2. Administration System
In Administration > System, you can record setup data related to the application’s overall functionality and performance. This data affects;
Navigating to Administration System
  1. On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > Administration > System
The System drop-down link records the following data:
Using these parameters, you can control the behavior of the system from a technical perspective. For example, determine parameter values, define what information is audited, and record default values. The product provides default values for all these screens.
2.1 System Parameters
System parameters define information or values used throughout the system. They act as switches that control the manner in which a function is implemented, or whether or not the system performs a particular task. Parameters are used throughout the system to control everything from user access to what information is stored on any given form. Parameters also define configuration data, such as the location of the system files, the URLs for the report and image servers, and other administration controlled data. Some of the system parameters are setup when the system is installed, but the values associated with the parameters need to be reviewed and maintained.
There are three types of parameters in the system, grouped by what part of the system they affect:
Parameter Type:
Parameter Range:
System parameters
These parameters apply to the entire system.
Examples: batch processes, archiving, aging.
Organization parameters
These parameters apply to the organization, division, and user responsibility.
Examples: User login control, password expiration.
Company parameters
These parameters apply to the company and branch.
Examples: decision fax control, scoring model.
Hence, the System Parameters screen contains the following three tabs:
2.1.1 System Parameters Setup
The System Parameters Setup screen displays and records each system wide parameter, along with its current value and whether or not it is enabled. These parameters relate to the overall processing of the system, such as application server file locations and data purging configuration.
To set up the System Parameters
  1. Click Setup > Setup > Administration > System > System Parameters > System. The system displays the System Parameter screen
  2. In the System Parameters section, perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field
Do this
Parameter
System parameter of the specified parameter description is dis­played here.
Parameter Description
Select the description of system parameter from the drop-down list.
Parameter Value
Specify the value for the system parameter (required).
Enabled
Check this box to enable the parameter.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
For a detailed list of available parameters, refer to Appendix “System Parameters” chapter.
2.1.1.1 FCUBS Integration
Oracle Financial Services Lending and Leasing (OFSLL) is integrated with Oracle FLEXCUBE Universal Banking System (FCUBS) with the capability to integrate the centralized CIF (Customer Information Files), ELCM (Enterprise Limits and Collateral Management) and CASA (Current Account and Savings Account) modules.
To work with the integrated environment functionalities, you need to enable the following core banking indicator.
Parameter
CMN_CORE_BANK
CORE BANKING INTERFACE INDICATOR
Note
Re-qualification is pending for Core and Direct Banking Integration.
For detailed information about integration changes, you can refer to ‘FCUBS Integration Documents’ section at OTN library (http://docs.oracle.com/cd/E59770_01/homepage.htm).
2.1.2 Organization Parameters
The Organization parameters control the system functions related to user log in, such as passwords and expiration dates, responsibility levels and the ability to access the system features. Individual parameters can be created with different values for uniquely defined organizations, divisions, and responsibility combinations.
When determining which parameter to use, the system selects the best match based on a hierarchical sort by the Organization, Division, and Responsibility fields, with values of ALL being a lower order match than an exact match.
For example:
Assume the organization parameter UIX_APP_VIEW_ALL_APPS (VIEW ALL APPLICATIONS) is as follows:
Note
Be aware that while the system allows for Organization parameters to be defined at all three hierarchical (organization, division, and responsibility) levels, not all will be applica­ble to each parameter. For example, while you can define the UIX_SMTP_SERVER (Email server for user) for a responsibility, you would normally want only to define this parameter based on organization or division.
To set up the Organization Parameters
  1. Click Setup > Setup > Administration > System > System Parameters > Organization tab.
  2. In the Organization Parameters section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Parameter
Parameter of the specified parameter description is displayed here.
Parameter Value
Specify the value for the system parameter.
Organization
Select the organization for which the parameter will be valid from the drop-down list.
Division
Select the department for which the parameter will be valid from the drop-down list.
Responsibility
Select the responsibility for which the parameter will be valid from the drop-down list.
IMPORTANT: In selecting which organization parameter to use, the system searches for a best match using the following attributes:
1. Organization
2. Division
3. Responsibility
Hence, Oracle Financial Services Software recommends creating a version of each organization parameter, where ALL is these fields.
Enabled
2.1.3 Company Parameters
The Company parameters control the system processes associated with functions that may vary for different companies or branches. These parameters address credit scoring, credit bureau interfaces, fax services, and fax generation. Individual parameters may be set up with different values for uniquely defined company and branch combinations.
When these parameters values are requested by the system, the system responds with the “best” match based on a hierarchical sort ordered on company and branch fields, with values of ALL being a lower order match than an exact match. For example, assume the company parameter UIX_RUN_AAI_ACT (online account creation and activation) has been defined as:
The system uses these two parameters to determine whether to create and activate an account online.
To set up the Company Parameters
  1. Click Setup > Setup > Administration > System > System Parameters > Company tab.
  2. On the Company Parameters screen, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Parameter
The system displays the parameter, when you select parameter description.
Parameter Value
Company
Select the portfolio company for which the parameter will be valid from drop-down list.
Branch
Select the portfolio branch for which the parameter will be valid from the drop-down list (required).
IMPORTANT: In selecting which company parameter to use, the system searches for a best match using the following attributes:
1. Company
2. Branch
For this reason, the Software recommends creating a version of each company parameter where ALL is the value in these fields.
Enabled
2.2 Lookups Setup screen
The Lookup Setups screen defines the contents in many drop-down fields used throughout the system. Fields that make use of drop-down field will accept only entries that are stored on this screen.
The Lookups screen contains two sections: Lookup Types and Lookup Codes. Lookup types and codes can be system-defined or user-defined. The lookup types describe the function of the related lookup codes.
For system-defined lookup types, only the Description field may be changed.
A system-defined lookup type (Lookup Types block, System Defined is selected) is one that is critical to the system and cannot be changed. However, you can still modify the lookup type description and Record indicator (Enabled/Disabled).
A user-defined lookup type (Lookup Types block, System Defined is not selected) is one that can be modified, depending on a user's business needs. You can modify the description, system indicator and record indicator. If a lookup type is user-defined, the lookup code belonging to that lookup type can either be system-defined or user-defined.
A system-defined lookup code (Lookups screen, System Defined is selected) is one on which the system processing is dependent. Without this lookup code, the process produces incorrect results or fails.
A user-defined lookup code (Lookups screen, System Defined is not selected) is one that can be defined or altered by a user.
WARNING: System-defined lookup types are those that are required by the system. Their related lookup codes will also be system defined. If you update and save a user-defined lookup type as a system-defined-lookup type (that is, change the System Defined button from No to Yes in the Lookup Type sub screen), the system will not allow you to change the lookup type back to user-defined in the future.
Note
Lookup codes cannot be deleted, as they may have been used in the past, and the display and processing of that data is still dependent on the existing setup.
Typically, the system Administrator would modify the descriptions of lookup codes and add new lookup codes to the existing lookup types as needed.
To set up the Lookups
  1. Click Setup > Setup > Administration > System > Lookups. The system displays the Lookups screen. The details are grouped into two:
  1. In the Lookup Types section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Lookup Type
Specify the lookup type.
Description
Specify the description for the lookup type .
System Defined Yes/No
Select ‘Yes’, if you wish to maintain the lookup type as system defined and ‘No’, if you wish to maintain lookup type as User defined.
Enabled
Check this box to enable the lookup type.
  2. In the Lookup Codes section, you can setup individual codes that a field or process using the related lookup type can have. Perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Lookup Code
Specify the lookup code. These are solely dependent on the function of the Lookup Type.
Description
Specify the lookup code description. This may be changed as per your business requirement.
Sort
Specify the sort order for the lookup code. This determines the order these lookup codes are displayed or processed.
Sub Code
Specify the sub code for the lookup code.
Select ‘Yes’, if you wish to maintain the lookup code as system defined and ‘No’, if you do not want to maintain it as system defined. System defined lookup codes cannot be modified, except for changing the Description or Sorting fields. If the lookup type is not system defined, then the code can be modified.
Enabled
Check this box to enable the lookup code.
2.3 User Defined Tables
In User Defined Tables you can maintain user-defined tables, such as the data attributes the system uses on its Search screens.
In the following example, the list of attributes in the Criteria column are computed from the User Defined Tables screen.
To set up a user-defined table, you must:
  1. Define the fields on the table.
  2. Join the related tables.
  3. Assign the table a lookup type.
You can create tables for different products, funding, and collateral types.
After creating the user-defined tables, the system sorts the attributes to make the system usage more efficient. These details are used with different functions of the system, including:
Note
Many of these tables, (Asset Tracking Attributes for example) may be configured during the initial setup of the application to provide for your specific business needs. Oth­ers, such as Application Search, may be changed whenever your business needs change. Still others should not be changed without consulting Oracle Financial Services Software, as changing them would require changes to existing code for the expected re­sults to be implemented. As a thumb rule, it is better to add or disable information on the User Defined Tables screen than to edit existing entries.
To set up the User Defined Tables
  1. Click Setup > Setup > Administration > System > User Defined Tables. The system displays the User Defined Tables screen. The details are grouped into two:
  1. In the User Defined Tables section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Table
Specify the user-defined table name.
User Table Type
Select the user-defined table type from the drop-down list. This determines where and how the related data is being used.
Description
Specify the description for user-defined table.
System Defined Yes/NO
Select ‘Yes’, if you wish to maintain the User table type as system defined and ‘No’, if you do not want to maintain it as system defined. System defined entries cannot be modified. If the entry is not system defined, then it can be modified.
Enabled
Check this box to enable the user-defined table (optional).
Product Type
Select the product typefrom the drop-down list.
Funding Type
Select the funding type associated with the user-defined table from the drop-down list.
Collateral Type
Select the collateral type associated with the user-defined table from the drop-down list.
View Name
Specify the view name.
SQL Statement
Specify the SQL version of the statement.
For Example: For SEARCH_ACC_ACCOUNTS table, the SQL is as follows:
SELECT /*+ FIRST_ROWS */ ACC_AAD_ID FROM ACCOUNTS WHERE
Note: For the above SQL, the where criteria is part of the User Defined Table Attributes
Sort
Specify the sort order for the user-defined table relative to other tables of the same type.
  2. In the User Defined Table Attributes section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Attribute
Specify the user-defined table attribute.
Description
Specify the description for the user-defined table attribute.
Data Type
Select the data type for the attribute (CHARACTER, NUMBER, or DATE) from drop-down list.
Length
Specify the maximum length of the user-defined table attribute.
Sort
Specify the sort order of the user-defined table attribute. If the sort order is changed it will only affect new instances of the User Defined Table, and will not affect existing data.
Operator
Select the operator for the user-defined table attribute from the drop-down list.
Select ‘Yes’, if you wish to maintain the User table attribute as system defined and ‘No’, if you do not want to maintain it as system defined. System defined entries cannot be modified. If the entry is not system defined, then it can be modified.
Enabled
Check this box to enable the user-defined table attribute so that the attribute will be considered when creating new instances of the User Defined Table.
Sub Attribute
Specify the sub-attribute for the attribute (sub attributes are used to associate related attributes).
LOV Type
Select the list of value (LOV) type for the user-defined table attribute from the drop-down list.
LOV Validation Ind
Check this box to enable LOV validation of the user-defined table attribute. This indicates whether the data must come from the LOV.
Lookup Types
Specify the lookup type of the LOV associated with the user-defined table attribute.
Default Value
Specify the default value for the user-defined table attribute.
2.4 Audit Tables
The system allows you to track changes in the database during loan origination. This includes the tracking of:
The Audit Tables Setup screen records the tables and columns requiring an audit. the system stores the following details for the fields you want to audit for changes:
IMPORTANT: The system recommends that only a database administrator perform the following steps.
To set up the Audit Tables
  1. Click Setup > Setup > Administration > System > Audit Tables. The system displays the Audit Tables screen. The details are grouped into two:
  1. In the Audit Tables section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Table
The table name on which audit trigger needs to be cre­ated is displayed here (the system table being audited).
Description
Specify the table description.
Display Description
Specify the column description to be displayed on audit screen.
Display Column
Select the table column to be displayed on audit screen from the drop-down list.
Enabled
Check this box to enable the audit table so that it will be considered while generating the database triggers.
Reset Row ID
Check this box to allow resetting the row identifier.
Primary Key 1 (unlabeled)
The table primary key column 1 is displayed here. (These columns define how to access the data in the table.)
Primary Key 2 (unlabeled)
The table primary key column 2 is displayed here.
Primary Key 3 (unlabeled)
The table primary key column 3 is displayed here.
Primary Key 4 (unlabeled)
The table primary key column 4 is displayed here.
Primary Key 5 (unlabeled)
Table primary key column 5 is displayed here .
Primary Key 6 (unlabeled)
Table primary key column 6 is displayed here.
Primary Key 7 (unlabeled)
The table primary key column 7 is displayed here.
Primary Key 8 (unlabeled)
The table primary key column 8 is displayed here.
Primary Key 9 (unlabeled)
The table primary key column 9 is displayed here.
Primary Key 10 (unlabeled)
The table primary key column 10 is displayed here.
Primary Key 11 (unlabeled)
The table primary key column 11 is displayed here.
Primary Key 12 (unlabeled)
The table primary key column 12 is displayed here.
Primary Key 13 (unlabeled)
The table primary key column 13 is displayed here.
Primary Key 14 (unlabeled)
The table primary key column 14 is displayed here.
Primary Key 15 (unlabeled)
The table primary key column 15 is displayed here.
  2. In the Audit Tables Columns section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Column
Specify the column name on which the audit needs to be created from drop-down list (column in the table that is being audited)
Description
Specify the column description (description of the data contained in the column).
Data Type
The data type for the attribute is displayed here.
Enabled
Check this box to enable the audit column.
2.5 Transaction Codes
The system uses transaction codes to define the actions and tasks it can perform; for example, activating an account, changing a due date, applying a late fee, and charging off an account.
The Transaction Codes Setup screen catalogs and defines these core system actions.
The system organizes transaction codes in ‘Super Groups’. All transaction codes within a particular super group are processed in a similar manner. The transaction super groups in the system are as follows:
Super Group Type:
Description:
ACCOUNT CONDITION TXN
These transaction codes control a user’s ability to open and close account conditions.
ACCOUNT MONETARY TXN
These transaction codes affect the monetary value of accounts in the system; for example, activating accrual of interest, the assessment of fees, and closing the account.
ACCOUNT NON MONETARY TXN
These transaction codes do not have a direct affect on the monetary value of the account, but are used in maintaining account information. This includes chang­ing a customer’s driving license, or adding information for automated clearing house (ACH).
AMORTIZATION TXN
These transaction codes affect the amortized balances of the accounts in the system.
CORRESPONDENCES
These transaction codes relate to the system corre­spondences.
ESCROW ANALYSIS AND DISBURSEMENTS
These transaction codes allow for reviewing and approving escrow analysis, stopping an escrow over­ride, and posting escrow disbursement.
ESCROW MONETARY TRANSACTIONS
These transaction codes affect the monetary value of escrow accounts in the system; for example, disburs­ing escrow to a customer and insurance, and receiving payment.
ESCROW NON MONETARY TRANSACTIONS
These transaction codes do not have a direct affect on the monetary value of an escrow account, but are used in maintaining account information, such as changing insurance maturity date and adding new escrow tax details.
FEE ASSESSMENTS
These transaction codes determine if fees such as nonsufficient funds fees or membership fees are to be applied.
FUNDING TXN
These transaction codes affect the funding of applica­tions and accounts within the system.
ITEMIZATION TXN
These transaction codes affect the itemization of appli­cations and accounts within the system.
menu TXN
These transaction codes affect the menus within the system.
PRODUCER MONETARY TXN
These transaction codes relate to the monetary trans­actions that apply to the the system producers (or “dealers”).
reports
These transaction codes are related to generating the system reports.
SECURITIZATION TXN
These transaction codes affect the pools of securitized loans or accounts within a pool of securitized loans.
SETUP LOCK/UNLOCK
These transaction codes limit a user’s ability to change the existing setup data, even if they are allowed access to the form, by restricting access to the Lock/Unlock Record icon on the the system tool bar.
Three sub screens, Transaction Parameters, Access Grid, and Transaction Product Definition, record any additional information required to perform a transaction, the user types that can perform the transaction, and the product type to which the transaction codes apply.
Note
The Software recommends that you restrict the access to the seed data once you are in production.
To set up the Transaction Codes
  1. Click Setup > Setup > Administration > System > Transaction Codes. The system displays the Transaction Codes screen.
  2. In Transaction Super Group section, you can view the following information
Field
Do this:
Super Group
Select the Super Group you want to work with in the Transaction Codes screen.
  2. In the Transaction Codes section, perform any of the Basic Operations mentioned in Navigation chapter
Field
Do this:
Txn Code
Specify the transaction code (required).
Description
Specify the description for the transaction.
Group
Select the transaction group (the group within the Transaction Super Group that the transaction code belongs to) from the drop-down list.
Action
Select the action type code for the transaction (what action will take place when the transaction occurs) from the drop-down list.
Monetary
Check this box to maintain the transaction as a monetary transaction. If unchecked, then the transaction is nonmonetary.
Select ‘Yes’, if you wish to maintain the transaction code as system defined and ‘No’, if you do not want to maintain it as system defined. System defined entries cannot be modified. If entry is not system defined, then it can be modified.
Enabled
Check this box to enable the transaction.
Txn/Bal Type
Select the transaction / balance type affected by the Transaction from the drop-down list.
Statement Txn Type
Select the statement transaction type (how the transaction should appear on the customer statement) from the drop-down list.
Batch
Check this box to perform the transaction in a batch process.
Manual
Check this box, if the transaction is a manual transaction. If you define a transaction as manual, the system recommends that the transaction that reverses it also be defined as manual.
Stmt Print
Check this box to print the transaction on customer statements.
GL
Check this box, if the transaction is a general ledger transaction.
2.5.1 Transaction Codes sub screens
The Transaction Codes screen contains three sub screens:
Note
Please contact your System Administrator / Implementation Manager before making any changes in these sub screens.
2.5.1.1 Parameters
Here, you can define the parameter information for the associated transaction.
Note
Treat the Transaction Parameters sub screen as containing view-only information. This is very sensitive data and you should not change it without consulting Oracle Financial Ser­vices Lending and Leasing.
To set up the Parameters
  1. Click Setup > Setup > Administration > System > Transaction Codes > Parameters.
  2. In the Transaction Parameters section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Parameter Code
Select the parameter code associated with the transaction code, from the drop-down list.
Default
Specify the default value for the transaction parameter (value to initially populate, or used if no value is supplied).
Sort
Specify the sort order for the transaction parameter.
Displayed? Yes/No
Select ‘Yes’ to display the parameter and ‘No’ if you do not want to dis­play in current use.
Required? Yes/No
Select ‘Yes’ if the parameter is required and ‘No’ if you do not require the parameter. (You must select Required as empty values are not allowed.)
2.5.1.2 Access Grid
The Access Grid sub screen allows you to control access to each transaction according to user responsibility, account status, and account condition. It allows the administrator to control when these transactions may be conducted. Normally, you would create or modify the access based on either the user responsibility or account condition. Account status access is left unchanged.
To set up the Access Grid sub screen
  1. Click Setup > Setup > Administration > System > Transaction Codes > Access Grid.
  2. In the Transaction User Access Definition section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Access Type
Select the access grid function type (ACCOUNT CONDITION and ACCOUNT STATUS) that is being used to control the creation of the associated transaction, from the drop-down list.
Access Value
Select the access function grid value from the drop-down list (based on a lookup associated with the Access Type. Multiple entries for each access type may be created as long as each has a different access value).
Allowed? Yes/No
Select ‘Yes’ if the access is allowed and ‘No’ if the access is not allowed (indicates whether the current Access Type / Access Value may create the associated transaction).
Select ‘Yes’, if you wish to maintain access type as system defined and ‘No’, if you do not want to maintain it as system defined. System defined entries cannot be modified. If entry is not system defined, then it can be modified.
2.5.1.3 Products
The Products sub screen allows you to define the products to which the transaction codes apply. It allows the administrator to control if the associated transaction code will be available for use for specific product types and or funding types.
Normally, an Access Value of ALL is defined for one or more Access Types with a given Allowed value. Additional Access Values are then defined for the same Access Types with the opposite Allowed value. This controls access to the associated transaction.
To set up the Products sub screen
  1. Click Setup > Setup > Administration > System > Transaction Codes > Products.
  2. In the Transaction Product Definition section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Product Type
Select the product type associated with the transaction code from the drop-down list.
Funding Type
Select the funding type associated with the transaction code from the drop-down list.
Allowed? Yes/No
Select ‘Yes’ if the transaction is allowed and ‘No’ if the transaction is not allowed (indicates whether the current Access Type / Access Value may create the associated transaction).
2.6 Data Files
The Data Files Setup screen organizes information pertaining to the various input/output data files that the system can generate. The system uses the Data Files Setup screen to outline the file layouts of each data file produced/received within the system, including the length and data type of each column name.
These files are typically produced during the nightly process.
One major advantage for the system-defined data files is the format mask of each column name within each data file. A format mask is like a stencil that forces data input to be of the same format before accepting the data.
You can change the order in which the fields are displayed in the file.
Note
Any addition or removal of a field or change in the data type length requires the Software involvement.
Data Files screen consists of the following two tabs:
2.6.1 Output tab
The Output tab in the Data Files screen allows you to define the structure of output data file through the following sections:
2.6.1.1 Data File Definitions
The Data File Definitions section defines specific data files. Each is associated with a specific Output Data Definition (ODD) batch job that gathers the data that the file will contain. While new data file definitions may be created they will have no use unless a batch job is also created to populate the data.
To set up Data File Definitions
  1. Click Setup > Setup > Administration > System > Data Files > Outpout tab.
  2. In the Data Files Definitions section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Name
Specify data file type (name of data file definition).
Description
Specify data file description.
File Name
Specify data file name. Prefix used for files generated for this Data File. This is the only field on the Data File Definitions screen that can or should be modified by your Administrator. The generated file name will be in the form of <File Name>_<Company ID>_<Branch ID>_<MMDDYYYY>_<Process ID>.dat. The inclusion of _<Com­pany ID> and _<Branch ID> depends entirely on the associated batch process.
Directory Path
Specify the directory path.
Select ‘Yes’, if you wish to maintain the data file definition as system defined and ‘No’, if you do not want to maintain it as system defined. System defined entries cannot be modified. If the entry is not system defined, then it can be modified.
Enabled
Check this box to enable the data file definition.
2.6.1.2 Record Definitions
Each data file definition is made up of one or more record definitions. These define organization of the data. The associated batch file determines how these records are used. The order in which the data is populated determines the order in which those records will appear in the output file. This is generally related to the order the records appear in the Data File Definition section.
  1. In the Record Definitions section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Record Type
Specify the type of record being defined.
Description
Specify record description.
Record Format
Select the format of output data (FIXED, VARIABLE) from the drop-down list.
Delimiter
Specify the delimiter (column separator used with VARIABLE for­mat).
Terminator
Select the record terminator code (how the end of each record is indi­cated within the file -- CARRIAGE RETURN, LINE FEED, or CAR­RIAGE RETURN AND LINE FEED) from the drop-down list.
2.6.1.3 Column Definitions
Each record definition is made up of one or more column definitions. These define the output of the data. Much of this data is informational; it indicates what data is being provided by the associated batch job. Unless otherwise noted, the data should not be changed without changing the associated batch job.
  1. In the Column Definitions section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Seq
Specify the order in which the output data dump will process the col­umn information.
Column Name
Specify name/description of the column (informational only).
Data Type
Specify the data type. This describes the type of data the column is expected to contain (CHARACTER, DATE, or NUMBER). This effects how the ODD process handles the data, and should not be changed .
Format Mask
Select the format mask for the column from the drop-down list. For DATE or NUMBER columns, this field defines the output format of the data. For example; Date fields may be entered using the MM/DD/YYYY format, Number fields may be entered as decimal numbers with varying degrees of precision. Other formats for each data type are available.
Length
Specify the column length (the maximum number of characters of the output data to be included in the output file). Each output data details column may contain up to 240 characters of data. If the output data details column contains more data than the length value the data will be truncated. For VARIABLE records the length should be set to “-1” or a Delimited file will be created with FIXED LENGTH columns.
Data Column
Specify the data column sequence. This is the column that will be used to select the data that is being output. This should not be changed.
Output Column
Specify the output column sequence. This is the column that will appear in Output File. The Output Data Dump process allows for the output of 250 columns of data per record. No output column should be repeated in the setup for a record.
2.6.2 Input tab
Oracle Financial Services Lending and Leasing facilitates processing of a input data file received from external interface into the system through an automated batch job (IDDPRC_BJ_000_01) triggered on regular intervals.
The Input tab in the Data Files screen allows you to define the input data file through the following sections:
2.6.2.1 Input Data File Definitions
In the Input Data File Definitions section, you can define and maintain the structure of input data file to populate data from external system.
To set up Input Data File Definitions
  1. Click Setup > Setup > Administration > System > Data Files > Input tab.
  2. In the Input Data Files Definitions section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Name
Specify a unique name for the input data file.
Description
Directory Path
Specify the directory path configured within OFSLL Database server to process the input data file.
Delimiter
Specify the delimiter used to separate column data. (Ex: Comma).
Record Format
System defaults the record format as ‘VARIABLE’.
Enabled
Check this box to enable the input data file definition.
2.6.2.2 Column Definitions
Each input data file definition is made up of one or more column definitions. These define the structure of data to be loaded from external system.
Field
Do this:
Seq
Specify the order in which the input data dump will process the col­umn information.
Column Name
Specify name of the column.
Column Description
Specify description of the column.
Data Type
Select the data type from the drop-down list. The selected data type describes the type of data the column is expected to contain such as INTEGER/DATE/NUMBER/CHARACTER. This effects how the input data file processing handles the data, and should not be changed.
Format Mask
Select the format mask for the column from the drop-down list. The list displays the format depending on the Data Type selected.
For example; Date fields may be entered using the MM/DD/YYYY format, Number fields may be entered as decimal numbers with var­ying degrees of precision. Other formats for each data type are avail­able.
Length
Specify the column length (the maximum number of characters of the data to be included in the input file).
Each input data details column may contain up to 240 characters of data. If the output data details column contains more data than the length value the data will be truncated. For VARIABLE records the length should be set to “-1” or a Delimited file will be created with FIXED LENGTH columns.
Sort
Specify the order in which the column definitions are to be sorted for display in the external interface screen (Customer Service > External Interfaces). There can be a maximum of 61 column definitions.
Enabled
Default selected. If not, you can check this box to enable the column definition.
2.7 Events
During account processing, when an account moves from one status/sub status to another, or changes condition, the system can trigger an event and perform the associated event actions. This can occur either online or in batch mode.
Note
Only predefined events and actions can be set up on the Events Setup screen. You cannot create new event types or action types.
As processing events and associated actions require additional processing at the server level, the performance of the transactions, for which the events are setup, may be adversely affected dependent upon your specific configuration.
2.7.1 Events
In the Events screen you can setup “trigger events” with associated actions which the system performs during account processing. The fields on this form are both system and user defined. There are four sub screens on the Events screen to set up and maintain these events:
Event Types and Action Types sections of this screen provide a master table for setting up the online and batch events. This setup triggers the event, which in turn triggers the actions associated with the events, during account processing.
Navigating to Events
  1. On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > Events.
2.7.1.1 Event Types
  1. Click Setup > Setup > Administration > System > Events > Line of credit > Events Types.
  2. In the Events Type section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Event Type Code
Specify the event type code.
Description
Specify the event description.
Process Type
Specify the process type (BATCH or ONLINE) from the drop-down list.
Entity Type
Specify the entity type (ACCOUNTS or APPLICATIONS) from the drop-down list.
Engine Type
Specify the engine type (MONETARY TRANSACTIONS PRO­CESSING, NON-MONETARY TRANSACTION PROCESSING, CONDITION/ASSIGNMENT PROCESSING, APPLICATION STA­TUS CHANGE, CREDIT BUREAU PROCESSING, LETTERS PROCESSING or CORRESPONDENCE) from the drop-down list.
Enabled
Check this box to activate the event type.
System Defined
Select ‘Yes’ to indicate that the event type is system define. Select ‘No’ to indicate that the event type is user defined.
2.7.1.2 Event Action Type
The Event Action Types section is system defined and lists the action codes supported in the system.
  1. Click Setup > Setup > Administration > System > Events > Line of credit > Event Action Types.
  2. In the Events Action Types section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Action Code
Specify the action code.
Description
Specify the action description.
Process Type
Select the process type (BATCH or ONLINE) from the drop-down list.
Entity Type
Select the entity type from the drop-down list.
Engine Type
Select the engine type from the drop-down list.
Enabled
Check this box to activate the action.
System Defined
2.7.1.3 Online
The Online screen allows you to set up the online events by defining all online events and the event criteria actions. The system supports the following online events:
  1. A change in account’s status. the system processes the event's actions when the:
  1. The opening or closing of an accounts conditions. The system processes the event’s actions when the:
  1. The posting of a non-monetary transaction to the account.
The events that can be performed online after each of the events listed above are as follows:
To setup Online Event
  1. Click Setup > Setup > Administration > System > Events > Line of credit > Online.
  2. In the Events section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Event Code
Specify the event code.
Event Type
Specify the event type from the drop-down list.
Frequency
Specify the event frequency from the drop-down list.
Synchronous
Check this box to set the event as synchronous (any failure in trigger­ing the event will fail to trigger the entire transaction). If unchecked, then the event is asynchronous (any failure in the event will not affect the transaction, which will be successfully completed).
Enabled
The Event Criteria section allows you to name and describe the query for an event, as well as enable or disable the query.
  1. In the Event Criteria section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Query Name
Specify the query name.
Description
Specify the query description.
Enabled
Check this box to activate the event criteria.
Criteria Details
The Criteria Details sub screen allows you to define the selection criteria for the event. The event engine uses these criteria to determine which account to include in the event action.
  1. In the Setup > Setup > Administration > System > Events > Line of credit > Online > Criteria section, you can define the event selection criteria. Perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Seq
Specify sequence numbers.
Specify left bracket.
Parameter
Select the parameter from the drop-down list.
Comparison Operator
Select comparison operator from the drop-down list.
Criteria Value
Specify criteria value.
Specify right bracket.
Logical Expression
Specify logical operator from the drop-down list.
Actions
The Actions section records the actions the system performs after the event is triggered.
  1. In the Setup > Setup > Administration > System > Events > Line of credit > Online > Action section, define the action you want the system to perform for the event by entering the following information. (You can set up more than one event action for a particular event, then use the Seq field to define the order in which the events will occur)
Field:
Do this:
Description
Select the event action description from the drop-down list.
Seq
specify sequence number.
Enabled
Check this box to activate the event action.
  2. For each event action, use the Action Parameters section to set up the required action parameters and values. Perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Description
Specify the parameter description from the drop-down list.
Value
Specify parameter value.
2.7.1.4 Batch
The Batch screen allows you to set up the events performed as a batch transaction by the system. The system supports the following predefined batch events for account processing. (These batch events are listed in the Events Types section on the Setup screen):
To setup the Batch Event
  1. Click Setup > Setup > Administration > System > Events > Line of credit > Batch.
Field:
Do this:
Event Code
Event Type
Frequency
Synchronous
Check this box to set the event as synchronous (any failure in triggering the event will fail to trigger the entire transaction). If unchecked, then the event is asynchronous (any failure in the event will not affect the transac­tion, which will be successfully completed).
Enabled
The Events Criteria section allows you to name and describe the query for an event, as well as enable or disable the query.
  1. In the Events Criteria section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Query Name
Description
Enabled
Criteria Details
  1. In the click Setup > Setup > Administration > System > Events > Line of credit > Batch > Criteria section, you can define the event selection criteria. Perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Seq
Parameter
Comparison Operator
Criteria Value
Logical Expression
Action
The Action sub screen allows you to define the actions performed in the batch event. The system supports the following batch event actions:
  1. Click Setup > Setup > Administration > System > Events > Line of credit > Batch > Action.
  2. In the Actions section, define the action you want the system to perform for the event by entering the following information. (You can set up more than one event action for a particular event, then use the Seq field to define the order in which the events will occur.) Perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Description
Select the event action from the drop-down list.
Seq
Specify sequence numbers (required).
Enabled
Field:
Do this:
Description
Value
2.7.1.5 Monitoring Events
You can verify the status of events and event actions on the Monitor Jobs screen of the Utilities form.
To monitor events
  1. On the Oracle Financial Services Lending and Leasing home screen, click Dashboard > Dashboard > System Monitor > Jobs > Back Ground.
The system displays the status for all asynchronous events that have been completed or failed for an account.
For further details, on monitoring events refer Dashboard Chapter of this Guide.
2.8 Batch Jobs
“Batch jobs” refer to the back-end processes that automatically run at a certain time. There are two types of batch jobs:
2.8.1 Batch Jobs
The Batch Job screen allows you to set up, monitor, and maintain batch jobs in the system.
Batch jobs can be set up to be performed on a daily, weekly, monthly, and ad-hoc basis. Batch jobs can also be configured to trigger an e-mail or phone message if a batch job fails.
Critical batch jobs control job flow and system date rollover to allow recovery during errors. Errors are instances where a process did not successfully complete. Failures indicate that a particular job encountered errors that require remedial action. The number of errors allowed before failure is defined for each job. Some errors automatically result in a failure.
Navigating to Batch Jobs:
  1. On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > Administration > System > Batch Jobs. The Batch Jobs details are further grouped into two tabs:
2.8.1.1 Batch Jobs
In the Batch Job Setup screen, you can track and maintain all batch processes within the system. Using this form, the system administrator can configure the frequency and start time of each batch process, as well as set the number of threads to improve performance.
“Threading” allows a specific job to be separated into smaller units that are processed at the same time. This allows Oracle Financial Services Lending and Leasing to complete the job in less time.
You can set up multiple batch jobs within a batch set. In the Batch Job Sets section, each process is listed with the last run date (Last Run Dt field) and the next scheduled process date (Next Run Dt field). In the Freq Code and Freq Value fields, you can determine the frequency of each batch set, such as daily, weekly and monthly. You can also set up batch sets to incorporate a dependency on another batch set. This way, if the initial batch fails, the dependent set will not be processed.
In the Batch Jobs section, you can configure the process to run on weekends and holidays using the respective option boxes.
CAUTION: As the batch job setup widely affects the Oracle Financial Services Lending and Leasing system, Oracle Financial Services Software suggests that the system administrator has a clear understanding of the various functionalities within Oracle Financial Services Lending and Leasing before creating and updating the batch processes.
For the standard job set please review the Visio document, dbk_std_detail_design_job_sets.vsd
To setup a Batch job
  1. Click Setup > Setup > Administration > System > Batch Jobs.
  2. In the Batch Job Sets section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Set Code
Specify the code for the batch job set.
Job Set Description
Specify the description for the batch job set.
Frequency
Select the frequency at which the job set is to be executed from the drop-down list.
Frequency Value
Select the frequency value from the drop-down list. The fre­quency value will be displayed based on the frequency code selected.
Start Time
Specify the start time for the job set.
Critical
Check this box to set job as critical. A “critical” job is one that prevents the General Ledger (GL) post date from rolling for­ward, should the job fail.
Enabled
Check this box to enable the job set.
Last Run Dt
The system displays the last run date of the job set.
Next Run Dt
Specify the next run date for job set. You can select the data from adjoining calendar icon.
Parent
Select the parent job set from drop-down list.
Dependency
Select the type of dependency on the parent from drop-down list.
  2. In the Batch Job section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Seq
Specify the batch job sequence number.
Note: Within a job set, jobs are executed sequentially based on the sequence number assigned.
Job Type
Select the batch job request type from the drop-down list.
Job Code
Specify the batch job request code.
Job Description
Specify the batch job description.
Threads
The system displays the number of threads used by the job.
Commit Count
Specify the number of rows after which auto-commit is triggered.
Errors Allowed
Specify the number of errors allowed.
Weekend
Check this box to perform batch jobs on weekend.
Holiday
Check this box to perform batch jobs on a holiday. (Holidays are defined on the Job Holidays screen.)
Enabled
Check this box to enable the batch job.
Parent
Select the parent batch job from the drop-down list.
Dependency
Select the dependency clause of the batch job from the drop-down list.
Command
Specify the command line for the job (required).
RollbackSegment
If you choose, use this field to specify the rollback segment for job.
  2. In the Batch Job Thread section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Thread
Specify the name of thread.
Trace
Specify the SQL trace level (0, 1, 4, 8, 12). The higher the number, the more activities the system can trace.
Enabled
Check this box to enable the thread.
2.8.1.2 Job Holidays
The system allows you to define holidays within the company on Job Holidays screen. You can then use the Batch jobs screen to set up whether you want the system to perform batch jobs on these days or not, using the Holiday box of Batch Jobs section .
To define job holidays
  1. Click Setup > Setup > Administration > System > Batch Jobs > Job Holidays.
  2. In the Job Holidays section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Holiday Dt
Specify the date of the job holiday. You can select the date from the adjoining calendar icon.
Description
Specify the job holiday description (required).
Enabled
Check this box to enable the holiday.
2.8.2 Batch Jobs Available
The below table provides a list of Batch Jobs maintained in the system and a brief description to each:
Engine Type
Description
Batch Job
Description
Origination
Servicing
Collection
Product Type
Comment
AAE
Application Account Interface
aaiprc_b­j_100_01
APPLICA­TION TO ACCOUNT INTERFACE
No
Yes
No
Common
This process peri­odically picks up applications in 'Approved-Veri­fied' status and creates accounts.
ACH
ACH Accounts
acaprc_bj_100_01
ACCOUNT ACH PRO­CESSING
No
Yes
No
Common
This process pro­duces the ACH file for the eligible cus­tomer payments.
ACH
ACH Produc­ers
acp­prc_b­j_100_01
PRO­DUCER ACH PRO­CESSING
Yes
Yes
No
Common
This process pro­duces the ACH file for the eligible pro­ducer payments.
ACH
ACH Ven­dors
acvprc_bj_100_01
VENDOR ACH PRO­CESSING
No
Yes
No
Common
This process pro­duces the ACH file for the eligible ven­dor payments.
ACH
ACH Pro­ducer/Ven­dors/Customer/Third Party
acx­prc_b­j_100_01
Yes
Yes
No
Common
This process pro­ducers the ACH file for the eligible Producer/Vendors/Customer/Third Party
AGE
Aging Appli­cations
agaap­p_b­j_100_01
APPLICA­TION AGING PROCESS
Yes
No
No
Common
This process puts applications into 'Aged-Application' substatus.
AGE
Aging Con­tracts
agcco­n_b­j_100_01
CON­TRACT AGING PROCESS
Yes
No
No
Common
This process puts contracts into 'Aged-Contract' substatus.
ALT-PFS
ALLOT­MENT EXTRACT FILE DUMP
PFSEFT­PRC_B­J_111_01
BACKUP EFT
No
Yes
No
Common
This process cre­ates the Backup EFT file
ALT-PFS
PFSL­BAPRC_BJ_100_01
POSTING ALLOT­MENT PAY­MENTS
No
Yes
No
Common
This process posts the payments from the allotment file received from the bank
ALT-PFS
PFSOD­DALT_B­J_100_01
No
Yes
No
Common
This process sends the allot­ment draft notice to the bank
ALT-PFS
PFSNS­FPRC_BJ_100_01
NSF BATCH
No
Yes
No
Common
This process posts the NSF file received from the bank
API
API Accounts
accaa­i_b­j_100_01
API AAI
No
Yes
No
Common
This process cre­ates accounts from validated conver­sion applications/contracts
API
API Accounts
accd­mp_b­j_100_01
MOVE API_XX TO ITABS
No
Yes
No
Common
This process cop­ies data from con­version API tables to conversion applications table
API
API Accounts
accval_bj_111_01
VALIDATE ITABS (LOAN)
No
Yes
No
Loan
This process vali­date all conver­sion applications loan accounts by running the edits
API
API Accounts
accval_bj_112_01
VALIDATE ITABS (LINE)
No
Yes
No
Line
This process vali­date all conver­sion applications line of credit accounts by run­ning the edits
API
API Accounts
acm­prc_b­j_100_01
LOAD API_COM­MENTS
No
Yes
No
Common
This process cre­ates account com­ments from conversion appli­cations/contracts
COL
Appointment Cancellation
cap­prc_b­j_100_01
APPPOINT­MENT CAN­CEL PROCESS­ING
No
Yes
Yes
Common
This process can­cels all the expired appointments.
COL
Payment Promise Pro­cessing
cppprc_bj_100_01
BROKEN PROMISE PROCESS­ING
No
Yes
No
Common
This process updates any bro­ken promises as of the run time.
CRB
Credit Bureau Reporting
cbuutl_b­j_100_01
CREATE METRO2 FILE
No
Yes
No
Common
This process cre­ates the METRO2 file for Credit Bureau reporting for the specified date.
DOT
Document Tracking Load
dolprc_b­j_000_01
ACCOUNT DOCU­MENT LOAD
No
Yes
Yes
Common
This process reads acct_doc_load directory. Attach the documents to specified accounts and move docu­ments to appropri­ate directory
DLX
Accounts Dialer Exclu­sion
ODX­PRC_B­J_100_01
ACCOUNTS DIALER EXCLU­SION
N
Y
Y
Common
This process gen­erates a dialer exclusion file with account details and checks if the maintained call action result entry is made on any account during the specified time interval.
GLP
GL Interface
gliprc_b­j_100_01
GL SUMMA­RIZATION
No
Yes
No
Common
This process sum­marizes GL trans­actions for the day.
GOV
Debt Report­ing IRS 1099A /1099C
gdraap_bj_100_01
IRS 1099-A PROCESS­ING
No
Yes
No
Common
This process gen­erates the 1099-A flat file for govern­ment reporting.
GOV
gdrcad_bj_100_01
IRS 1099-C PROCESS­ING
No
Yes
No
Common
This process gen­erates the 1099-C flat file for govern­ment reporting.
GOV
HMDA Reporting
ghr­prc_b­j_100_01
IRS HMDA PROCESS­ING
Yes
No
No
Common
This process gen­erates the HMDA flat file for govern­ment reporting.
GOV
Interest Reporting IRS 1098
girprc_b­j_100_01
IRS 1098 PROCESS­ING
No
Yes
No
Common
This process gen­erates the 1098 flat file for government reporting.
JOB
Scheduler
jsctst_b­j_000_01
Scheduler
Yes
Yes
Yes
Common
This process test the job scheduler
LBP
Lockbox
lbxprc_b­j_100_01
LOAD LOCKBOX PROCESS­ING
No
Yes
No
Common
This process loads any lockbox files available. This pro­cess can be set to run periodically throughout the day.
LNT
Lien Tracking
OFD­PRC_B­J_111_03
OUTPUT LIEN TRACKING FOR DATA CHANGE
N
Y
N
Common
This process gen­erates output file with changes in customer informa­tion such as Address/Phone no./Borrower/Co-borrower name.
LNT
Lien Tracking
OFD­PRC_B­J_111_04
OUTPUT LIEN TRACKING FOR VOID ACCOUNT
N
Y
N
Common
This process gen­erates output file for 'Void Accounts' to be sent to dealer track.
LTR
Collections Letter
lcolt1_b­j_100_01
GENERATE FIRST COL­LECTION LETTER
No
No
Yes
Common
This process gen­erates the first col­lection letter for eligible accounts.
LTR
Collections Letter
lcolt2_b­j_100_01
GENERATE SECOND COLLEC­TION LET­TER
No
No
Yes
Common
This process gen­erates the second collection letter for eligible accounts.
LTR
Collections Letter
lcolt3_b­j_100_01
GENERATE THIRD COL­LECTION LETTER
No
No
Yes
Common
This process gen­erates the third col­lection letter for eligible accounts.
LTR
Customer Service Let­ter
lcspdf_b­j_111_01
PAID IN FULL LET­TER
No
Yes
No
Loan
This process gen­erates the paid-in-full letter for the relevant accounts.
LTR
lcspo­q_b­j_111_01
PAYOFF QUOTE LETTER
No
Yes
No
Common
This process gen­erates the payoff quote letter for the requested accounts.
LTR
lcsst­m_b­j_100_01
CUS­TOMER STATE­MENT LET­TER
No
Yes
No
Common
This process gen­erates the cus­tomer statement letter for requested accounts.
LTR
lcswel_b­j_111_01
WELCOME LETTER
No
Yes
No
Loan
This process gen­erates the wel­come letter for the newly funded accounts.
LTR
Origination Letter
loraco_b­j_111_01
Origination Adverse Action Let­ter(Condi­tional) (Loan)
Yes
No
No
Loan
This process gen­erates the adverse action letter for rel­evant applications.
LTR
Origination Letter
loradv_b­j_111_01
Origination Adverse Action Let­ter (Loan)
Yes
No
No
Loan
ODD
Coupon Book Dump File
ocn­prc_b­j_100_01
CUS­TOMER COUPON BOOK GEN­ERATION
No
Yes
No
Common
This process gen­erates coupon books, if appropri­ate.
ODD
Output Data Dump File
odd­prc_b­j_000_01
CREATE OUTPUT DATA DUMP FILES
Yes
Yes
Yes
Common
This process cre­ates any defined output data dump files set in the sys­tem.
ODD
Collections Letter
olclt1_b­j_100_01
COLLEC­TION LET­TER 1 FILE CREATION
No
No
Yes
Common
ODD
Collections Letter
olclt2_b­j_100_01
COLLEC­TION LET­TER 2 FILE CREATION
No
No
Yes
Common
ODD
Collections Letter
olclt3_b­j_100_01
COLLEC­TION LET­TER 3 FILE CREATION
No
No
Yes
Common
ODD
Origination Letter
olo­aco_b­j_100_01
ADVERSE ACTION CONDI­TIONAL LETTER FILE CRE­ATION
Yes
No
No
Common
ODD
Origination Letter
oload­v_b­j_100_01
ADVERSE ACTION LETTER FILE CRE­ATION
Yes
No
No
Common
ODD
olspdf_b­j_100_01
PAID IN FULL FILE CREATION
No
Yes
No
Common
ODD
olspo­q_b­j_100_01
PAY OFF QUOTE FILE CRE­ATION
No
Yes
No
Common
ODD
ols­wel_b­j_100_01
WELCOME LETTER FILE CRE­ATION
No
Yes
No
Common
ODD
Producer Statement Dump File
opsprc_bj_100_01
DEALER STATE­MENTS GENERA­TION
No
Yes
No
Common
This process gen­erates the dealer/producer state­ments at the speci­fied frequency.
ODD
Customer Statement Dump File
ostprc_b­j_100_01
CUS­TOMER STATE­MENTS GENERA­TION
No
Yes
No
Common
This process gen­erates the cus­tomer statement for eligible accounts.
PRQ
Payable Requistion Customer
pcu­prc_b­j_100_01
CUS­TOMER REFUND PAYMENT REQUISI­TIONS
No
Yes
No
Common
This process cre­ates requisitions for customer over­payment refunds.
PRQ
Payable Requisition Producer
ppores_bj_100_01
MONTH END DEALER RESERVE PAYMENT REQUISI­TIONS
No
Yes
No
Common
This process cre­ates requisitions for dealer compen­sation payments on month-end.
PRQ
Payable Requisition Vendor
pvn­prc_b­j_100_01
VENDOR INVOICE PAYMENT REQUISI­TIONS
No
Yes
No
Common
This process cre­ates requisitions for vendor invoice payments
PUR
Archive Accounts
pacarc_bj_100_01
ARCHIVE ACCOUNT DATA TO OTABLES
No
Yes
Yes
Common
This process archives account data from ACCOUNTS table to OACCOUNTS table.
PUR
Archive Accounts
pacarc_bj_100_02
ARCHIVE ACCOUNT DATA TO OOTABLES
No
Yes
Yes
Common
This process archives account data from OAC­COUNTS table to OOACCOUNTS table.
PUR
Archive Applications
paparc_bj_100_01
ARCHIVE APPLICA­TION DATA TO OTABLES
Yes
No
No
Common
This process archives applica­tion-related data from APPLICA­TIONS to OAPPLI­CATIONS table.
PUR
paparc_bj_100_02
ARCHIVE APPLICA­TION DATA TO OOT­ABLES
Yes
No
No
Common
This process archives applica­tion-related data from OAPPLICA­TIONS to OOAP­PLICATIONS table.
PUR
Archive GL
pglarc_b­j_100_01
ARCHIVE GL DATA TO OTABLES
No
Yes
Yes
Common
This process archives General Ledger data from GL tables to OGL tables.
PUR
Archive GL
pglarc_b­j_100_02
ARCHIVE GL DATA TO OOTABLES
No
Yes
Yes
Common
This process archives General Ledger data from OGL tables to OOGL tables.
PUR
Purge Job Requests
pjrjrq_b­j_100_01
Purge Job Requests
Yes
Yes
Yes
Common
This process purges job requests from the system.
PUR
Purge Output Data Dump
pododh_bj_100_01
PURGE OUTPUT DATA HEADERS
No
Yes
Yes
Common
This process purges Output Data Headers from the system.
PUR
Archive Securitiza­tion
ppaarc_bj_100_01
ARCHIVE POOL DATA TO OTABLES
No
Yes
No
Common
This process archives securiti­zation data from TABLE to corre­sponding OTABLE.
PUR
ppaarc_bj_100_02
ARCHIVE POOL DATA TO OOT­ABLES
No
Yes
No
Common
This process archives securiti­zation data from OTABLE to corre­sponding OOT­ABLE.
PUR
Archive Pro­ducers
pprarc_bj_100_01
ARCHIVE PRO­DUCER DATA TO OTABLES
Yes
Yes
Yes
Common
This process archives producer data from PRO­DUCERS table to OPRODUCERS table.
PUR
Archive Pro­ducers
pprarc_bj_100_02
ARCHIVE PRO­DUCER DATA TO OOTABLES
Yes
Yes
Yes
Common
This process archives producer data from OPRO­DUCERS table to OOPRODUCERS table.
PUR
Archive Pro­ducers Txns
ppx­arc_b­j_100_01
ARCHIVE PRO­DUCER TXNS DATA TO OTABLES
No
Yes
No
Common
This process archives producer transaction data from PRODUC­ERS table to OPRODUCERS table.
PUR
ppx­arc_b­j_100_02
ARCHIVE PRO­DUCER TXNS DATA TO OOT­ABLES
No
Yes
No
Common
This process archives producer transaction data from OPRODUC­ERS table to OOPRODUCERS table.
PUR
Archive Statements
pstarc_b­j_100_01
ARCHIVE ACCOUNT STATE­MENT AND TXNS DATA TO OTABLES
No
Yes
No
Common
This process archives account statement and transaction data from TABLE to cor­responding OTABLE.
PUR
Archive Statements
pstarc_b­j_100_02
ARCHIVE ACCOUNT STATE­MENT AND TXNS DATA TO OOT­ABLES
No
Yes
No
Common
This process archives account statement and transaction data from OTABLE to OOTABLE.
PUR
Terminate User
ptuus­r_b­j_100_01
Terminate User
Yes
Yes
Yes
Common
This process termi­nates user satisfy­ing the selection criteria.
PUR
Archive Txns (To O tables)
ptxarc_b­j_100_01
ARCHIVE TXNS DATA TO OTABLES
No
Yes
No
Common
This process archives data from TXNS table to OTXNS table.
PUR
Archive Txns (To OO tables)
ptxarc_b­j_100_02
ARCHIVE TXNS DATA TO OOT­ABLES
No
Yes
No
Common
This process archives data from OTXNS table to OOTXNS table.
PUR
Purge User Logins
pululg_b­j_100_01
Purge User Logins
Yes
Yes
Yes
Common
This process purges user login data from the sys­tem.
PUR
Archive Ven­dor Assign­ments
pvaarc_bj_100_01
ARCHIVE VENDOR ASSIGN­MENTS DATA TO OTABLES
No
Yes
Yes
Common
This process archives vendor assignment data from TABLE to OTABLE.
PUR
pvaarc_bj_100_02
ARCHIVE VENDOR ASSIGN­MENTS DATA TO OOTABLES
No
Yes
Yes
Common
This process archives vendor assignment data from OTABLE to OOTABLE.
PUR
Archive Ven­dor Invoices
pviarc_b­j_100_01
ARCHIVE VENDOR INVOICES DATA TO OTABLES
No
Yes
Yes
Common
This process archives vendor invoice data from TABLEs to OTABLEs.
PUR
pviarc_b­j_100_02
ARCHIVE VENDOR INVOICES DATA TO OOTABLES
No
Yes
Yes
Common
This process archives vendor invoice data from OTABLEs to OOT­ABLEs.
QUE
Queue Cus­tomer Ser­vice
qcsprc_bj_100_01
CUS­TOMER SERVICE QUEUE PROCESS­ING
No
Yes
Yes
Common
This process cre­ates the customer service/collections queues
RDB1
RDB1 Accounts
racd­mp_b­j_100_01
Data Dump Accounts
No
Yes
Yes
Common
This process trans­fers the account data from (OLTP) Regular tables to Temporary T tables
RDB1
RDB1 Appli­cations
rapd­mp_b­j_100_01
LOAD APPLICA­TION RELATED DATA INTO T TABLES
Yes
No
No
Common
This process trans­fers the applica­tion data from (OLTP) Regular tables to Tempo­rary T tables
RDB1
RDB1 Asset Tracking
ratd­mp_b­j_100_01
LOAD ASSET RELATED DATA INTO T TABLES
No
Yes
No
Common
This process trans­fers the account asset data from (OLTP) Regular tables to Tempo­rary T tables
RDB1
RDB1 Bank­ruptcy
rbkd­mp_b­j_100_01
LOAD BANK­RUPTCY DATA TO T TABLES
No
No
Yes
Common
This process trans­fers the account bankruptcy data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB1
RDB1 Call Activities
rcad­mp_b­j_100_01
LOAD CALL ACTIVITIES DATA INTO T TABLES
No
No
Yes
Common
This process trans­fers the account call activity data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB1
RDB1 Defi­ciency
rchd­mp_b­j_100_01
LOAD DEFI­CIENCY DATA INTO T TABLES
No
No
Yes
Common
This process trans­fers the account deficiency data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB1
RDB1 Con­tracts
rcod­mp_b­j_100_01
LOAD CON­TRACT DATA INTO T TABLES
Yes
Yes
No
Common
This process trans­fers the account contracts data from (OLTP) Regular tables to Tempo­rary T tables
RDB1
RDB1 Reposses­sions
rfod­mp_b­j_100_01
LOAD REPO FORECLO­SURE DATA INTO T TABLES
No
No
Yes
Common
RDB1
RDB1 Pro­ducers
rprd­mp_b­j_100_01
LOAD PRO­DUCER AND ITS TXNS DATA INTO T TABLES
No
Yes
No
Common
This process trans­fers the producer and producer transactions data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB1
RDB1 Setup
rstd­mp_b­j_100_01
LOAD SETUP RELATED DATA INTO T TABLES
Yes
Yes
Yes
Common
This process trans­fers the setup data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB1
RDB1 Txns
rtxd­mp_b­j_100_01
LOAD TXN DATA INTO T TABLES
No
Yes
No
Common
This process trans­fers the account transactions data from (OLTP) Regu­lar tables to Tem­porary T tables
RDB2
RDB2 Accounts
racac­c_b­j_100_01
Load Reporting Tables Accounts
No
Yes
Yes
Common
This process trans­fers the account data from T tables to RDB tables
RDB2
RDB2 Accounts (Derived Fields)
rac­drv_b­j_100_01
Update Reporting Tables Accounts
No
Yes
Yes
Common
This process updates the codes with description for account RDB tables
RDB2
RDB2 Appli­cations
rapap­p_b­j_100_01
Load Reporting Tables Appli­cations
Yes
No
No
Common
This process trans­fers the applica­tion data from T tables to RDB tables
RDB2
RDB2 Appli­cations (Derived Fields)
rap­drv_b­j_100_01
Update Reporting Tables Appli­cations (Derived Fields)
Yes
No
No
Common
This process updates the codes with description for application RDB tables
RDB2
RDB2 Asset Tracking
ratase_bj_100_01
Load Reporting Tables Asset Tracking
No
Yes
No
Common
This process trans­fers the account asset tracking data from T tables to RDB tables
RDB2
RDB2 Asset Tracking (Derived Fields)
ratdrv_b­j_100_01
Update Reporting Tables Asset Tracking (Derived Fields)
No
Yes
No
Common
This process updates the codes with description for account asset tracking RDB tables
RDB2
RDB2 Bank­ruptcy
rbkab­d_b­j_100_01
Load Reporting Tables Bankruptcy
No
No
Yes
Common
This process trans­fers the account bankruptcy data from T tables to RDB tables
RDB2
RDB2 Call Activities
rca­cac_b­j_100_01
Load Reporting Tables Call Activities
No
No
Yes
Common
This process trans­fers the account call activities data from T tables to RDB tables
RDB2
RDB2 Defi­ciency
rchaof_bj_100_01
Load Reporting Tables Defi­ciency
No
No
Yes
Common
This process trans­fers the account deficiency data from T tables to RDB tables
RDB2
RDB2 Con­tracts
rco­con_b­j_100_01
Load Reporting Tables Con­tracts
Yes
Yes
No
Common
This process trans­fers the account contract data from T tables to RDB tables
RDB2
RDB2 Con­tracts (Derived Fields)
rcodrv_bj_100_01
Update Reporting Tables Con­tracts (Derived Fields)
Yes
Yes
No
Common
This process updates the codes with description for account contract RDB tables
RDB2
RDB2 Reposses­sions
rfoafr_b­j_100_01
Load Reporting Tables Reposses­sions
No
No
Yes
Common
This process trans­fers the account repossession data from T tables to RDB tables
RDB2
RDB2 Pro­ducers (Derived Fields)
rprdrv_b­j_100_01
Update Reporting Tables Pro­ducers (Derived Fields)
No
Yes
No
Common
This process updates the codes with description for producer and pro­ducer transactions RDB tables
RDB2
RDB2 Pro­ducers
rprpro_b­j_100_01
Load Reporting Tables Pro­ducers
No
Yes
No
Common
This process trans­fers the producer and producer transactions data from T tables to RDB tables
RDB2
RDB2 Setup
rststp_b­j_100_01
Load Reporting Tables Setup
Yes
Yes
Yes
Common
This process trans­fers the setup data from T tables to RDB tables
RDB2
RDB2 Txns
rtxdrv_b­j_100_01
Load Reporting Tables Txns
No
Yes
Yes
Common
This process trans­fers the account transaction data from T tables to RDB tables
RDB2
RDB2 Txns (Derived Fields)
rtxtxn_b­j_100_01
Update Reporting Tables Txns (Derived Fields)
No
Yes
Yes
Common
This process updates the codes with description for account transac­tions RDB tables
RED
Policy Cre­ation Batch Job
red­prc_b­j_100_01
Policy cre­ation for PII Data
Yes
Yes
Yes
Common
This process cre­ates data redaction policy for masking personal identifi­able information in UI.
SEC
Pool Sum­mary
ssm­prc_b­j_100_01
POOL SUM­MARY TABLE POPULA­TION
No
Yes
No
Common
This process popu­lates summary tables for all pools
SET-OVR
OVERPAY­MENT REALLOCA­TIONS
PFSTX­NOVR_BJ_100_01
No
Yes
No
Common
This process han­dles the overpay­ments/overages existing on an account
TPE
Earning/Amortization
tam­prc_b­j_100_01
AMORTIZA­TION TRANSAC­TIONS PROCESS­ING
No
Yes
No
Common
This process cre­ates the month-end interest accrual transac­tions on month-end.
TPE
tam­prc_b­j_111_01
MONTH END AMOR­TIZATION TRANSAC­TIONS
No
Yes
No
Loan
TPE
Escrow Non Monetary Transactions
tenbmt_bj_100_01
Escrow Non Monetary Batch Trans­actions
No
Yes
Yes
Common
This process posts escrow non mone­tary transactions in the background at the specified time interval.
TPE
Escrow Anal­ysis & Dis­bursements
tesanl_b­j_100_01
Escrow Analysis Posting
No
Yes
No
Common
This process posts all approved escrow analysis to the account
TPE
tesanl_b­j_100_02
Create batches for Customer Refund Requests
No
Yes
No
Common
This process cre­ates company branch wise batches for cus­tomer refund requests.
TPE
tesanl_b­j_100_03
Create Transaction of Customer Refund Requests
No
Yes
No
Common
This process popu­late customer refund request in respective batch created above
TPE
tesanl_b­j_100_04
Compute control totals for cus­tomer refund request batches
No
Yes
No
Common
This process popu­lates control totals for the bathes cre­ated for customer refund requests.
TPE
tesanl_b­j_100_05
Escrow compliance checking
No
Yes
No
Common
This process checks escrow­able account for compliance
TPE
tesds­b_b­j_100_05
Escrow dis­bursement posting & requisition creation
No
Yes
No
Common
This process posts processed escrow disbursement and creates requisi­tions.
TPE
Non Mone­tary Transac­tions
tnmb­mt_b­j_100_01
NON MON­ETARY TRANSAC­TIONS POSTING
No
Yes
Yes
Common
This process posts non monetary transactions in the background at the specified time interval.
TPE
Compensa­tion
tpr­com_b­j_111_01
Compensa­tion
No
Yes
No
Loan
This process cre­ates transaction for month-end pro­ducer compensa­tion
TPE
Statement
tprps­g_b­j_111_01
Producer Statement
No
Yes
No
Loan
TPE
txnacr_b­j_100_01
INTEREST ACCRUAL AND DELIN­QUENCY PROCESS­ING
No
Yes
No
Common
This process posts any payment batches open in the system. This process can be set to run periodically.
TPE
txnact_b­j_100_01
ACCOUNT ACTIVA­TION
No
Yes
No
Common
This job activates new accounts i.e. changes status from PENDING to ACTIVE.
TPE
txnad­v_b­j_112_01
Advance Posting
No
Yes
No
Line
This process posts any advance batches open in the system. This process can be set to run periodically.
TPE
txnan­n_b­j_100_01
ANNIVER­SARY PRO­CESSING
No
Yes
No
Common
This process car­ries out the anni­versary processing for eligible accounts
TPE
txnbmt_bj_100_01
MONE­TARY TRANSAC­TIONS POSTING
No
Yes
No
Common
This process posts monetary transac­tions in the back­ground at the specified time interval.
TPE
txnch­g_b­j_100_01
Chargeoff Processing
No
Yes
No
Common
This process charges off eligi­ble or scheduled for chargeoff accounts .
TPE
txncls_b­j_100_01
VOID/PAID ACCOUNT CLOSE PROCESS­ING
No
Yes
No
Common
This process closes void and paid off accounts.
TPE
txnddt_b­j_100_01
BILLING/DUE DATES PROCESS­ING
No
Yes
No
Common
This process cre­ates/updates the due dates for the accounts in the system.
TPE
txnfpd_b­j_100_01
FIRST PMT DEDUC­TION PRO­CESSING
No
Yes
No
Common
This process posts the first payment deduction pay­ment to the eligi­ble accounts.
TPE
txnfpr_b­j_111_01
FIRST PMT REFUND PROCESS­ING
No
Yes
No
Loan
TPE
txnltc_b­j_100_01
LATE CHARGE PROCESS­ING
No
Yes
No
Common
This process assesses late charge depending on the rules, for all accounts in the system.
TPE
txnmt­d_b­j_100_01
MONTH END PRO­CESSING
No
Yes
No
Common
This process popu­lates the month end balances and carries over the balances to next month.
TPE
txnp­mt_b­j_100_01
Payment Posting
No
Yes
No
Common
This process does the daily accrual and delinquency processing.
TPE
txn­prm_b­j_100_01
PROMO­TION END PROCESS­ING
No
Yes
No
Common
This process 'ends' the promotion on the account.
TPE
txn­prm_b­j_100_03
TLP PRO­MOTION CANCEL PROCESS­ING
No
Yes
No
Common
This process 'can­cels' the promo­tion on the account.
TPE
txnrat_b­j_100_01
RATE CHANGE PROCESS­ING
No
Yes
No
Common
This process changes the prev­alent rate on an account.
TPE
txn­sch_b­j_100_01
SCHEDULE FOR CHARGEDOFF PRO­CESSING
No
Yes
No
Common
This process puts the 'Schedule for Charge Off' condi­tion on eligible accounts.
TPE
txntip_b­j_100_01
TERMINA­TION PRO­CESSING
No
Yes
No
Common
This process puts the "Paid" status on eligible accounts
TPE
txnytd_b­j_100_01
YEAR END PROCESS­ING
No
Yes
No
Common
This process popu­lates the year end balances and car­ries over the bal­ances to next year.
LTR
CONDI­TIONAL ADVERSE ACTION LETTER
LORACO_B­J_100_01
CONDI­TIONAL ADVERSE ACTION LETTER GENERA­TION
Yes
No
No
Loan
LTR
LORAD­V_B­J_100_01
Yes
No
No
Loan
RPT
ACCOUNT LIST
ROPAC­C_EM_100_01
ACCOUNT LIST
No
Yes
No
Common
RPT
ADVANCE POSTING LIST
ROPAD­V_EM_100_01
No
Yes
No
Common
RPT
ASSET TRACKING DETAILS
ROPAT­K_EM_100_01
No
Yes
No
Common
RPT
BANK­RUPTCY ACCOUNT LIST
ROPBNK_EM_100_01
No
Yes
No
Common
RPT
COLLEC­TOR ACTIV­ITY DETAILS
ROP­COL_EM_100_01
No
Yes
No
Common
RPT
DEFI­CIENCY ACCOUNT LIST
ROP­DEF_EM_100_01
No
Yes
No
Common
RPT
DELIN­QUENT ACCOUNT LIST
ROP­DLQ_EM_100_01
No
Yes
No
Common
RPT
FUNDING CONTRACT LIST
ROP­FUN_EM_100_01
FUNDING CON­TRACT LIST
No
Yes
No
Common
RPT
GL TXN DETAILS LIST
ROP­GLI_EM_100_01
GL TXN DETAILS LIST
No
Yes
No
Common
RPT
APPLICA­TIONS LIST
ROPORG_EM_100_01
APPLICA­TIONS LIST
No
Yes
No
Common
RPT
PAYMENT ALLOCA­TION POST­ING DETAILS|
ROP­PAL_EM_100_01
No
Yes
No
Common
RPT
PAYMENT POSTING LIST
ROP­PMT_EM_100_01
No
Yes
No
Common
RPT
PAYABLE REQUISI­TION LIST
ROP­PRQ_EM_100_01
No
Yes
No
Common
RPT
REPOSSSE­SION/FORE­CLOSURE ACCOUNT LIST
ROPREP_EM_100_01
REPOS­SSESION/FORECLO­SURE ACCOUNT LIST
No
Yes
No
Common
RPT
SCHEDULE TO CHAR­GEOFF LIST
ROP­SCH_EM_100_01
No
Yes
No
Common
RPT
TERMINA­TION IN PROGRESS LIST
ROP­TIP_EM_100_01
TERMINA­TION IN PROG­RESS LIST
No
Yes
No
Common
RPT
NON MON­TETARY TXN POST­ING LIST
ROPTN­M_EM_100_01|
No
Yes
No
Common
RPT
ROPTX­N_EM_100_01
No
Yes
No
Common
RPT
BATCH JOB SETUP
CMN­BJB_EM_100_01
BATCH JOB SETUP
No
Yes
No
Common
RPT
BATCH JOB LOG
CMN­BJB_EM_100_02
BATCH JOB LOG
No
Yes
No
Common
RPT
NUMBER OF CREDIT APPLICA­TIONS ENTERED BY USER
OUN­ADE_EM_100_01
No
Yes
No
Common
RPT
CREDIT APPLICA­TIONS IMAGES BY STATUS
OUN­ADE_EM_100_02
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND PRO­DUCER (LOAN)
OUNUND_EM_111_11
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND UNDER­WRITER (LOAN)
OUNUND_EM_111_12
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH (LOAN)
OUNUND_EM_111_13
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY UNDER­WRITER (LOAN)
OUNUND_EM_111_14
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND PRO­DUCER (LINE)
OUNUND_EM_112_11
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND UNDER­WRITER (LINE)
OUNUND_EM_112_12
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH (LINE)
OUNUND_EM_112_13
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY UNDER­WRITER (LINE)
OUNUND_EM_112_14
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND PRO­DUCER (LEASE)
OUNUND_EM_121_11
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH AND UNDER­WRITER (LEASE)
OUNUND_EM_121_12
No
Yes
No
Common
RPT
UNDER­WRITING STATUS BY MONTH (LEASE)
OUNUND_EM_121_13
No
Yes
No
Common
RPT
OUNUND_EM_121_14
Yes
No
No
Lease
RPT
ACCOUNT PAYABLE (ORIGINA­TION)
OFNA­PY_EM_100_01
Yes
No
No
Common
RPT
ACCOUNT PAYABLE (SERVIC­ING)
OFNA­PY_EM_100_02
No
Yes
No
Common
RPT
PRE-FUND­ING CON­TRACTS (LOAN)
OFNF­ND_EM_111_01
Yes
No
No
Loan
RPT
FUNDED CON­TRACTS (LOAN)
OFNF­ND_EM_111_02
Yes
No
No
loan
RPT
PRE-FUND­ING CON­TRACTS (LINE)
OFNF­ND_EM_112_01
Yes
No
No
Loan
RPT
FUNDED CON­TRACTS (LINE)
OFNF­ND_EM_112_02
Yes
No
No
Common
RPT
PRE-FUND­ING CON­TRACTS (LEASE)
OFNF­ND_EM_121_01
Yes
No
No
Common
RPT
FUNDED CON­TRACTS (LEASE)
OFNF­ND_EM_121_02
Yes
No
No
Loan
RPT
ACCOUNT PAYABLE LOG BY PRODUCER
OCSAP­P_EM_100_01
Yes
No
No
Loan
RPT
ACCOUNT PAYABLE LOG BY VENDOR
OCSAPV_EM_100_01
Yes
No
No
Loan
RPT
COLLAT­ERAL TRACKING LOG
OCSAS­T_EM_100_01
Yes
No
No
Common
RPT
GL POST­ING LOG
OCS­GLI_EM_100_01
GL POST­ING LOG
Yes
No
No
Common
RPT
PAYMENT POSTING (DAILY CASH) LOG
OCSP­MT_EM_100_01
Yes
No
No
Common
RPT
PAYMENT POSTING ERROR LOG
OCSP­MT_EM_100_02
Yes
No
No
Common
RPT
ACCOUNT LISTING (LOAN)
OCSAC­C_EM_111_01
Yes
No
No
Loan
RPT
EXCESS PAYMENT (REFUND) LOG (LOAN)
OCSP­MT_EM_111_03
Yes
No
No
Loan
RPT
PAYMENT HISTORY (LOAN)
OCSP­MT_EM_111_04
Yes
No
No
Loan
RPT
PAYMENT ALLOCA­TIONS LOG (LOAN)
OCSP­MT_EM_111_05
Yes
No
No
Loan
RPT
PAYMENT ALLOCA­TIONS LOG BY GL POST DT (LOAN)
OCSP­MT_EM_111_06
Yes
No
No
Loan
RPT
PRO­DUCER STATE­MENT (LOAN)
OCSPS­M_EM_111_01
Yes
No
No
Loan
RPT
PRO­DUCER MONETARY TXNS LOG BY GL POST DT (LOAN)
OCSPTX_EM_111_01
PRO­DUCER MONE­TARY TXNS LOG BY GL POST DT (LOAN)
Yes
No
No
Loan
RPT
SCHED­ULED FOR CHAR­GEOFF ACCOUNTS LOG (LOAN)
OCSS­CH_EM_111_01
Yes
No
No
Loan
RPT
AMOR­TIZED TXNS LOG BY GL POST DT (LOAN)
OCSTAM_EM_111_01
Yes
No
No
Loan
RPT
SCHED­ULED FOR TERMINA­TION ACCOUNTS LOG (LOAN)
OCSTER_EM_111_01
Yes
No
No
Loan
RPT
OCSTX­N_EM_111_01
Yes
No
No
Loan
RPT
ACCOUNT LISTING (LINE)
OCSAC­C_EM_112_01
Yes
No
No
Loan
RPT
ADVANCE POSTING LOG (LINE)
OCSAD­V_EM_112_01
Yes
No
No
Loan
RPT
ADVANCE POSTING ERROR LOG (LINE)
OCSAD­V_EM_112_02
Yes
No
No
Loan
RPT
PAYMENT HISTORY (LINE)
OCSP­MT_EM_112_04
Yes
No
No
Loan
RPT
PAYMENT ALLOCA­TIONS LOG (LINE)
OCSP­MT_EM_112_05
Yes
No
No
Common
RPT
PAYMENT ALLOCA­TIONS LOG BY GL POST DT (LINE)
OCSP­MT_EM_112_06
Yes
No
No
Common
RPT
SCHED­ULED FOR CHAR­GEOFF ACCOUNTS LOG (LINE)
OCSS­CH_EM_112_01
Yes
No
No
Common
RPT
AMOR­TIZED TXNS LOG BY GL POST DT (LINE)
OCSTAM_EM_112_01
Yes
No
No
Common
RPT
SCHED­ULED FOR TERMINA­TION ACCOUNTS LOG (LINE)
OCSTER_EM_112_01
Yes
No
No
Common
RPT
MONETARY TXNS LOG BY GL POST DT (LINE)
OCSTX­N_EM_112_01
MONE­TARY TXNS LOG BY GL POST DT (LINE)
Yes
No
No
Common
RPT
ACCOUNT LISTING (LEASE)
OCSAC­C_EM_121_01
Yes
No
No
Common
RPT
PAYMENT HISTORY (LEASE)
OCSP­MT_EM_121_04
Yes
No
No
Common
RPT
PAYMENT ALLOCA­TIONS LOG (LEASE)
OCSP­MT_EM_121_05
Yes
No
No
Common
RPT
PAYMENT ALLOCA­TIONS LOG BY GL POST DT (LEASE)
OCSP­MT_EM_121_06
Yes
No
No
Common
RPT
SCHED­ULED FOR CHAR­GEOFF ACCOUNTS LOG (LEASE)
OCSS­CH_EM_121_01
Yes
No
No
Common
RPT
AMOR­TIZED TXNS LOG BY GL POST DT (LEASE)
OCSTAM_EM_121_01
Yes
No
No
Common
RPT
SCHED­ULED FOR TERMINA­TION ACCOUNTS LOG (LEASE)
OCSTER_EM_121_01
Yes
No
No
Common
RPT
MONETARY TXNS LOG BY GL POST DT (LEASE)
OCSTX­N_EM_121_01
MONE­TARY TXNS LOG BY GL POST DT (LEASE)
Yes
No
No
Common
RPT
BANK­RUPTCY LOG
OCOBNK_EM_100_01
BANK­RUPTCY LOG
Yes
No
No
Common
RPT
COLLEC­TOR ACTIV­ITY (DETAILED) LOG
OCO­COL_EM_100_01
No
No
Yes
Common
RPT
COLLEC­TOR PRO­DUCTIVITY BY QUEUE
OCO­COL_EM_100_02
No
No
Yes
Common
RPT
DELIN­QUENCY ANALYSIS BY PRO­DUCER
OCO­COL_EM_100_03
No
No
Yes
Common
RPT
DELIN­QUENCY ANALYSIS BY CREDIT GRADE
OCO­COL_EM_100_04
No
No
Yes
Common
RPT
DELIN­QUENCY ANALYSIS BY STATE
OCO­COL_EM_100_05
No
No
Yes
Common
RPT
PAYMENT PROMISE LOG
OCO­COL_EM_100_06
PAYMENT PROMISE LOG
No
No
Yes
Common
RPT
COLLEC­TOR ACTIV­ITY LOG
OCO­COL_EM_100_07
No
No
Yes
Common
RPT
DEFI­CIENCY LOG
OCODE­F_EM_100_01
DEFI­CIENCY LOG
No
No
Yes
Common
RPT
DELIN­QUENCY LOG
OCODLQ_EM_100_01
DELIN­QUENCY LOG
No
No
Yes
Common
RPT
REPOSSES­SION/FORE­CLOSURE LOG
OCOREP_EM_100_01
REPOS­SESSION/FORECLO­SURE LOG
No
No
Yes
Common
RPT
NON MONE­TARY TXNS LOG
OCOTN­M_EM_100_01
NON MON­ETARY TXNS LOG
No
No
Yes
Common
RPT
VENDOR INVOICE LOG
OCOVIN_EM_100_01
VENDOR INVOICE LOG
No
No
Yes
Common
RPT
VENDOR WORK ORDER LOG
OCOVNA_EM_100_01
No
No
Yes
Common
RPT
POOL DELIN­QUENCY SUMMARY (LOAN)
OCS­SEC_EM_111_01
No
Yes
No
Common
RPT
POOL DEFAULTS (NON LIQUI­DATED) (LOAN)
OCS­SEC_EM_111_02
POOL DEFAULTS (NON LIQ­UIDATED) (LOAN)
No
Yes
No
Common
RPT
POOL PAY­OFFS (LOAN)
OCS­SEC_EM_111_03
No
Yes
No
Common
RPT
POOL RECOVERY (LOAN)
OCS­SEC_EM_111_04
POOL RECOV­ERY (LOAN)
No
Yes
No
Common
RPT
POOL DELIN­QUENCY (LOAN)
OCS­SEC_EM_111_05
No
Yes
No
Common
RPT
POOL REPUR­CHASED ACCOUNTS (LOAN)
OCS­SEC_EM_111_06
No
Yes
No
Common
RPT
POOL MONTHLY ACTIVITY (LOAN)
OCS­SEC_EM_111_07
No
Yes
No
Common
RPT
POOL LIQ­UIDATED CON­TRACTS (LOAN)
OCS­SEC_EM_111_08
No
Yes
No
Common
RPT
POOL TXNS LOG BY GL POST DT (LOAN)
OCS­SEC_EM_111_09
No
Yes
No
Common
SET-QRT
Real time Queues pro­cessing
QCSPRC_B­J_100_02
No
Yes
Yes
Common
This batch job pro­cesses queues marked as real time based on refresh frequency setup in the job set.
TAM
MONTH END COM­PENSATION DISBURSE­MENT PRO­CESSING
TPR­COM_B­J_100_01
MONTH END COM­PENSA­TION DISBURSE­MENT PRO­CESSING
No
Yes
No
Common
TAM
PRO­DUCER STATE­MENTS
TPRPS­G_B­J_100_01
No
Yes
No
Common
TAM
PRO­DUCER STATUS CHANGE
TPRSTA_BJ_100_01
No
Yes
No
Common
TPE
TXNCH­G_B­J_100_02
CHAR­GEOFF PROCESS­ING FOR ACTIVE ACCOUNTS
No
Yes
No
Common
This package con­tains procedures related to Batch Job for chargeoff processing
ESC
ESCROW ANALYSIS POSTING
TESAN­L_B­J_100_01
No
Yes
No
Common
This package con­tains procedures related to Batch Job for escrow analysis process­ing
ESC
CREATE BATCHES FOR CUS­TOMER REFUND REQUESTS
TESAN­L_B­J_100_02
No
Yes
No
Common
ESC
COMPUTE CONTROLS FOR CUS­TOMER REFUND REQUEST BATCHES
TESAN­L_B­J_100_04
COMPUTE CON­TROLS FOR CUS­TOMER REFUND REQUEST BATCHES
No
Yes
No
Common
ESC
ESCROW COMPLI­ANCE CHECKING
TESAN­L_B­J_100_05
No
Yes
No
Common
ESC
CREATE PAYABLE REQUISI­TIONS FROM APPROVED DISBURSE­MENT REQUESTS
TESDS­B_B­J_100_01
No
Yes
No
Common
PUR
PACARC_BJ_100_01
No
Yes
No
Common
EVE
BATCH EVENTS FOR ACCOUNTS
EVBAC­C_B­J_100_01
Yes
EVE
BATCH EVENTS FOR APPLI­CATIONS
EVBAP­P_B­J_100_01
Yes
EVE
MAIN BATCH JOB FOR BATCH EVENTS PROCESS­ING
EVB­PRC_B­J_100_01
Yes
ODD2
BATCH JOB TO GENER­ATE METRO 2 DATA
CBUUT­L_B­J_100_02
Yes
ODD2
BATCH JOB FOR CRE­ATING METRO 2 DATA FILE
CBUUT­L_B­J_100_03
Yes
ODD2
THIRD PARTY ACH PROCESS­ING
ACT­PRC_B­J_100_01
Yes
ODD2
THIRD PARTY OUT­PUT DATA DUMP SER­VICING
OBI­PRC_B­J_100_01
CREATE THIRD PARTY CUS­TOMER FILE
Yes
This process pulls the customer account details shared in input data files for pro­cessing.
ESC
JOB TO GENERATE ESCROW DISCLO­SURE STATEMENT
OED­PRC_B­J_100_01
JOB TO GENERATE ESCROW DISCLO­SURE STATE­MENT
Yes
EDF
ADR FILE
EDFADR_BJ_100_01
ADR FILE
Yes
EDF
IVR FILE
EDFIVR_BJ_100_01
IVR FILE
Yes
TPE
CONTRAC­TUAL PRO­MOTION CANCEL PROCESS­ING
TXN­PRM_B­J_100_04
Yes__
TPE
RATE CHANGE PROCESS­ING FOR BACK­DATED INDEXES
TXN­RAT_B­J_100_02
Yes
RDB1
LOAD ACCOUNT RELATED DATA INTO T TABLES
RACD­MP_B­J_100_01
Yes
TPE
EXPIRED INSUR­ANCE PRO­CESSING
TXNINS_BJ_100_01
Yes
ADT
UPDATE ROWID IN AUDIT TABLE (RUN THIS JOB AFTER EXPORT-IMPORT OF TABLES)
ADT­PRC_B­J_100_01
Yes
RDB1
LOAD INSUR­ANCE DATA TO T-TABLES
RIND­MP_B­J_100_01
Yes
AGS
SALE LEAD AGING
AGS­SAL_B­J_100_01
SALE LEAD AGING
Yes
BOD
PROCESS PARKED TRANSAC­TIONS
JOB­BOD_B­J_000_02
Yes
BOD
MARK SYS­TEM FOR BEGINING OF DAY
JOB­BOD_B­J_000_01
Yes
EOD
SET SYS­TEM MODE TO END-OF-DAY
JOBEOD_BJ_000_01
Yes
ACR
DAILY TRIAL BALANCE DATA
TABAC­C_B­J_100_01
DAILY TRIAL BAL­ANCE DATA GENERA­TION
Yes
LTR2
RATE CHANGE PRE-INTI­MATION LETTER
LCS­RAT_B­J_100_01
Yes
BLK
BULK UPLOAD FOR PRIC­ING SETUP
BLK­PRP_B­J_100_01
Yes
BLK
BULK UPLOAD FOR GL ATTRI­BUTES
BLK­GLS_B­J_100_01
common
BLK
BULK UPLOAD FOR GL TRANSLA­TION
BLK­GLS_B­J_100_02
BULK UPLOAD FOR GL TRANSLA­TION DEFI­NITION
common
BLK
BULK UPLOAD FOR GL TRANSAC­TION TYPES
BLK­GLS_B­J_100_03
BULK UPLOAD FOR GL TRANSAC­TION TYPES DETAILS
common
BLK
BULK UPLOAD FOR GL TRANSAC­TION LINKS
BLK­GLS_B­J_100_04
common
ODD2
RATE CHANGE LETTER FILE
OLSRAT_BJ_100_01
RATE CHANGE LETTER FILE CRE­ATION
Yes
TPE
EXPIRED DRAW PERIOD PROCESS­ING (STAGE FUNDED LOANS)
TXN­DRW_B­J_111_01
Yes
ODD2
DEALER SUBVEN­TION STATE­MENTS
OPSSB­V_B­J_100_01
DEALER SUBVEN­TION STATE­MENTS GENERA­TION
common
TAM
SUBVEN­TION RECEIV­ABLE PRO­CESSING (PAY AS GO)
TPRSB­V_B­J_100_01
common
ODD2
PRO­DUCER CHECK PRINT
OPCPRC_B­J_100_01
PRO­DUCER CHECK PRINT GENERA­TION
common
BSR
BEHAV­IORAL SCORING
BSR­PRC_B­J_100_01
BEHAV­IORAL SCORING
yes
AGE
TRANSAC­TION IN WAITING FOR APPROVAL AGING
TXNAGE_BJ_100_01
TRANSAC­TION IN WAITING FOR APPROVAL AGING PROCESS
yes
ACR
PREPARE BATCH DATA FOR INTEREST ACCRUAL AND DELIN­QUENCY
TXNA­CR_B­J_100_02
PREPARE BATCH DATA FOR INTEREST ACCRUAL AND DELIN­QUENCY PROCESS­ING
yes
PDC
POST DATED CHECKS
PDCPRC_B­J_100_01
POST DATED CHECKS
yes
PDC
PENDING PDC
PDCPND_B­J_100_01
PENDING PDC PRO­CESSING
yes
LTR2
PDC RENEWAL LETTER
LCSPD­C_B­J_100_01
PDC RENEWAL LETTER GENERA­TION
yes
DOT
APPLICA­TION DOCU­MENT LOAD
DOL­PRC_B­J_000_02
APPLICA­TION DOC­UMENT LOAD
Yes
ODD2
ONE TIME ACH POST DATED PAY­MENT LET­TER
OLSPD­P_B­J_100_01
ONE TIME ACH POST DATED PAYMENT LETTER PROCESS­ING
Yes
WFP
BILLING
WTX­BIL_B­J_132_01
BILLING PROCESS­ING
Yes
WFP
DELIN­QUENCY
WTX­DLQ_B­J_132_01
Yes
WFP
LATE CHARGE
WTX­LTC_B­J_132_01
LATE CHARGE ASSESS­MENT
Yes
WFP
STATEMENT
WTXPS­G_B­J_132_01
STATE­MENT GEN­ERATION
Yes
WFP
RATE CHANGE
WTX­RAT_B­J_132_01
Yes
WFP
TERMINA­TION
WTX­TIP_B­J_132_01
Yes
TPE
PERIODIC MAIN­TAINENCE FEE
TXNPM­F_B­J_100_01
PERIODIC MAIN­TAINENCE FEE PRO­CESSING
WFP
UNIT UPLOAD
WUP­PRC_B­J_132_01
UNIT UPLOAD
common
ODD2
BATCH JOB FOR MONTHLY HANDSOFF FILE FOR SIMAH
CBUUT­L_B­J_100_04
BATCH JOB FOR MONTHLY HAND­SOFF FILE FOR SIMAH
PUR
PURGE ALL PTT TABLES
PTTPRC_BJ_100_01
comon
TPE
BATCH JOB FOR SET­TING MATURED ACCOUNT CONDITION
TXN­MAC_B­J_100_01
yes
TPE
NON REFUND GL
TXNRF­D_B­J_100_01
NON REFUND GL PRO­CESSING
common
TPE
PAYMENT ARRANGE­MENT
TXNPA­P_B­J_100_01
PAYMENT ARRANGE­MENT PRO­CESSING
yes
TPE
DELAY FEE
TXND­LY_B­J_100_01
DELAY FEE PROCESS­ING
yes
TPE
STATE­MENT PAST MATURITY
TXNST­M_B­J_100_01
STATE­MENT PAST MATURITY PROCESS­ING
yes
TPE
BLACK BOOK INTERFACE
VEVBB­K_B­J_100_01
common
LBT
BULK NSF PAYMENT REVER­SALS
TXNNS­F_B­J_100_01
ACR
STOP INTEREST ACCRUAL
TXNA­CR_B­J_100_03
STOP INTEREST ACCRUAL PROCESS­ING
yes
QRT
CUSTOMER SERVICE REAL TIME QUEUE
QCSPRC_B­J_100_02
CUS­TOMER SERVICE REAL TIME QUEUE PROCESS­ING
yes
ODD2
OUT­BOUND CUSTOMER EXTRACTS TO PAY­MENT AGENCIES
OCP­PRC_B­J_100_01
OUT­BOUND CUS­TOMER EXTRACTS TO PAY­MENT AGENCIES
yes
IFP
OFFLINE CALL ACTIVITY POSTING
ICAPRC_BJ_100_01
yes
ACR
RE-START INTEREST ACCRUAL
TXNA­CR_B­J_100_04
yes
IFP
UPLOAD TRANSAC­TIONS
ITUPRC_BJ_100_01
yes
IFP
POST UPLOADED TRANSAC­TIONS
ITUPRC_BJ_100_02
yes
IFP
INPUT FILE PROCESS­ING - CUR­RENCY EXCHANGE RATE FILE UPLOAD
ICE­PRC_B­J_100_01
Yes
Yes
Yes
Common
This process extracts currency exchange rates from desired source at sched­uled intervals.
IFP
INPUT FILE PROCESS­ING - INPUT DATA INSERTION
IDDPRC_BJ_000_01
Yes
This process updates customer account informa­tion corresponding to the details received from external system. Ex: Bankruptcy details in External Interface screen or Cure Letter details in Account Infor­mation screen.
IFP
IPIPRC_BJ_100_01
PI INFRO­MATION FILE UPLOAD PROCESS­ING
Y
Y
Y
Common
This process uploads input file with PII data into the data masking screen.
PUR
ARCHIVE PURGE JOB SET
PJR­PAC_B­J_100_01
PURGE ACCOUNTS DATA
Y
Y
Y
Common
This process purges accounts data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRPA­P_B­J_100_01
PURGE APPLICA­TION DATA
Y
Y
Y
Common
This process purges application data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRP­GL_B­J_100_01
PURGE GL TXNS DATA
Y
Y
Y
Common
This process purges general ledger transaction data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRP­PA_B­J_100_01
PURGE POOLS DATA
Y
Y
Y
Common
This process purges pools and its transactions data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRP­PX_B­J_100_01
PURGE PRO­DUCER TXNS DATA
Y
Y
Y
Common
This process purges producer transaction data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRPTX­_BJ_100_01
PURGE TXNS DATA
Y
Y
Y
Common
This process purges account transaction data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
PUR
PJRPVA_BJ_100_01
PURGE VENDOR ASSIGN­MENTS DATA
Y
Y
Y
Common
This process purges vendor assignment data in archival tables based on the days defined in system parameter PAC_PURGE_­DAYS.
2.9 Producer Cycles
The Producer setup screen enables you to define the dealer or producer status cycle. This tells the system which status a producer can cycle through. (This information is recorded in the Status field on the Producers section of the Producer setup screen.
For example,
The Producer Setup screen also defines the user responsibilities capable of changing the producer status.
Note
The system enables only producers/dealers with a status of ACTIVE to fund contracts.
To set up Producer Cycles
  1. On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > Administration > System > Producer Cycles.
  2. The system displays the Producer Cycles screen. The producer cycle screen contains three section:
  1. In the Cycle Definitions section, you can view the following information.
    Field:
    View This:
    Cycle
    Displays the cycle name.
    Type
    Displays the cycle type.
  2. In the Cycle/Next Status section, perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Current Code
Select the current code from which you need to perform transition, from the drop-down list.
Next Code
Select the code to which you need to perform transition, from the drop-down list.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. In the Status Change Responsibilities section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Responsibility Code
Select the responsibility that will be capable of executing this transition, from the drop-down list.
Allowed Indicator
Check this box to enable the responsibility to execute the transition.
2.10 Vendors
During the life of an account, a financial institution might require the use of specialized services of a vendor for various purposes; for example, repossessing a vehicle, retaining an attorney for bankruptcy court proceedings, or making field calls. With the system’s Vendors screen, you can define the following:
2.10.1 Cycles Tab
The Cycle link allows you to define the various vendor cycles and the responsibilities that can gain access to the various transactions in each cycle. The different categories are:
To set up the vendor cycles
  1. Click Setup > Setup > Administration > System > Vendors > Cycles. The screen contains three sections:
  1. In the Status Cycle section, perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields are given below:
Field:
View this:
Cycle
Specify the status cycle for the vendor.
Type
Displays the type of vendor assignment status cycle.
Order Type
Select the work order type for the vendor from the drop-down list.
  2. In the Current/Next Status section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Current Code
Select the current code from which you need to transition, from the drop-down list
Next Code
Select the Next status code to which you need to transition, from the drop-down list
Action Code
Select the call activity action code from the drop down list.
Result Code
Depending on the call activity action code, you can select the result code from the drop down list.
Note
When there is a change in status from ‘Current’ to ‘Next’, system posts respective call ac­tivity on the account based on selected Action and Result code.
  2. In the Status Change Responsibilities section, perform any of the Basic Operations mentioned in Navigation chapter:
Field:
Do this:
Allowed
Select ‘Yes’ to enable the responsibility to execute the transition and ‘No’ to disable
Responsibility
Select the responsibility that will be capable of executing this transition (from current code to the next code), from the drop-down list.
2.10.2 Vendor Services Tab
The Vendor Service screen enables you to establish the links between the service type, vendor group, and the work order type. It records which vendor groups can provide which type of services and which service type belongs to which work order types.
For each service type (Service Type field), there can be multiple vendor groups and/or multiple work order type(s).Each vendor (Group field) can belong to one or multiple vendor group(s).
  1. Click Setup > Setup > Administration > System > Vendors > Vendor Services. The screen contains three sections:
  1. In the Services section, you can view the following information:
    Field:
    View this:
    Service Type
    Displays the service type.
    Enabled
    Displays if the service is enabled or not.
  2. In the Vendor Groups section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Group
Select the vendor group from the drop-down list.
  2. In the Work Order Types section, perform any of the Basic Operations mentioned in Navigation chapter:
Field:
Do this:
Work Order Type
Select the work order type from the drop-down list.
Transaction
Select the associated transaction for the service type from the drop-down list.
2.10.3 Vendor Fees Tab
The Vendor Fees tab allows you to define fee structure (with specific amount) for each service offered by specific vendor. The defined fees is auto populated as the estimated cost of the assignment when a specific vendor and service is selected during work order creation.
To define vendor fees
  1. Click Setup > Setup > Administration > System > Vendors > Vendor Fees. The screen consists of Vendor Service Fee Definition section with option to define vendor fees.
  2. In the Vendor Service Fee Definition section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Start Dt
System defaults the current date as the start date. You can modify the same to a future date using the adjoining calendar.
End Dt
Specify the end date from the adjoining Calendar.
Enabled
Select the check box to enable the fee structure.
Amt
Specify the amount charged by the vendor for a specific service.
Selection Criteria
Vendor Group
Select the vendor group from the drop-down list. You can also select ‘ALL’ (default option) if the fee structure is applicable across vendor groups.
Vendor
Select the vendor from the drop-down list. You can also select ‘ALL’ if you have selected the ‘Vendor Group’ as ‘ALL’. The list is sorted depending on the vendor group selected.
Services
Select the service from the drop-down list. The list is sorted depending on the services offered by the selected Vendor.
Company
System defaults this value based on the vendor selected. You can also select the required company from the drop-down list.
Branch
System defaults this value based on the vendor selected. You can also select the required branch from the drop-down list.
Vendor Channel
System defaults this value based on the vendor selected. You can also select the required vendor channel from the drop-down list.
State
System defaults the state in which the vendor operates. You can also select the state from the drop-down list.
2.10.4 Invoice Rules tab
The Invoice Rules tab allows you to define state specific rules with a combination of service and work order status. This helps to decide if a particular service fees in a work order is ‘Collectable or Not’ from the customer.
When the same combination of service, work order status and state is detected during auto invoice validation, the ‘Collectible’ check box in Vendors > Invoice tab > Invoice Details section is selected. Further, the collectible amount is posted as an expense on the customer account.
To define invoice rules
  1. Click Setup > Setup > Administration > System > Vendors > Invoice Rules.
  2. In the Invoice Rules section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Service
Select the service from the drop-down list. The list consists of services offered by Vendors which can be associated with a work order.
Work Order Status
Select the work order status from the drop-down list.
Close Rea­son
Select the close reason from the drop-down list. This field is enabled only if the work order status is selected as ‘CLOSE’.
State
Select the state from the drop-down list. The selection here indicates that the state rules allow to collect the service fee for selected service from the customer.
Enabled
Select the check box to enable the invoice rule.
2.11 Reports
The Reports screen allows you to setup reports in the system.
To set up the Reports
  1. Click Setup > Setup > Administration > System > Reports link. The system displays the Report screen. The details are grouped into two:
  1. In the Reports section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Code
Specify the code of the report.
Description
Specify the description of the report.
Package
Specify the package .
Module
Select the code of the report from the drop-down list.
System Defined Yes/No
Select ‘Yes’, if you wish to maintain the Report as system defined and ‘No’, if you do not want to maintain it as system defined. Sys­tem defined entries cannot be modified. If the entry is not system defined, then it can be modified.
Enabled
Check this box to enable the report definition.
  2. In the Report Parameters section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Parameter
Specify the parameter code of the report.
Description
Specify the description of the parameter.
Parameter Type
Select the parameter type of the report from the drop-down list.
Parameter Sub Type
Select the parameter sub type of the report from the drop-down list.
Default
Specify the default value for the report parameter (value to ini­tially populate, or used if no value is supplied) (optional).
Sort
Specify the sort order for the lookup code. This determines the order these report parameters are displayed or processed.
Enabled
2.12 Error Messages
In the Error Messages Setup screen, you can translate or modify the text of error messages. the system displays all messages as they appear to the system users in the Error Message section’s Message field.
New messages created with the Error Messages screen can then be translated with the Setup > Setup > Administration > System > Translation > Message Translation screen.
To set up the Error Messages Setup screen
  1. Click Setup > Setup > Administration > System > Error Messages. The system displays the Error Message screen.
  2. On the Error Messages Setup screen’s Error Type section, use the Error Type field to select the error type. These are the categories of error messages available for creating or editing.
  3. The error messages associated with the error type you selected appear in the Error Message section.
  4. In the Error Messages section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Region
Specify the region code.
Country
Specify the country code.
Customer
Specify the customer code.
Engine
Specify the engine code.
Error Code
Specify the error code.
System Defined
Displays whether the record is system defined or not.
Enabled
Check this box to enable the data error message.
Error Message
Specify the error message.
2.13 Translation
You can setup translation properties.
Navigating to Translation
  1. Click Setup > Setup > Administration > System > Translation. The system displays the Translation screen. On this screen you can,
2.13.1 Setup Translation
In the Setup Translation tab, you can translate the contents of a predefined list of setup description fields into a different language.
After you translate an entry in the Translation Data section, the system adds the new data to the setup form.
To set up the Translation Setup
  1. Click Setup > Setup > Administration > System > Translation > Setup Translation.
  2. In the Language section, you can select the language for which you need to setup the translation.
Note
For more information, refer Language setup at the end of this chapter.
  1. In the Source Type section, you can select the source (or location in the system) of the item you want to translate.
  2. Click Populate All in the Source Type section and the system loads the setup data descriptions in the Translation section screen for the selected source type.
If you have new entries and are unsure as to which setup items have been updated since the last translation, click Populate All, the system loads the additional data for all items with no impact to the previously translated data for any of the entries.
  1. In the Translation Data section, Select:
  1. In the Translation Data section, perform any of the Basic Operations mentioned in Navigation chapter.
Note
You cannot add a new record.
Field
Do this:
Key 1
Displays the first reference key value.
Key 2
Displays the second reference key value.
Key 3
Displays the third reference key value.
Key 4
Displays the fourth reference key value.
Key 5
Displays the fifth reference key value.
Key 6
Displays the sixth reference key value.
System Defined
Select ‘Yes’, if you wish to maintain the data as system defined and ‘No’, if you do not want to maintain it as system defined.
Enabled
Check this box to indicate that the record is active.
Desc 1 Translation 1
Specify the first translated description.
Desc 2 Translation 2
Specify the second translated description.
Desc 3 Translation 3
Specify the third translated description.
Desc 4 Translation 4
Specify the fourth translated description.
2.13.2 Message Translation Setup
In the Message Translation tab, you can translate the contents of a predefined list of error messages into a different language.
After you translate an entry in the Error Message section, the system adds the new data to the error message.
To set up the Message Translation Setup
  1. Click Setup > Setup > Administration > System > Translation > Message Translation.
  2. In the Language section, you can select the language for which the translation needs to be done.
Note
  1. In the Error Type, you can select the type of error message you want to translate.
  2. Click Populate All in the Error Type section and the system loads the error messages in the Error Message section for the selected error type.
If you have new entries and are unsure as to which error messages have been updated since the last translation, click Populate All, the system loads the additional data for all items with no impact to the previously translated data for any of the entries.
  1. In the Error Message section, select:
  1. In the Error Message section, perform any of the Basic Operations mentioned in Navigation chapter.
Note
Field
Do this:
Region
Displays the region code.
Country
Displays the country code.
Customer
Displays the customer code.
Engine
Displays the engine name.
Error Code
Displays the error code.
System Defined
Check this box to indicate that the record is system defined.
Enabled
Message
English Translation
Specify the English translated description.
Language setup
On the Lookup master tab’s Lookup Types screen, you can add other languages to the TRD_LANGUAGE_CD lookup type and perform translations for those languages.
However, translated data only appears in one language, which is defined by the User Language parameter. This parameter can be defined in the system configuration file, typically named DBKWEB.CFG, which defines the parameter as:
Parameter: otherparams=ORA_USER=<schema_name> USR_LANG=<native language>
Note
<native language> should match lookup codes in the TRD_LANGUAGE_CD lookup type on the Administration form’s Lookups screen.
The system supports the following pre-defined list of setup items for translation:
  1. Asset Sub Types
  2. Asset Types
  3. Assignments
  4. Audit Table Columns
  5. Audit Tables
  6. Call Action Result Types
  7. Call Action Types
  8. Checklist Action Types
  9. Checklist Types
  10. Commission Plans
  11. Companies
  12. Company Branch Departments
  13. Company Branches
  14. Compensation Plans
  15. Credit Bureau Score Reasons
  16. Credit Models
  17. Credit Scoring Parameters
  18. Edits
  19. Escrow Disburse Rules
  20. Escrow Sub Types
  21. Flex Table Attributes
  22. Flex Tables
  23. GL Transaction Types
  24. GL Translators
  25. Job Sets
  26. Jobs
  27. Lookup Codes
  28. Lookup Types
  29. Portfolio Companies
  30. Portfolio Company Branches
  31. Producers
  32. Product Instruments
  33. Product Insurances
  34. Product Pricings
  35. Products
  36. Promotions
  37. Spreads
  38. Standard Correspondences
  39. Standard Document Definitions
  40. Standard Element Definitions
  41. Standard Function Definitions
  42. Transaction Codes
  43. Error Messages
  44. Org. Fees
2.14 Seed Data
Seed data in general is referred to as any data delivered with the standard product installation and is required to be present in the production environment for application to work properly. Seed data basically consists of Table with its associated data that are uploaded into the system through DAT files.
Seed Data screen in Oracle Financial Services Lending and Leasing displays the seed data details maintained in the system along with the updated seed data provided with the latest release or patch installation.
Note that, when you upgrade OFSLL from an existing version to higher version,
The modified seed data can have updates on base tables and/or its associated data and the changes can either be updated or skipped depending on the need.
Navigating to Seed Data screen
  1. Click Setup > Setup > Administration > System > Seed Data. The system displays the Seed Data screen.
  2. On this screen you can do the following:
2.14.1 Factory Data
The Factory Data tab displays the list of both existing and updated seed data which are provided though release/patch installation. In the Factory Data tab you can select and update only the required seed data changes into the respective seed data tables. During update, you can also skip the seed data changes for later updates (if required).
Accordingly, you can sort the view in Factory Data tab by selecting ‘Skipped’, ‘Update’ or ‘All’ options to display the list of corresponding seed data.
In the ‘Patch #’ drop-down list, you can further sort the list to display ‘ALL’ the seed data or only the additions or updates available as part of latest patch which has seed data changes.
To View Factory Data
Click Setup > Setup > Administration > System > Seed Data > Factory Data tab.
The ‘Factory Data’ section displays the list of seed data with the following details:
Field
View this:
Table
Displays the seed data table name.
Type
Displays the category of seed data as either System or Combination Data.
Key Column
Displays the unique identifier columns.
Key Column Type
Displays the unique identifier column data types.
Other Columns
Displays the non unique identifier column names.
Other Column Types
Displays the non unique identifier column data types.
Count
Displays the total count of updated records in the seed data table.
The ‘Factory Data Details’ section displays the associated data of the selected seed data table along with the following details:
Field
View this:
Key Column Data
Displays the unique identifier column names.
Other Column Data
Patch #
Displays the patch number with which the seed data changes are identified.
Status
Displays the current status of seed data as one of the following:
INSERT: This status indicates new seed data.
UPDATE: This status indicates if there are changes in the record when compared to the seed data released in previous patch.
POSTED: This status indicates that the seed data changes are updated into the main tables and is subsequently updated from previous status - SKIPPED OR UPDATE OR INSERT.
SKIPPED: This status indicates that the seed data is not updated into the main tables.
DEPRECATED - This status indicates that the seed data is no longer used.
In the ‘Factory Data’ tab, you can click (refresh) to fetch the latest details and click ‘View’ to display the detailed information of the selected record.
2.14.1.1 Update/Skip Seed Data
The ‘Update’ option in the Factory Data tab allows you to replace the existing seed data with the current update. However, ensure to double check the details before performing ‘Update’ operation since the same can have significant impact on system behaviour.
To Update/Skip Data
  1. In the Factory Data’ tab, select ‘Update’. System displays those records which can be updated to the existing seed data tables.
  2. Inspect the required record in Factory Data section with the Factory Data Details in subsequent section.
  3. Select the required record to be updated by clicking on the adjacent check box. You can also click ‘Select All’ to select all the records.
  4. Do one of the following:
    • Click ‘Update Data’. This action updates the existing seed data with the updated seed data provided as part of the current patch release.
    • Click ‘Skip Data’. This action skips the seed data changes received as a part of the patch release. The skipped records can be viewed by selecting ‘Skipped’ option in Factory Data tab. However, the same can further be updated into the system, by selecting ‘Update Data’.
  1. Click ‘Yes’ in confirmation dialog to confirm the setup data changes.
On successful update, system does the following:
2.14.2 Current Data
The Current data tab displays the customized seed data which are changed or configured as part of implementation. In the ‘Current Data’ tab, you can click (refresh) to fetch the latest details and click ‘View’ to display the detailed information of the selected record.
Additionally you can click “Refresh Data’ to pull the seed data details from the production system and update the current seed data tables.
To View Current Data
Click Setup > Setup > Administration > System > Seed Data > Current Data tab.
The ‘Current Data’ section displays the following details:
Field
View this:
Table
Displays the current seed data table name.
Type
Key Column
Key Column Type
Other Columns
Other Column Types
Count
Displays the total count of records in the seed data table.
Last Refreshed Dt
Displays the date and time when seed data for the selected table was last updated in the system.
The subsequent ‘Current Data Details’ section displays the associated data of the selected seed data table along with the following details:
Field
View this:
Key Column Data
Other Column Data
2.14.3 Comparison Data
The ‘Comparison Data’ tab displays the differences between factory shipped seed data and current customized seed data.
To View Comparison Data
Click Setup > Setup > Administration > System > Seed Data > Comparison Data tab.
The ‘Comparison Data’ section displays the list of seed data records with the following details:
Field
View this:
Table
Displays the seed data table name to be inserted or updated.
Type
Key Column
Key Column Type
Other Columns
Other Column Types
Count
The subsequent ‘Comparison Data Details’ section displays the associated data of the selected seed data table along with the following details:
Field
View this:
Key Column Data
Other Column Data
Patch #
Displays the patch release version with which the seed data was inserted/updated.
In the ‘Comparison Data’ tab, you can click (refresh) to fetch the latest details and click ‘View’ to display the detailed information of the selected record.
2.14.4 Download Data
The Download Data tab allows you to download table specific seed data available in the system in ‘.dat’ format. While migrating from one environment to other, you can use the Download Data tab to download the existing seed data and perform a bulk upload of all/required files.
Similar to other file download process, based on the value defined for the system parameter ‘CMN_FILE_PROCESS_TO_LOB’, the seed data download file can be accessed from the Process Files interface (if value is ‘Y’) or Database Files system (if value is ‘N’). For more information on handling Incoming/Outgoing process files, refer to ‘Dashboard’ section in User Guides.
To Download Data
  1. Click Setup > Setup > Administration > System > Seed Data > Download Data tab.
The Download Data section displays the list of tables maintained in the system with ‘Table Name’ and ‘Table Type’. Click (refresh) to fetch the latest details.
  1. Select the check box adjacent to the required table in the list. You can choose ‘Select All’ check box to select all the tables with seed data maintained in the system.
  2. Click ‘Submit For Download’ button. System displays an information message in the header indicating that the request has been submitted along with a reference number. The reference number is generated in format - useridDDMMHHMISS# followed by table name with ‘.dat’ extension. For example, (USER1230603121517#lookups.dat)
(Optional) If ‘CMN_FILE_PROCESS_TO_LOB’ is set to ‘Y’, navigate to DashBoard > Process Files screen > Outgoing Process File tab to download the selected seed data file which will be listed with the same reference number. The file can be downloaded to Application server.
2.15 Data Masking
Data masking screen in Oracle Financial Services Lending and Leasing facilitates to mask Personally Identifiable Information (PII) displayed in the application to safeguard the sensitive and confidential information while protecting them from offenders.
As part of the product installation, standard set of identified fields (seed data) which is likely to contain either organization / customer PI information are provided for data masking in disabled status. Based on need, the required fields can be enabled and masked for specific user responsibility in the Data Masking screen. Also if there are additional PII fields identified for masking, the same can be pooled into the system using input file processing method and masked using Data Masking screen.
The data masking process involves the following steps:
The following table indicates the standard pre-defined fields (seed data) identified in respective screens/tabs which can be readily masked using the Data Masking screen.
Tab Name
Field Names
Origination
Applicant
First Name, MI, Last Name, Family Name, Birth Dt, Nationality, National ID, Visa #, Passport #, License #, Marital status, Mother's maiden name, Passport number, Gender, Language, Dependents, Ethnicity, Disability, Email, Race, and Education.
Applicant > FATCA
Birth Place, Birth Country, and Permanent US Resident Status.
Applicant > Power of Attorney
Holder Name, Address, Country, Nationality, and Telephone Number.
Applicant
Active Military Duty, Military Effective Date, Duty Order Number, and Active Military duty Release date.
Addresses
Country, Postal Address Type, Address #, Street Pre, Street Name, Street Type, Street Post, Apt #, Address 1, Address 2, Address 3, Zip, Zip Extn, City, State, and Phone.
Telecoms
Phone and Extn
Employments
Employer, Country, Address #, Address 1, Address 2, Zip, Zip Extn, City, State, Phone, Extn, Income Amt - Stated, Income Amt - Actual, Salary - Stated, Salary - Actual, and Title.
Applicant > Financials
Type, Source, Account #, and Currency.
Existing Accounts
Account # and Title.
Servicing
Customer
Name, Birth Dt, Nationality, National ID, Visa #, Passport #, License #, Marital status, Mother's maiden name, Passport #, Language, Disability, Email, and Education.
Customer > FATCA
Customer > Power of Attorney
Customer
Addresses
Country, Postal Address Type, Address #, Street Pre, Street Name, Street Type, Street Post, Apt #, Address 1, Address 2, Address 3, Zip, Zip Extn, City, State, Phone, and Address.
Employments
Employer, Country, Address #, Address 1, Address 2, Zip, Zip Extn, City, State, Phone, Extn, and Title.
Assets tab
Assets
Identification #, Lien Status, Lien Event Date, Second Lien Holder, Comments, Lien Release Entity, and Entity Name.
Masking Format
Oracle Financial Services Lending and Leasing supports only complete masking (not partial) of both factory shipped and user identified PII data. On masking, the masked data is presented in same structural format to facilitate internal validations. The below table indicates the default values used for masking fields based on data type:
Data Type
Masking Value
NUMBER
9
VARCHAR
X
DATE
31/12/9999
Phone number
For UI represented format - 000-000-0009 (Masked with 0’s and last digit as 9) and for generic, masked as 9999999999
Email
xxxxx.xxx@<domain>.com
Note
It is recommended to avoid modifying masked data for user(s) with masked responsibility. However, while editing masked data (if permitted) requires to input full data replacing the masked characters. For example, editing a masked SSN (xxx.xx.xxxx) requires to specify all nine digits of SSN and not just the last four digits.
2.15.1 Setup Data Masking
  1. Click Setup > Administration > System > Data Masking.
  2. Define the parameters available in ‘Data Masking Details’ and ‘User Access Details’ tabs.
2.15.1.1 Data Masking Details
On clicking Data Masking link, the Data Masking Details tab is displayed by default and allows you to enable the required fields for masking.
  1. In the Data Masking Details section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Table Name
View the table name which contains the selected field details.
Field Name
View the selected field name.
Enabled
Check this box to enable masking of the selected field.
System Defined
View the type of seed data maintained in the system. ‘Y’ indicates factory shipped seed data and ‘N’ indicates user defined seed data.
2.15.1.2 User Access Details
The User Access Details tab facilitates to define the user responsibility to whom the PII data should be masked. By default, all the selected PII data in Data Masking Details tab appears as masked for one or more user(s) selected in this tab.
  1. Click Setup > Administration > System > Data Masking > User Access Details.
  2. In the User Access Details section, perform any of the Basic Operations mentioned in Navigation chapter.
Field
Do this:
Responsibility
Select the user responsibility from the drop-down list.
Masked
Check this box to enable masking for the selected user.
Note: Defining a user and not selecting the masked check box will only create the record and masking rules are not applied.
2.15.2 Create data redaction policy
Once the data masking details are defined and stored in the database, you need to create a data redaction policy which facilitates for field level masking while displaying the details to the respective user. A data redaction policy file contains the policies on the columns enabled in the Data Masking Details screen.
To create data redaction policy
Click Setup > Administration > System > Batch Jobs and execute the following batch job (in single thread mode only):
Set Code
Description
Job Code
SET-RED
POLICY CREATION FOR PERSONAL IDENTIFIABLE INFORMATION DATA
REDPRC_BJ_100_01
This batch job can either be scheduled for regular run or executed on-demand and facilitates to generate data redaction policy picking only the enabled data masking field information from database. On every run, the batch job drops and re-creates new set of policies in the file based on the details updated in Data Masking Details screen.
The generated policy is either written into CLOB or sql file depending on the following option:
Further, the policy file needs to be manually compiled into database schema to apply the masking rules for respective fields for that particular user. Either a system administrator or any other user having administration privileges needs to compile the policies in the database.
Note
For every change in the data masking details such as masking additional fields or unmask­ing / disabling masked fields, a new policy is to be created by executing the batch job.
2.15.3 Masking User defined data
Apart from factory shipped seed data, additional user identified PII data can be masked by uploading an input file with field details and processing it in Data Masking screen using input file processing method.
  1. On identifying the fields, create an input file (in text file format) with table name, column name, and enabled indicator (Y/N) for each field level record. If enabled indicator is ‘N’, the record is not processed for data masking.
For example, BUSINESS_APPL_DETAILS,BSD_LEGAL_NAME,N
  1. Place the input file to repository path as defined in system parameter CMN_SERVER_PATH. For example, /scratch/OFSLL/<release>/input/ipi
  2. Navigate to Setup > Administration > System > Batch Jobs screen and execute the following batch job:
    Set Code
    Description
    Job Code
    SET-IFP
    PI INFROMATION FILE UPLOAD PROCESSING
    IPIPRC_BJ_100_01
On execution, the batch job picks the file from the location, processes it and loads the seed data into Data Masking screen. By default, all the user identified PII data from input file is categorized separately in Data Masking screen by assigning the value of ‘System Defined’ property as ‘N’.
Once the data is available in Data Masking screen, enable the required fields, assign user responsibility and run the processing batch job - redprc_bj_100_01 to generate a redaction policy. For more details, refer Create data redaction policy section.
