1. Preface
1.1 Introduction
This document is designed to help acquaint you with the integration among Oracle FLEXCUBE products namely; Oracle FLEXCUBE Universal Banking Solutions (FCUBS) and Oracle FLEXCUBE Corporate Lending (OFCL).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and pressing the <F1> key on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface
Back office Managers/Officers
Authorization functions
End of day operators
Processing during end of day/ beginning of day
Implementation Partners
Provide customization, configuration and implementa­tion services
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized into the following chapters:
Chapter
Description
Chapter 1
Preface gives information on the intended audience. It also lists the vari­ous chapters covered in this User Manual.
Chapter 2
Oracle OFCL - FCUBS Integration explains the integration between Oracle FLEXCUBE Corporate Lending and Oracle FLEXCUBE Universal Banking systems.
Chapter 3
Annexure provides the details of data exchange and further reference sources.
Chapter 4
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Acronyms and Abbreviations
Abbreviation
Description
System
Unless and otherwise specified, it shall always refer to Oracle FLEX­CUBE Universal Banking Solutions system
FCUBS
AC
Accounting
GL
General Ledger
ECA
External Credit Approval
EAC
External Account Check
FCY
Foreign Currency amount
LCY
Local Currency amount
XML
Extensible Markup Language
OL
Oracle Lending
DDA System
System that holds the CASA account and balances
EOD
End Of Day
OFCL
ROFC
Rest of Oracle FLEXCUBE
CASA
Current and Savings Account
1.6 Glossary of Icons
This user manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.7 Related Information Sources
Along with this user manual, you may also refer to the following related sources:
