8. Configuring JNDI name for HTTP Listener
- Click ‘WebLogic Domain’ on the right panel.
Select Security > Credentials.
- Click
‘Credentials’. The following window is displayed.
- Click
‘Create Map’. The following window is displayed.
- Enter
Map name as 'ofsll.http.listener.jndi'.
- Click ‘OK’. The following window is displayed.
- Click
‘Create Key’ Button. The following window is displayed.
- Enter
the followng details as per your requirement.
- Key: jndiname
- Credential: java:comp/env/jdbc/ofsllDBConnDS
- Type:Generic
