| Oracle® Retail Job Orchestration and Scheduler Implementation Guide Release 16.0.21 E88078-01 |
![]() Previous |
![]() Next |
The screenshots in this appendix are part of the Process Flow User Interface.
The Process Flow Live tab shows the details of the currently running processes. The first section shows the summary of all processes running in the system. The next section shows the list of all processes running since midnight. The last section shows the activity details of the selected process.
The Manage Process Flow tab is used to start a process flow, restart a failed process flow, view/edit a process flow, list the executions instances of a process flow, and view/edit the process flow configuration. A failed process flow instance can be restarted only if it is the latest failed instance and there are no successful executions after that.
The Process Flow Configurations tab is used to set skip/hold flags on activities in a flow.
The Launch Process Flow tab is used to start a process flow with the provided process parameters.
The Process Details tab displays process activities and configuration in a tabular form.
The Process DSL tab displays DSL for the selected process flow.
The Historical Process Flow Execution tab allows the user to look at the history of process flow executions. The user can specify a date, a time interval, and a process status. The application will list all the process flow executions matching the criteria. The user can select any of the flow to see the activities details of that execution instance. The page also provides the option to view the before and after values of all process variables for each activity.
The Manage Configurations tab allows to view, edit, and create system options. This page displays the list of system options of the application. The user can modify the value of the existing system options, create new system options, and delete the existing system options. The user must have admin privileges for editing and creating system options. A search option based on the system options name and value is also provided on this page.
