| Oracle® Retail Bulk Data Integration Implementation Guide Release 16.0.21 E87348-01 |
![]() Previous |
![]() Next |
The endpoint "discover" can be used to identify all endpoints provided by Process Flow.
| REST Resource | HTTP Method | Description |
| /discover | GET | Lists all available endpoints |
| /batch/processes/operator/{processName} | POST | Start a new Process Flow execution |
| /batch/processes/executions/{processName} | GET | List Process Executions for the process name |
| /batch/processes/executions | GET | List all process execution ids |
| /batch/processes/executions/status/{status} | GET | List all process execution ids for the specified status |
| /batch/processes/executions/time/{startTime}/{endTime} | GET | List all process execution ids for the specified time range |
| /batch/processes/external-variables | GET | List external variables |
| /batch/processes/external-variables | PUT | Create external variables |
| /batch/processes/external-variables | POST | Update external variables |
| /batch/processes/external-variables/{key} | DELETE | Delete external variable |
| /batch/processes/currently-running-processes | GET | List all the currently running process flows |
| /batch/processes | GET | Get all the available process definitions |
| /batch/processes/{processName} | GET | Get process DSL for the specified process |
| /batch/processes/executions/{processName}/{processExecutionId}/activities/{activityExecutionId} | GET | Get all the activities for the process flow execution |
| /batch/processes/{processName}/activities | GET | Get all the activities for the process specified |
| /batch/processes/operator/{processName}/{processExecutionId} | POST | Restart a process execution instance |
| /batch/processes/operator/{processName}/resolve | POST | Resolves stranded process by setting the status of process to PROCESS_FAILED |
| /batch/processes/{processName}/{processExecutionId} | DELETE | Stops running process |
| /batch/processes/executions | DELETE | Stops all running processes |
| /batch/processes/{processName}/activities/{activityName} | POST | Sets skip, hold flags for activity. Query parameters that can be passed with this end point - "skip", "hold", "actionExpiryDate", "comments". |
| /batch/processes/{processName}/activities/{activityName} | GET | Returns dynamic configuration for activity |
