This manual is designed to help you quickly get acquainted with the Integration Gateway of Oracle FLEXCUBE ELCM.
It provides an overview to the module, and provides information on using the Integration Gateway module of Oracle FLEXCUBE ELCM. This user manual is a supplement to the Common Core - Core Entities and Services User Manual and contains only specific functionalities and information related to Oracle ELCM Gateway Services. Hence, this document should be read in conjunction with the Common Core - Core Entities and Services User Manual from the perspective of completeness in flow and understanding.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
Function |
IT department members responsible for integration |
Input functions for maintenance related to the gateway |
IT managers |
Authorization functions |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Abbreviation |
Description |
OFCL |
Oracle FLEXCUBE Corporate Lending |
The manual is organized in the following manner:
Chapter |
Description |
Chapter 1 |
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Gateway Functions - An Overview explains the features of this module. |
Chapter 3 |
External System Maintenance explains the maintenance of external systems and the various processes involved. |
Chapter 4 |
Message Formats explains the different message formats. |
Chapter 5 |
Annexure – List of Messages lists all the messages that you encounter while working with Oracle FLEXCUBE ELCM Gateway services. |
Chapter 6 |
Planned Outage Support Server describes the process of having a support server to substitute the host server during downtime. |
Chapter 7 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons:
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
