3. Deploying Application Interface WebServices
3.1 Creating Data Sources for WebServices
Create a new server on the console which will be specifically for
WebServices.
- Login to WebLogic Server 12c console (http://hostname:port/console).
- The
following window is displayed.
- Click
Domain Name > Services > Data Sources. The following window is
displayed.
- Click
‘Lock & Edit’ button on the left panel. Click ‘New’
on right panel and select ‘Generic Data Source’.
- Specify
the following details:
- Enter Data source Name.
- Enter JNDI Name as ‘jdbc/dbk105nlEJBDS’.
- Select ‘Oracle’ as Database Type.
- Click ‘Next’. The following window is displayed.
- Select the Database Driver ‘Oracle's Driver(Thin)
for Instance connections;Versions:Any’ as shown.
- Click
- Click
- Enter
the Database details.
- Click
‘Test Configuration’. The following window is displayed indicating
a confirmation message as ‘Connection test succeeded’.
- Select target WebServices Server and click ‘Finish’.
- Click ‘Activate Changes’.
Similarly follow the above steps to create the following data sources:
- jdbc/dbkwsDS
- jdbc/IN1HukWznG0b4esj
3.2 Working with SSL
It is not recommended to run OFSLL WebServices with the test certificates
in production. You have to get:
- Vendor public production key/certificates for SSL handshake.
These have to be imported into weblogic truststore.
- RO public production key/certificates to validate digital
signature in the RO inputs. This has to be imported into dls_cacerts
keystore mentioned in the configuration file.
- Generate production grade public/private key signed by
appropriate CA. The public key has to be shared with RO so that they
can validate digital signature in OFSLL requests. The corresponding private
key should not be shared, should be imported into dls_cacerts keystore
mentioned in the configuration file and used to add the digital signature
in RO requests.
Additional Notes
- While testing with the test certificates, you may get error: ‘Signature
verification failed because RSA key public exponent [3] is too small’.
- As a fix, you need to add the following in the start-up script: ‘Dweblogic.security.SSL.allowSmallRSAExponent=true’
- You may encounter error: ‘java.security.InvalidKeyException:
Illegal key size or Cipher not initialize’.
- As a fix add the following in the start-up script: ‘Dweblogic.security.SSL.nojce=true’
- You may encounter error: ‘java.security.InvalidAlgorithmParameterException:
the trustAnchors parameter must be non-empty’.
- As a fix remove the ‘-DUseSunHttpHandler=true’ SSL option
if any from the startup script.
3.2.1 Steps to Import Certificates
to keystore
- The JKS(dls_cacerts) should be available under /WEB-INF/classes/config.
- Save all the certificates from the vendor website. Note
to save the certificates in "Base-64 encoded X.509(.CER)" and with extn
.cer. Steps for saving certificates from the vendor website:
- Click on the padlock and choose ‘View Certificates’.
- Click
on the Certification Path tab and select the certificate with the ‘Name’
and ‘Issued To’ the same as the user-defined ID.
- Go
to the Details tab.
- Click
on the ‘Copy to File’ button, and click ‘Next’.
Select ‘Base-64 encoding’ and save the file somewhere on
your local computer.
- Run following command to import certificate into JKS(dls_cacerts)
- "keytool -keystore <Key store Path> /dls_cacerts -import -trustcacerts
-file <Certificate location in file system>\xxx.cer -alias <alias
as mentioned in config file>
- Run following command to view details of certificate like
expiration date of certificate etc.
- "keytool -list -rfc -alias alias <alias as mentioned in config
file> -keystore <Key store Path> /dls_cacerts
- "keytool -list -v -alias alias <alias as mentioned in config
For more details on keytool refer the link: http://docs.oracle.com/javase/7/docs/technotes/tools/windows/keytool.html
3.2.2 Enable SSL Debugging
SSL debugging can be enabled by adding the following to managed server
start-up script: ‘Dssl.debug=true’
3.2.3 Connecting to service supporting
only TLS protocol
For WLS 12c by default (acting as a client) will send sslv2 hello
for the SSL handshake to TLS service. The TLS service will not respond
to SSLv2 hello and the connection will be dropped.
The fix for the problem is to set Dweblogic.security.SSL.protocolVersion=TLS1
at the Managed server level in which the WebServices have been deployed.
3.3 Create RouteOne Credentials and
System Policies
In order Configure RouteOne, you need to create credentials and system
policies.
- Login to Oracle Enterprise Manager 12c (http://hostname:port/em).
- On the left panel, right click on OFSLL_domain and select
Security > System Policies > Credentials. The following window
is displayed.
- Click ‘Create
Map’. The following window is displayed.
- Enter Map Name as
‘ofsll.int.routeone’ and click ‘OK’.
- Click ‘Create Key’. The following window is
displayed.
- Click ‘OK’.
Similarly you need to create the following Maps and corresponding
keys as indicated in following table.
Maps
Key Name
Username
Password
Description
ofsll.int.routeone
routeone_key_store_password
keystorePassword
changeit
The keystore password
routeone_key_alias
roKeyAlias
routeone_pub_tst
RouteOne's public key alias
name.The public key is needed to verify the xml signature of the request.
routeone_sscro_key_alias
sscroKeyAlias
ssc_routeone
OFSLL's private key alias
name. The private key is used to sign xml response to RouteOne
routeone_sscro_key_passsword
sscroKeyPassword
demotestSSCR1
OFSLL's private key password
You need to provide access permission for the below mapping. For details
on how to set the access permission, refer to point 9 in ‘Create
Credentials and System Policies’ topic available in Application
Installation Guide.
Permission Class
Resource Name
Permission Actions
oracle.security.jps.service.credstore.CredentialAccessPermission
context=SYSTEM,mapName=
ofsll.int.routeone,keyName=*
read
3.4 Deploying Webservices
3.4.1 Deployment of WebServices in Enterprise Manager
- Download and unzip the WebServices - ofsllxws.zip.
- Following is a mapping of which EAR is needed for which
service:
dbkls-xxws.ws.app.ear
dbkls-xxws.ws.app-dt.ear
dbkls-xxws.ws.app-ds.ear
dbkls-xxws.ws.app-ro.ear
DialerIntegrator: Service
to integrate with third party dialer systems
DT Interface: To receive
loan application from dealer track
DS Interface: To receive
edocs application update
RO Interface: To receive
loan application from route one
CSSAccountDetailsRequestService:
Service to fetch Account Details by account number
loan application/deal update from dealer track
edocs comment update
loan application/deal refresh from route one
CSSAccountSearchRequestService:
Service to fetch Account Details by attributes such as AccountNumber,
CustomerFirstName, CustomerLastName, SSN
comments from dealer track
edocs location update
comments from route one
CSSPostTransactionsRequestService:
To post different transactions such as update address, update phone
number, update ACH details, etc
LOSPostStatusRequestService:
To post comments to dealer track
To post comments to route one
CSSAccountPayOffQuoteRequestService:
To get the account payoff quote
To post application status to dealer track
To post application status to route one
LOSeApplicationRequestService:Edocs
application update service
ILOSPostDealerDetailsService:
To post dealer details to dealer track
LOSApplicationRequestService:
Loan application entry service
LOSApplicationSearchRequestService:
Application Search service
LOSApplicationCommentUpdateService:
Edocs application comment update service
Service to post loan application status
LOSApplicationUpdateService:
Service to update an existing application
LOSCheckStatusRequestService:
Service to check application status
LOSApplicationAccountWebService:
Service to create Account number in OFSLL
LOSEContractService:
To recieve contract information from RouteOne
- Unzip all the ear files present:
- dbkls-xxws.ws.app.ear
- dbkls-xxws.ws.app-dt.ear
- dbkls-xxws.ws.app-ro.ear
- dbkls-xxws.ws.app-ds.ear
- Open each of the unzipped files and unzip the war file.
- It creates a WEB-INF file
After unzipping the war file to directory, the directory will have
the following structure
- dbkls-xxws.ws.app / dbkls-xxws.ws.app-ds / dbkls-xxws.ws.app-dt /
dbklsxxws.ws.app-ro
- /dbkls-xxws.ws.app/dbkls-xws-web
WEB-INF (directory)
---->classes (directory)
- config
- class files (in package folders)
-----> lib (directory)
- jdom-2.0.6.jar
- OfsllCommonCSF.jar
- soap-2.3.1.jar
------> wsdl (directory)
- *.wsdl
-----> *-java-wsdl-mapping.xml
-----> web.xml
-----> weblogic.xml
-----> weblogic-webservices.xml
-----> weblogic-webservices-policy.xml
-----> webservices.xml
- To edit the web interface config files, navigate to the
above WEB-INF > classes > config. Edit the following configuration
files with the application url and port.
For complete details on configuration parameters, refer to “Appendix - Configuration parameters”
section in Appendix chapter.
- ds_servlet_init.conf-This is the configuration file only for edocs
servlet interface
- dt_servlet_init.conf-
This is the configuration file only for dealer track servlet interface
- ro_servlet_init.conf-
This is the configuration file only for route one servlet interface
- Login to Web Logic application server enterprise manager
(e.g.: http://hostname:port/em)
- Enter valid login credentials. The following window is displayed.
- Expand the weblogic domain present in the left pane. The following
- Right click on WebService_ManagedServer in left panel, select
Application Deployment > Deploy.
- The following window is displayed.
- Browse to the folder containing the WebService.
Eg: /scratch/ofsllxws/dbkls-xxws.ws.app
Click ‘Next’.
- The following window is displayed. Select the server on
which the WebService needs to be deployed. Click ‘Next’.
- The following window is displayed. Check the context root
and click ‘Next’.
- The following window is displayed. Click ‘Deploy’.
- The following window is displayed. Click ‘Close’.
- If required, similarly deploy rest of the WebServices.
- In case the context root has to be changed for the WebServices,
it can be changed by editing the application.xml or through the console.
To change through console, login to WebLogic Server 12c console (http://hostname:port/console).
- Go to Deployments > <select the service deployment>
> Configuration General and modify the context root to the recommended
name as follows:
Service
Service EAR
Recommended Context
Remark
Webservices
dbkls-xws-app
If this the recommended
context name is not used, then the Service URLs in the configuration
files needs to be changed
Edocs Interface
dbkls-xws-app-ds
Dealer Track Interface
dbkls-xws-app-dt
Route One Interface
dbkls-xws-app-ro
- Ensure that the application status is ‘Active’.
