| Oracle® Retail Service Backbone Oracle® Retail Service Backbone Implementation Guide Release 16.0.21 E87022-01 |
![]() Previous |
![]() Next |
This chapter describes RSB paks.
Decorator paks contain the proxy and business service definitions of the services provided by the application. There is one pak for each application. Decorators are generated using Retail SOA Enabler (RSE) tool. The RSE tool uses the service definition xml file as input for generating the decorators. The generated decorator is included in the archive generated by RSE. The decorator paks are available as zip archives. The decorator paks of the applications in scope must be downloaded and copied into the specified directory in the service-assembly-home directory.
The list of all app service decorator paks in this release is given in Appendix A.
This is not currently used, it is a placeholder for future functionality.
RSB Functional Integration Flows are OSB integration services that are not decorators. Decorators have one proxy service and one business service tied to the proxy. Any other type of integration service should be placed under this category.
This pak contains the proxy service which serves as the router service for the incoming payload. Depending on the message family and message type of the incoming payload, the proxy service routes the service to appropriate decorators.
