| Oracle® Retail Job Orchestration and Scheduler Implementation Guide Release 16.0.21 E88078-01 |
![]() Previous |
![]() Next |
This chapter describes the Job Admin functionality.
Here is a list of the Job Admin features.
Provides management and monitoring of batch jobs.
Services available to start/restart/monitor jobs programmatically.
Monitors executions and logs.
Built on JavaEE JSR352 JavaBatch standard and available on WebLogic.
GUI to manage/start/restart batch jobs.
JavaBatch Runtime Engine to execute job.xml files.
The following section includes information about the Job Admin components.
This section describes the RESTFul services.
The Batch service is a RESTful service that provides various endpoints to manage batch jobs. Here are the key endpoints in the Batch Service.
Start Job
This endpoint starts a job asynchronously based on a job name and returns the execution ID of the job in the response.
Path: /batch/jobs/<jobName>
HTTP Method: POST
Inputs:
Job Name as path parameter
Job Parameters is a query parameter. Job Parameters is a comma separated list of name value pairs. This is optional.
Sample Request
http://localhost:7001/jos-batch-job-admin/resources/batch/jobs/ShellCommandRunnerJob?jobParameters=key=value
Successful Response
Restart Job
This endpoint restarts a job asynchronously using the job execution ID and returns the new job execution ID.
Path: /batch/jobs/executions/{executionId}
HTTP Method: POST
Inputs: executionId as path parameter
Sample Request
http://localhost:7001/jos-batch-job-admin/resources/batch/jobs/executions/2
Inputs
jobName as path parameter
jobExecutionId as path parameter
Sample Request
http://localhost:7001/jos-batch-job-admin/resources/batch/jobs/ShellCommandRunnerJob/1
System Setting Service
See Appendix D for details about System Setting Service.
The Job Admin UI provides functionality to manage and monitor jobs. The Job Admin UI is described in detail in Appendix G.
Best practices include:
Use Batchlet if a job must run a script or program that resides locally.
Use ItemReader, ItemWriter, and so on, if a job requires more control over the processing of data. Chunk processing allows data to be processed in chunks, and, if a job fails, it can only process the remaining chunks during a restart.
Use job parameters to dynamically pass parameters to a job.
Use PartitionMapper to specify the number of partitions and the threads for chunk processing so that all data is processed concurrently.
Both Job Admin UI and REST Services are secured with SSL and basic authentication. The following roles are defined to restrict access to operations in Job Admin.
JobAdminRole
JobOperatorRole
JobMonitorRole
Batch jobs can be run from the Job Admin UI or through the Batch REST service. Here are the operations that can be performed by the users based on their roles.
During the deployment of Job Admin, seed data is loaded to various tables. Seed data files are located in the jos-<app>-home/setup-data/dml folder. If seed data is changed, Job Admin must be reinstalled and redeployed. In order to load seed data again during the redeployment, the LOADSEEDDATA flag in the BDI_SYSTEM_OPTIONS table must be set to TRUE.
This section describes the Job Admin errors and troubleshooting.
Issue: Job Admin deployment can encounter this error if the database credentials are invalid:
Caught: javax.management.RuntimeMBeanException: java.lang.RuntimeException: weblogic.management.provider.EditFailedException: java.lang.NullPointerException
at weblogic.utils.StackTraceDisabled.unknownMethod()
Caused by: java.lang.RuntimeException: weblogic.management.provider.EditFailedException: java.lang.NullPointerException
1 more
Caused by: weblogic.management.provider.EditFailedException:
1 more
Caused by: java.lang.NullPointerException
1 more
Solution:
Undo all changes in the WebLogic domain session. Redeploy the application, setting up new credentials and verifying that the deployment has been successful.
Issue: Log files contain this exception:
oracle.wsm.common.sdk.WSMException: WSM-07620 : Agent cannot enforce policies due to either failure in retrieving policies or error in validations, detail= "WSM-02557 The documents required to configure the Oracle Web Services Manager runtime have not been retrieved from the Policy Manager application (wsm-pm), possibly because the application is not running or has not been deployed in the environment. The query "&(@appliesTo~="REST-CLIENT()")(policysets:global:%)" is queued for later retrieval.
Solution: Follow the BDI Installation guide and verify that the WSM- policy manager is configured for the admin server URL.
Open the WebLogic domain console and target the wsm-pm application to Admin Server. Bounce Admin server and verify that the wsm-pm application is in an active state.
Job Fails and Job Admin Log Files Contain No Details of the Failure
Issue: A job fails and the Job Admin log files contain no evidence of or details about the failure.
Solution: Examine the WebLogic server log files to identify the root cause of the job failure. A possible root cause is the improper data source configuration.
Job Admin UI Throwing Error: Job XML Not Found
Caused By: javax.ejb.EJBException: EJB Exception: : java.lang.RuntimeException: Could not find jobName(ShellCommandRunnerBatchlet) xml file. You may have renamed the job file or your job repository has more jobs than your application. To resolve the issue either delete the job repository or add the correct job xml file to the app.
Solution: The job has been deleted from the jos-job-home before redeployment. Either add the missing job XML or delete the execution records of the job from the batch database.
Job Admin UI Throwing Error: Table or View Doesn't Exists
<Error> <javax.enterprise.resource.webcontainer.jsf.application> <BEA-000000> <Error Rendering View[/index.xhtml] javax.el.ELException: /index.xhtml @15,84 value="#{batchSummaryRequestBean.refreshPage}": javax.ejb.EJBException: EJB Exception: : com.ibm.jbatch.container.exception.PersistenceException: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
Solution: BatchInfrastructure database is not pointing to a valid schema. Check if the schema has the following tables: CHECKPOINTDATA, STEPEXECUTIONINSTANCEDATA, STEPSTATUS, EXECUTIONINSTANCEDATA, JOBINSTANCEDATA, JOBSTATUS. If not, then run the DDL:
$Oracle_Home/oracle_common/common/sql/wlsservices/batch/oracle/jbatch.sql
IO Exception or Permissions Issue On Running A Shell Runner Job
Issue: java.io.IOException: Cannot run program "./TestShell1.sh" (in directory "/u00/webadmin/16.1.0/Scripts"): error=13, Permission denied
Solution: Check if the script the job is running is present in the specified location or not.
Check if the required permissions are provided for running the script.
Missing Credentials Access Permission
Issue: Caused by: java.lang.RuntimeException: Cannot get the Credential Map with the specified appLevelKeyPartitionName(DEFAULT_KEY_PARTITION_NAME).at com.oracle.retail.integration.common.security.credential.CredentialStoreManager.getAllUserNameAliases(CredentialStoreManager.java:1171) ~[retail-public-security-api-16.1.0.jar:?]Caused by: java.security.AccessControlException: access denied ("oracle.security.jps.service.credstore.CredentialAccessPermission" "context=SYSTEM,mapName=DEFAULT_KEY_PARTITION_NAME,keyName=*" "read")
Solution: Verify weblogic.policy file. The credential access permissions should be added for the domain where the applications are deployed. Add the permissions and restart the Admin and managed server.
Issue: Caused by: java.lang.IllegalArgumentException: alias(processCallBackServiceUrlUserAlias) not found in the credential store.
Solution: Add the system credentials using the UI or REST service.
Issue: 2017-03-31T02:49:42,628 [Thread-132] DEBUG Logger$debug - Starting job: null/resources/batch/jobs/DiffGrp_Fnd_ExtractorJob 2017-03-31T02:49:42,658 [Thread-132] ERROR Logger$error$0 - Error calling activity. java.lang.NullPointerException: Cannot invoke method getBytes() on null object
Solution: Add the system options using the UI or ReST service.
