12. Application Documents
12.1 Introduction
The Documents Maintenance screen allow for paperless storage of documents within Oracle Financial Services Lending and Leasing system. Initially with the applications during the Line of credit origination cycle and later with accounts during customer service.
This chapter explains how to use the Application Document screen to:
It also explains how to use the Account Document Tracking screen to attach documents to accounts and then view these documents in a browser.
The Application Document screen consists of “Document Maintenance” and “Document Details” sections.
Credit applications are often sent or faxed to financial institutions from producers (or ‘dealers’) on behalf of the customer. These credit applications, if received as fax, can be stored in the system as images. Frequently, more than one application is received in a single fax or a single application is received across multiple faxes. In such cases, the Application Document Tracking screen can help you organize and maintain your image collection.
The Application Document screen’s Document Maintenance screen allows you to upload documents to an application in the form of GIF files, PDF files, DOC files, XLS files, and TXT files. The Document Maintenance screen’s Document Details section allows you to view these documents.
12.2 Application Document screen
Oracle Financial Services Lending and Leasing supports the online attachment of document images to an application using the Application Documents screen’s Document Maintenance section. You can attach the documents from either a client machine or server. A default image directory can be maintained in the system using the system parameter: UIX_DEFAULT_IMAGE_PATH.
When you choose List File in the Select Document sub section in the Document Maintenance section, the system displays all available files in the selected directory in the Document Details section. You can use the Document Maintenance sub-section and Action sub-section to attach selected documents to a particular account.
12.2.1 Attaching a Document to an Application from a server
To attach a document to an Application from a server
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Origination > Origination > Application Documents link.
  2. In the Action sub-section, click Attach Document (Server).
  3. In the Select Document sub-section, use the default image directory in the Directory Path field. (The default path is the value for the system parameter UIX_DEFAULT_IMAGE_PATH). -or-
  4. In the Directory Path field, specify the full path name to the document on the server that you want to attach to an account.
You can click Reset Path at any time to return to the default image directory.
  1. In the Select Document section, click List File.
    The system displays the files from the entry in the Select Document section Directory Path in the Document Maintenance record.
  2. In the Document Details record, select the record you want to work with and click Edit in the Details column.
  3. In the Document Details record, specify, view or edit the following information:
    Field:
    Do this:
    File Name
    View the file name for the document.
    Document Type
    Select the type for the document.
    Document Sub Type
    Select the sub type for the document.
    Application #
    Select the application number to attach/copy/move the docu­ment image.
    Attach
    Attach the document.
    Status
    View the status of the document.
    Tracking #
    Specify the tracking number of the document.
    Docket #
    Specify the docket number of the document.
    Location
    Specify the location of the document.
    Received Dt
    View the document image received date.
    Effective Dt
    Specify the effective date of the document.
    Expiry Dt
    Specify the expiration date of the document.
    Comment
    Specify any comments regarding the document.
  4. Select the Attach check box to attach the file to the account.
  5. Click Save And Return.
  6. In the Action sub-section, click Post.
    The system attaches the document to the application.
You can view the document in a browser by clicking View Document in the Document Details section.
12.2.2 Attaching a Document to an Application from a Client Machine
To attach a document to an application from a client machine
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Origination master tab.
  2. Click the Application Documents link.
  3. In the Action sub-section, click Attach Document (Client).
  4. In the Select Document section, click Browse in File to upload field.
    The system opens a Choose File to Upload dialog box.
  5. In the Choose File to Upload dialog box, locate the document you want to attach to the account. You can select multiple files by holding the Ctrl or Shift key on your keyboard.
  6. When you have located the document you want to attach to the account in the Open dialog box’s File name: field, click Open.
  7. The selected files appear in the Select Document sub-section’s File to Upload field.
  8. In the Select Document sub-section, click Upload.
  9. In the Document Details record, select the file uploaded from your server and click Edit.
  10. In the Document Details section, enter, view or edit the following information:
    Field:
    Do this:
    File Name
    Document Type
    Document Sub Type
    Application #
    Status
    Comment
    Tracking #
    Docket #
    Location
    Received Dt
    Specify the received date of the document.
    Effective Dt
    Expiry Dt
    Comments
  11. Select the Attach check box to attach the file to the account.
  12. Click Save And Return.
  13. In the Action sub-section, click Post.
You can view the document in a browser by choosing View Document in the Action section.
12.2.3 Copying a Document
The Action section’s Copy Document command copies the document image from one application to another application. This command has no impact on the source application or the source application’s document image.
To copy a document to an application from another application
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the origination master tab.
  3. In the Action sub-section, click Copy Document.
  4. In the Document Maintenance sub-section, use the Application # field to specify the application with the image you want to copy.
  5. In the Document Maintenance sub-section, click Search. The system displays the files attached to that application in the Document Details section.
  6. In the Document Details section, select the document you want to copy and click Edit.
  7. In the Copy/Move App # field, specify the application number of the application to which you want to copy the document.
  8. Click Save And Return.
  9. In the Action sub-section, click Post.
12.2.4 Moving a Document
The Action section’s Move Document command moves an existing document image from one application to another application. This command detaches the document image from the source application and attach to second application.
To move a document to an application from another application
  3. In the Action sub-section, click Move Document.
  4. In the Document Maintenance sub-section, use the Application # field to specify the application with the image you want to move.
    The system displays the files attached to that application in the Document Details sections.
  6. In the Document Details section, select the document you want to move and click Edit.
  7. In the Copy/Move App # field, specify the application number of the application to which you want to move the document.
You can view the documents attached to a particular account by loading the application on the Customer Service screen, then clicking the Customer Service tab and then clicking on the Document Tracking sub tab.
12.2.5 Viewing a Document Attached to an Application
To view a document attached to an application
  1. Using above method, load the application with the document you want to view.
  2. In the Application Document section, click Edit.
  3. View/edit the following display only information:
    Field:
    Do this:
    Document Type
    View the document type.
    Comment
    Specify any comments regarding the image.
  4. In the Application Document Details section, select the record you want to work with and click Edit.
  5. In the Application Document Details section, view the following display only information:
    Field:
    View this:
    Document Sub Type
    The document sub type.
    Version
    The version number. (version numbers will be incremental by batch job, first version will start with 1.0).
    Page #
    The page number.
    Document File Type
    The document file type.
    Status
    The status.
    Tracking #
    The tracking number of the image.
    Docket #
    The docket number of the image.
    Location
    The location of the of the image.
    Received Dt
    The effective date of the image.
    Effective Dt
    Expiry Dt
    The expiration date of the image.
    Comment
    Any comments regarding the image.
  6. Use the Application Document and Application Document Details sections to select the document you want to view.
    • In multiple paged documents, choose 1 in Page # field on Application Document Details section to view all the pages in the document.
-or-
    • Choose a specific page number to view only that page.
  1. Click View Document.
    The system opens a browser to display the actual document (which browser appears depends on what type of document you selected and what browsers are set up to work in conjunction with your Oracle Financial Services Lending and Leasing system).
  2. You can add comments to the Comments field in the Application Document and Application Document Details sections.
  3. Click Save And Return.
12.3 Document Tracking section
You can view the documents attached to a particular application by loading the application on the Underwriting/Funding screen and then clicking on Document tab.
12.3.1 Locating an Application Document
To locate an account document
  2. Click the Underwriting/Funding link.
  3. Select and open the application you want to work with.
  4. Click Document sub tab.
The Account Document screen appears.
Information about the documents attached to the Application appears in the Application Documents and Application Document Details sections.
12.3.2 Viewing a Document Attached to an Application
To view a document attached to an account
  1. Using the above method, load the account with the document you want to view.
    Field:
    Do this:
    Document Type
    Comment
    Field:
    View this:
    Document Sub Type
    Version
    The version number (version numbers will be incremental by batch job, first version will start with 1.0).
    Page #
    The page number.
    Document File Type
    Status
    The status.
    Tracking #
    Docket #
    Location
    Received Dt
    Effective Dt
    Expiry Dt
    Comment
  6. Use the Application Document and Application Document Details section to select the document you want to view.
-or-
  1. Choose View Document.
The system opens a browser to display the actual document (which browser appears depends on what type of document you selected and what browsers are set up to work in conjunction with your system).
  1. You can add comments to the Comments field in the Application Document and Application Document Details sections.
