| Oracle® Retail Service Backbone Integration Console User Guide June 2019 F19492-01 |
![]() Previous |
![]() Next |
The RIC application has the Oracle Retail Enterprise Integration Guide built in, for ease of access. This tab is an entry point to the Integration Guide.
The Integration Guide is the master document that has in-depth information about Oracle Retail Integration Interfaces including RIB, RSL, IGS and RSB. This gives an enterprise view of integration points across different integration patterns. You can find the information on a particular message flow/an application/or an integration pattern.
For detailed information about a particular message flow execution path in the Integration Guide, you can select the flow ID. The control navigates to Flow information in the Integration guide tab.
