4. Creating Unique BI Publisher User
After configuring BI publisher, you must create a unique User ID.
To create User ID
- Login to BIP Domain (http://hostname:port/console).
- Click ‘Security Realms’ and then select ‘myrealm’.
- Select Users and Groups > User and click ‘New’.
The following window is displayed.
- Specify the following
details:
Field
Action
Name
Specify a valid name you
need to maintain as User
Description
Provide description to
the specified user
Provider
Select a provider for the
user, from drop-down list.
Password
Specify a valid password
you need to assign to the specified user.
Confirm Password
Retype the password to
confirm it.
- Click ‘OK’. The following window is displays
the new User ID created.
- Select the check
box adjacent to the ‘User’ created and click ‘Groups’
tab. The following window is displayed
- Select the following
Groups from the ‘Parent Groups Available’ list and click
‘>’ to assign it to the new user. You can also assign
other groups as required.
- Click ‘Save’. The User is mapped to the Group.
