6. Importing Reports to BI Publisher Server
To import reports to BI Publisher Server, do the following:
- Copy and extract the OFSLLReports.zip file to local area.
Assume you have extracted to /home/oracle/app/OFSLLReports, then the
zip file “oracle.xdrz” is extracted to /home/oracle/app/OFSLLReports
- Launch the Oracle Business Intelligence Publisher Application
using http://hostname:port/xmlpserver
- Login with valid credentials.
- Following
window is displayed. Click on ‘Catalog Folders’ on the left
pane.
- Click on ‘Shared
Folders’ option and then click ‘Upload’.
- The following
window is displayed. Browse to the location where the oracle.xdrz file
is saved. Click the 'Overwrite Existing File' check box if you are overwriting
an existing directory.
- Click on ‘Upload’.
- The following
- Once the upload
is completed, click any folder to see the list of reports under the directory.
The following window is displayed.
