16.0.030
F19481-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
8 Importing Retail Business Objects
This chapter provides details about imports that are allowed in each type of retail business object (XSD). A retail business object does not support cyclic reference to another business object.
Imports in Base Business Object (XSD)
A base business object can import another non-cyclic base business object.
Topic Description
Recommendation Complex business is composed of small non complex business objects.
Rationale Base business object can import another base BO that is not a cyclic reference.
Example
<xs:schema elementFormDefault="qualified" targetNamespace="http://www.oracle.com/retail/integration/base/bo/XItemDesc/v1"  version="1.3"    xmlns="http://www.oracle.com/retail/integration/base/bo/XItem/v1"    xmlns:XItmSupCtyMfr=http://www.oracle.com/retail/integration/base/bo/XItmSupCtyMfr/v1 ><xs:import        namespace="http://www.oracle.com/retail/integration/base/bo/XItmSupCtyMfr/v1" schemaLocation="../../XItmSupCtyMfr/v1/XItmSupCtyMfr.xsd"></xs:import>
A base business object must import generic localized business object.
Topic Description
Recommendation A base business object <BO>, must provision Localization by importing generic localized business object LocOf<BO>.
Rationale A base business object must import generic localized business object LocOf<BO>.
Example
<xs:schema elementFormDefault="qualified"    targetNamespace="http://www.oracle.com/retail/integration/base/bo/XItem/v1"    version="1.3"    xmlns:LocOfXItem="http://www.oracle.com/retail/integration/base/bo/LocOfXItem/v1"            <xs:import        namespace="http://www.oracle.com/retail/integration/base/bo/LocOfXItem/v1" schemaLocation="../../../../base/bo/LocOfXItem/v1/LocOfXItem.xsd"></xs:import>
Imports in Custom Business Object (XSD)
A custom business object can import non-cyclic child custom business objects.
Topic Description
Recommendation A custom business object can be composed of child custom business objects.
Rationale A custom business object, ExtOf<BO> can import custom child business objects, ExtOf<Child Object1> , ExtOf<Child Object2>.
Example
<xs:schema elementFormDefault="qualified"    targetNamespace="http://www.oracle.com/retail/integration/base/bo/ XItmSupCtyMfr /v1" version="1.3" xmlns="http://www.oracle.com/retail/integration/base/bo/ XItmSupCtyMfr /v1"    xmlns:ExtOfXItmSupCtyMfr=http://www.oracle.com/retail/integration/base/bo/ ExtOfXItmSupCtyMfr /v1><xs:import        namespace="http://www.oracle.com/retail/integration/base/bo/ ExtOfXItmSupCtyMfr /v1" schemaLocation="../../ ExtOfXItmSupCtyMfr /v1/ ExtOfXItmSupCtyMfr.xsd"></xs:import>
Imports in Localized Business Object (XSD)
A localized business object can import localized child business objects for the same region only.
Topic Description
Recommendation A localized business object can compose of localized child business objects with same country code only.
Rationale A localized business object, In<BO> can import custom localized business objects In<child BO> with same country code.
Example
<xs:schema elementFormDefault="qualified"    targetNamespace="http://www.oracle.com/retail/integration/localization/bo/InSupplier/v1"    version="1.0"    xmlns="http://www.oracle.com/retail/integration/localization/bo/InSupplier/v1"    xmlns:InSupplierDtl="http://www.oracle.com/retail/integration/custom/bo/ InSupplierDtl /v1"    xmlns:retailDoc="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema">    <xs:import        namespace="http://www.oracle.com/retail/integration/custom/bo/EOfInSupplierDesc/v1" schemaLocation="../../../../custom/bo/ InSupplierDtl /v1/InSupplierDtl.xsd"></xs:import>
A localized business object can import custom localized business objects for the same region only.
Topic Description
Recommendation A localized business object can compose of customized localized business objects with same country code only.
Rationale A localized business object, In<BO> can import custom localized business objects EOfIn<BO> with same country code.
Example
<xs:schema elementFormDefault="qualified"    targetNamespace="http://www.oracle.com/retail/integration/localization/bo/InSupplier/v1"    version="1.0"    xmlns="http://www.oracle.com/retail/integration/localization/bo/InSupplier/v1"    xmlns:EOfInSupplierDesc="http://www.oracle.com/retail/integration/custom/bo/EOfInSupplier/v1"    xmlns:retailDoc="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema">    <xs:import        namespace="http://www.oracle.com/retail/integration/custom/bo/EOfInSupplierDesc/v1" schemaLocation="../../../../custom/bo/EOfInSupplierDesc/v1/EOfInSupplier.xsd">        <retailDoc:annotation>            <retailDoc:documentation>It's a referenced element. For detailed description, please refer referenced element doc.</retailDoc:documentation>        </retailDoc:annotation>    </xs:import>
