1. About this Manual
1.1 Introduction
This manual is essentially designed to help you set up products in Oracle Lending. It takes you through the various steps involved in creating a product.
Besides this user manual, you can find answers to specific features and procedures in the Online Help, which can be invoked by choosing ‘Help Contents’ from the Help Menu of the software. Further, you can obtain information specific to a particular field by placing the cursor on the relevant field and pressing <F1> on the keyboard.
1.1 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office clerk
Input functions for contracts
Back office managers/officers
Authorization functions
Product Managers
Product definition and authorization
End of day operators
Processing during end of day/ beginning of day
Financial Controller/Product Manag­ers
Generation of reports
1.2 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.3 Organization
This manual is organized into the following chapters:
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Product Definition provides a snapshot of creating and identifying various components of a product.
Chapter 3
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.4 Related Documents
For further information on procedures discussed in the manual, refer to the following manuals:
1.5 Glossary of Icons
This User Manual may refer to all or some of the following icons:
Icons
Function
Exit
Add row
Delete row
Option List
