| Oracle® Retail Oracle Retail Integration Console User Guide 16.0.21 E86912-02 |
![]() Previous |
![]() Next |
The following is an overview of the technical design of RIC product:
RIC is an ADF UI application.
RIC reads and uses the RIB and/or RSB configurations, if RIB and/or RSB are enabled.
RIC uses the WebLogic Diagnostic framework to forward all of the logs pertinent to RSB.
RIC summarizes and displays data collected by the RIB Integration monitoring and JMS monitoring services to display RIB run time information.
All RSB paks are created using the RSE tool. The tool includes instrumentation with OSB configurations.
The RSB instrumentation is asynchronously writing events to RSB schema.
RIC uses the RSB service activity schema and OSB instrumentation to present data and data summaries to the UI.
RIC directly integrates with the RRA/IG through context hyperlinks.
