11. Reports
Every action that results in a debit or credit to the customer’s monetary account is recorded. The advices are generated and sent to the customer depending on the advice generation frequency that you have specified.
You can generate the following reports:
11.1 Maintaining Printing Options for Reports
You can indicate preferences to print a report, while generating a report; however, the preferences are general.
The following are the common preferences you can maintain to print a report:
Format
Select the format in which you want the report to be generated from the options provided in the drop-down list. The following options are available:
Output
Select the output for the report from the options provided. The following options are available:
Printer At
Select location where you wish to print the report from the adjoining drop-down list. This list displays the following values:
Printer
Specify the name of the printer or select it from the option list provided. All the configured printers are displayed in the list.
This is applicable only if you have specified the output as ‘Print’.
11.2 IRA Statement Reports
11.2.1 Generating IRA Statement Reports
An IRA statement is a statement of accounts for an IRA plan. You will be able to generate statements for a list of all the transactions carried out in an IRA plan for the statement generation frequency specified for the plan. You also have the option of generation on an ad-hoc basis.
11.2.2 Selection Options
You can choose to generate the account statements for transactions involving all plans within your branch or for transaction within a single plan or for a range of plans.
You will also have to indicate the date range for the generation of the report.
11.2.3 Contents of the Report
The options that you specified while generating the report are printed at the beginning of the report. The contents of the IRA Statement have been discussed under the following heads:
Header
The Header carries the title of the Report, information on the branch code, the date and time at which the report was generated and the page number of the report.
Body of the Report
Field Name
Description
Customer Infor­mation
The CIF Number, full Name and mailing address of the cus­tomer as recorded in the CIF Maintenance screen
Plan Number
The reference number of the plan involving the transaction
Plan Type
The plan type involving the plan
Period of the statement
The period for which you are generating the statement
Statement Number
The statement number of the statement
Plan Balances
The balances in the plan at the beginning and end of state­ment period (Current and Previous Years)
The current balance is reflected for the current year and the year ending balance (after considering contributions and distributions done during the current year for the previous year) for the previous year.
Total Contributions
Excess Contributions
Total Distributions
Total Employer Contributions (where applicable)
Excess Employer Contributions
Transaction Information
Transaction type (Contributions, Distributions, Monetary Account Interest).
Transaction Reference Number
Amount and Currency
Transaction Year
Monetary Account Breakup
Account (Branch, Account, Currency)
Amount and Currency
Withholding Tax information (where applicable)
Tax Withheld (Amount and Currency)
Transaction Remark (if any)
Plan Balance after the transaction (current and previous year balances)
Transactions are sequenced in the manner in which they were processed in the system.
11.3 Minimum Withdrawal Advice Reports
11.3.1 Generating Minimum Withdrawal Advice Reports
This advice is sent to all customers approaching the minimum distribution age. The advice contains information about all the plans held by the customer under the plan type.
Since it is not generated automatically, you have to invoke the advice generation screen and identify the Plan Type and the Reference Number of the plan involving the plan type for which the minimum distribution age advice is to be generated.
11.3.2 Apart from the header the following details are printed for the report:
Body of the Report
Field Name
Description
The CIF Number, full Name and mailing address of the customer as recorded in the CIF Maintenance screen.
Plan Type
The plan type involving the plan.
Plans Held
This information includes:
Plan Number.
Plan Balances (current year only)
Plan Balance
Total Contributions
Total Distributions
Plan Remarks (if any)
11.4 Charge Advice Reports
11.4.1 Generating Charge Advice Reports
This advice is sent to all customers on whom you are levying a charge as a result of the IRA Charge set-up. The system generates this advice automatically as part of the EOD processes on the day the charge liquidation takes place.
11.4.2 Contents of the Report
Body of the Report
Field Name
Description
Customer Information
The CIF Number, full Name and mailing address of the cus­tomer as recorded in the CIF Maintenance screen.
Charge Code
The Code associated with the Charge for which you are charging the customer.
Charge Level
Indicates the level at which charging is being done:
CIF Level or
Plan level
Plan Type
Charge Amount and Currency
The charge is always charged in the local currency of your branch.
Liquidation Date
The date on which the charge amount was liquidated.
Debit Account Infor­mation
The Branch, Account Number and Currency of the account involved in the transaction.
11.5 IRS Form 5498
11.5.1 Generating IRS Form 5498
Oracle FLEXCUBE allows you to generate Form 5498 for reporting contributions to IRA plans for any year to the Internal Revenue Service (IRS). You can generate this report for:
You can generate Form 5498 either as part of initial filing with the IRS or after you have filed tax returns for that particular year.
11.5.2 Generating Form 5498 as Part of Initial Filing
During normal generation of Form 5498 as part of your initial filing with the IRS, the system will include all transactions entered in the previous year for the previous year. For example, during normal generation of Form 5498 on, say, January 20, 2003, all transactions entered during 2002 and pertaining to the financial year 2002 will be reported.
11.5.3 Generating Form 5498 after Tax Filing
During corrected generation post the date of tax filing, the system will include, apart from all the transactions included in normal generation, such transactions which are entered in the current year for the previous year. The report shows the total contributions for the year.
11.5.4 Details printed on Form 5498
Oracle FLEXCUBE generates Form 5498 customer-wise and plan-wise – that is, for each customer for each type of plan held by the customer. The type of plan can be Traditional IRA, Roth IRA, SEP, SIMPLE, etc.
The form contains the following details:
Note
IRA codes that you have marked for not reporting to the IRS will be left out of all of the above summations.
11.6 IRS Form 1099-R
11.6.1 Generating IRS Form 1099-R
Oracle FLEXCUBE allows you to generate Form 1099-R for reporting distributions from a selected type of IRA plan for any year to the Internal Revenue Service (IRS). You can generate this report for:
You can generate Form 1099-R either as part of initial filing with the IRS or after you have filed tax returns for that particular year.
11.6.2 Generating Form 1099-R as Part of Initial Filing
During normal generation of Form 1099-R as part of your initial filing with the IRS, the system will include all transactions entered in the previous year for the previous year. For example, during normal generation of Form 1099-R on, say, January 20, 2003, all transactions entered during 2002 and pertaining to the financial year 2002 will be reported.
11.6.3 Generating Form 1099-R after Tax Filing
During corrected generation post the date of tax filing, the system will include, apart from all the transactions included in normal generation, such transactions, which are entered in the current year for the previous year. The report shows the total contributions for the year.
11.6.4 Details printed on Form 1099-R
Oracle FLEXCUBE generates Form 1099-R for each customer for a distribution code. You have the option of combining distributions with the same code from any number of different plan/product types.
Note
IRA codes that you have marked for not reporting to the IRS will not be available for gen­eration of 1099-R forms.
Form 1099-R contains the following details:
11.6.4.1 Filling IRS Forms Electronically
IRS regulations stipulate that any entity filing 250 or more forms of each type must do so in electronic or magnetic form. You can access IRS’s Filing Information Returns Electronically (FIRE) system over a dial-up network and through a browser or through communication software like ProComm. You can log on to the system using the logon name, password and PIN provided to you by the IRS.
11.7 Customer Account Opening Confirmation Report
You can generate a report for the customer, confirming that his / her account with the bank has been successfully opened. This report contains the following details:
You can generate the Customer Account Opening Confirmation report for one customer or all the customers at once, as of a specific date. To generate the report, invoke ‘Customer Account Opening Confirmation’ screen.
You can invoke this screen by typing ‘CSRPACCO’ in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
The screen is as shown below:
Customer Report
You can generate customer account opening confirmation report for one or all the customers. Indicate your choice here. If you select ‘Single Customer’, you have to specify the customer number in the space provided.
Customer Number
If you wish to generate a report specific to one customer, specify the customer number. The option list displays all valid customer numbers maintained in the system. Select the appropriate one.
Date
Specify the date as of which you want to generate the report.
Once you have set the preferences, click ‘OK’ button. The system displays the print option screen, where you can set your preferences as to viewing and printing the report.
11.8 Report for NSF Returned Cheque
11.8.1 Generating Report for NSF Returned Cheque
You can generate NSF report to list the returned cheque details. You can invoke ‘Cheque return Data Over Counter’ screen by typing ‘STRNSFC’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the following here:
Branch Code
Select the transaction branch of the float extension from the adjoining option list.
From Date
Indicate the date from which transactions are extended. The system defaults current date. From Date should be lesser than or equal to ‘To Date’.
To Date
Indicate the date to which the transactions are extended. The system defaults current date. To Date should be lesser than or greater to ‘From Date’
11.8.2 Contents of the Report
The contents of the report are discussed under the following heads:
Header
The header carries the Branch Code, Account Type, Application Date.
Body of the Report
Field Name
Description
Bank Code
Indicates the bank code
Cheque No
Indicates the Cheque No which is returned in the counter
Account No
Indicates the Account Number of the customer whose cheque is returned in the counter
Blacklist Type
Indicates the type of blacklist.
Account Type
Indicates the type of the account whose cheque has been rejected
Reason
Indicates the reason for the rejection
Customer Name
Indicates the name of the customer whose cheque has been rejected over the counter
Customer Type
Indicates the type of the customer (Individual / Joint).
Unique Number
Indicates the unique reference number for identifying the transaction.
Date of Birth
Indicates the date of birth of the customer.
Address
Indicates the contact address for the customer whose cheque has been rejected.
City
Indicates city of the customer.
11.9 Report of Blacklisted Customers
11.9.1 Generating Blacklisted Customers Report
You can generate a report for blacklisted customers from internal banks and agencies. To invoke ‘Blacklisted Customers from Internal Bank’ screen, type ‘STRNSFBC’ in the field at the top right corner of the Application tool bar and click the adjoining arrow button.
Branch Code
From Date
To Date
Report Format
Select the format in which you need to generate the report from the adjoining drop-down list. This list displays the following values:
Report Output
Select the report output in which you need to generate the report from the adjoining drop-down list. This list displays the following values:
PrinterAt
Printer
Select printer using which you wish to print the report from the adjoining option list.
11.9.2 Contents of the Report
Header
The header carries the Branch Code, Blacklisted Type, Application Date.
Body of the Report
Field Name
Description
Cust No
Indicates the customer identification number of the customer who is marked as blacklisted customer in central bank / internal bank
A/c No
Indicates the primary account no of the customer who is marked as blacklisted customer
Brn Code
Indicates the branch of the customer account
NSF Level
Indicates the current NSF level for the customer
Description
Indicates the NSF level description
IB Status
Indicates the Internal blacklist status,
IB Status Desc
Indicates the description for the internal blacklist
IB Eff Date
Indicates the effective date from which the customer is marked as internally blacklisted customer
IB ExpDate
Indicates the effective date till which the customer is marked as internally blacklisted customer
CB Status
Indicates the central bank blacklist status of the cus­tomer
CB Status Desc
Indicates the description for the central bank blacklist status
CB Eff Date
Indicates the effective date from which the customer is marked as central bank blacklist status
CB Exp Date
Indicates the effective date till which the customer is marked as central bank blacklist status
11.10 Report of Blacklisted Customers from Central Bank
11.10.1 Generating Central Bank Blacklisted Customers Report
You can generate a report for blacklisted customers from central bank or agencies. You can invoke ‘Blacklisted Customers from Central Bank’ screen by typing ‘STRNSFCB’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
From Date
To Date
Indicate the date to which the transactions are extended. The system defaults current date. To Date should be lesser than or greater to ‘From Date’.
Report Format
Report Output
PrinterAt
Printer
11.10.2 Contents of the Report
Header
Body of the Report
Field Name
Description
Customer No
Branch Code
Account No
Indicates the customer account number
NSF Level
NSF Level Description
Account No
IB Status
IB Status Description
IB Effective Date
IB Expiry Date
CB Status
CB Status Description
CB Effective Date
CB Expiry Date
11.11 Report for Actions Triggered During NSF Status Change
11.11.1 Generating Actions Triggered During NSF Status Change Report
You can generate a report to list the actions which are triggered during the NSF status change. You can invoke ‘NSF Action Details’ screen by typing ‘STRNSACT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Customer No
Specify a valid customer number for which you want to generate the report from the adjoining option list.
From Date
Indicate the date from which transactions are extended. The system defaults current date. From Date should be lesser than or equal to 'To Date'.
To Date
Indicate the date to which the transactions are extended. The system defaults current date. To Date should be lesser than or greater to 'From Date'
Report Format
Report Output
PrinterAt
Printer
11.11.2 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report.
Header
The header carries the title of the report, branch code, branch name, module code, report generation date and time, user ID of the user who generated the report and the page number of the report.Body of the Report
Field Name
Description
Customer No
Event No
Indicates the Event number
Action No
Indicates the Action Number
Action Comp
Indicates the Action Component
Status
Indicates the Status
Remarks
Indicates the Remarks
Err Code
Indicates the Error Code
Err Desc
Indicates the Error Description
Action Date
Indicates the Action Date
11.12 Netting Report
11.12.1 Generating Netting Report
You can generate a Customer, Currency and Date wise report to retrieve details of contracts/amounts that were netted.
You can specify the following preferences for the report:
Note
11.12.2 Contents of the Report
The report options that you selected while generating the report are printed at the beginning of the report.
The contents of the report are discussed below:
Body of the Report
Field Name
Description
Counterparty
This is the name of the counterparty whose netted con­tract details are being displayed.
Contract Reference Number
This is the reference number of the contract which was netted.
Component
This is the name of the component (Amount Tag) involved in the transaction.
Amount
This is the amount for which the particular entry was passed.
Account Due
This is the account to which the netted amount is either debited/credited.
11.13 Combined Statement Reports
11.13.1 Generating Combined Statement Reports
This report is an ad-hoc combined statement of accounts for a customer, generated for a particular period. This report is grouped account class wise. This report helps in providing a single statement to the customers who own multiple accounts.
You can invoke ‘Statement of Combined Generation’ screen by typing ‘CSRCSTAD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the following details here:
Branch Code
Select the branch code from the adjoining option-list. The list displays all valid branch codes.
Customer No
Select the customer number from the adjoining option-list. This list displays all valid customers maintained in the system.
From Date
Select the From date for statement generation. By default the current application date is displayed here.
To Date
Select the To date for statement generation. By default the current application date is displayed here.
Click ‘OK’ button to generate the report. Click ‘Exit’ to return to the Reports Browser.
11.13.2 Contents of the Report
Header
The header carries the Customer Name, Customer Address, Account Class, Account Number, Opening balance, Currency and Branch.
Body of the Report
Field Name
Description
Account Class
This indicates the account class
Account Number
This indicates the account number
Branch
This indicates the branch code
Opening Balance
This indicates the opening balance
Transaction Date
This indicates the transaction date
This indicates the transaction reference
Transaction Code
This indicates the transaction code
Description
This is the description of the transaction
Ccy
This indicates the currency of the transaction
Credit Amount
This indicates the Credit amount
Debit Amount
This indicates the Debit amount
Balance
This indicates the Balance
11.14 Missing Signature Report
11.14.1 Generating Missing Signature Report
This is an exception report listing all the customers, of a specified branch, whose signatures have not yet been captured in the system.
While opening accounts, customer's signature/photographs/thumb impression are captured and linked to the account. This facilitates the signature verification in the system at the time of making payment. Branches can generate this ad-hoc report, and capture the missing signature in the system.
You can invoke ‘Signatures not Captured’ screen by typing ‘CSRSNREP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
11.14.2 Contents of the Report
Header
The Header carries the Branch, Date, User ID and the Module for which the report is generated.
Body of the report
The generated report will have the following information:
Field Name
Description
Customer ID
This indicates the unique id of the customer
Customer Name
This indicates the name of the customer
CIF Creation Date
This indicates the creation date of the customer
Check ID
This indicates the id of the check ID of the author­izer
11.15 Large Credit Transaction Report
11.15.1 Generating Large Credit Transaction Report
You can invoke 'Large Credits Report' screen by typing 'CSRCRDR' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
11.15.2 Contents of the Report
Header
The header carries the Report Name, Branch, Branch Date, User Id, Module, Run Date and Time.
Body of the Report
Field Name
Field Description
Branch Code
Indicates the branch code
Account Number
Indicates the account number
Customer Name
Amount Credited
Indicates the amount credited. The credit trans­action amount of the current day is displayed which is greater than 50,000 or 500,000. For retail customers an amount greater than 50,000 is displayed. For corporate customers an amount greater than 500,000 is displayed.
Total Amount Credited
Indicates the total amount credited. The total of credit transactions for the last 60 days including the current is displayed.
Average Credit
Indicates the average credit. This value is cal­culated as the total amount credited (including the current day’s transactions) / 60.
Largest Credit
Indicates the largest credit. The highest credit transaction for the last 60 days (including the current day’s transaction) is displayed. The amount displayed should be greater than 50,000 or 500,000.
Date of Largest Credit
Indicates the date of the largest credit
Customer MIS code
Indicates the customer MIS code
11.16 Large Debit Transaction Report
11.16.1 Generating Large Debit Transaction Report
You can invoke 'Large Debits Report' screen by typing 'CSRDEBR' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
11.16.2 Contents of the Report
Header
Body of the Report
Field Name
Field Description
Branch Code
Account Number
Customer Name
Amount Debited
Indicates the amount debited. The debit transaction amount of the current day is displayed which is greater than 50,000 or 500,000. For retail customers an amount greater than 50,000 is displayed. For cor­porate customers an amount greater than 500,000 is displayed.
Total Amount Debited
Indicates the total amount debited. The total of debit transactions for the last 60 days including the current is displayed.
Average Debit
Indicates the average debit. This value is calculated as the total amount debited (including the current day’s transactions) / 60.
Largest Debit
Indicates the largest debit. The highest debit transaction for the last 60 days (including the current day’s transaction) is displayed. The amount displayed should be greater than 50,000 or 500,000.
Date of Largest Debit
Indicates the date of the largest debit
11.17 Daily Account Opening Statistics Report
11.17.1 Generating Daily Account Opening Statistics Report
You can invoke 'Daily Account Opening Statistics Report' screen by typing 'CSRDLACC' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
11.17.2 Contents of the Report
Header
Body of the Report
Field Name
Field Description
Branch
Account Number
Account Type
Account Name
Indicates the name of the account
Processor ID
Indicates the processor Id
Authorizer ID
Indicates the authorizer Id
Customer Name
11.18 Dormant Account Reactivated Report
11.18.1 Generating Dormant Account Reactivated Report
You can invoke 'Dormant Account Reactivated Report' screen by typing 'CSRDRMAC' in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
You can generate this report for all the branches or a single branch alone. You can indicate the branch for which the report is being generated using the following options:
From Date
Specify a valid date from when you wish to generate the report from the adjoining calendar.
To Date
Specify a valid date till when you wish to generate the report from the adjoining calendar.
11.18.2 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the report is as follows:
Header
Body of the Report
Field Name
Field Description
Customer Ac No
Indicates the account number of the customer
Customer Type
Customer Name
Currency
Indicates the currency
Re-activation Date
Indicates the re-activation date
Dormancy Start Date
Indicates the start date of dormancy
Local Branch
Indicates the local branch
Branch Code
Branch Name
Indicates the name of the branch
Checker ID
Indicates the identification of the checker who authorized the record
Checker Date
Indicates the date on which the record was authorized
Maker ID
Indicates the identification of the maker of the record
Maker Date
Indicates the date when the record was created
11.19 360 Degree Customer Report
11.19.1 Generating 360 Degree Customer Report
The 360 Degree Customer report provides 360 Degree Customer details. You can invoke the screen by typing 'STRCUSRP' in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
You can specify the following parameters:
Customer Number
Customer Name
System defaults the customer name of the selected customer number.
11.19.2 Contents of the Report
Header
The following details are displayed in the header section:
Field Name
Field Description
Branch
Indicates Branch Code and Branch Name
Branch Date
Indicates Current Date of the Branch
User ID
Indicates User ID
Date & Time
Indicates the Date and Time when the report was gen­erated
Module
Indicates module for which report is generated.
Body of the Report
The following details are displayed as body of the generated report:
Field Name
Field Description
Customer Details
Displays Customer Details
Retail Deposit Details
Displays Retail Deposit Details
Corporate Deposit Details
Displays Corporate Deposit Details
Islamic Deposit Details
Displays Islamic Deposit Details
Consumer Loans
Displays Consumer Loans Details
Mortgage
Displays Mortgage Details
Leasing
Displays Leasing Details
Syndicate Loan Details
Displays Syndicate Loan Details
Islamic Financing
Displays Islamic Financing Details
CASA Deposits
Displays CASA Deposits Details
Islamic Accounts
Displays Islamic Accounts Details
Bills Details
Displays Bills Details
Islamic Bills
Displays Islamic Bills Details
LC Details
Displays LC Details
Islamic LC Details
Displays Islamic LC Details
Foreign Exchange Details
Displays Foreign Exchange Details
Money Market Details
Displays Money Market Details
Security Portfolio
Displays Security Portfolio Details
Derivatives
Displays Derivatives Details
OTC Options
Displays OTC Options Details
ETD Portfolio Details
Displays ETD Portfolio Details
Islamic Money Market Details
Displays Islamic Money Market Details
Islamic Derivatives
Displays Islamic Derivatives Details
Upcoming Events
Displays Upcoming Events Details
Overdue Loans
Displays Overdue Loans Details
Term Deposits Matured But Not Liquidated or Renewed
Displays Term Deposits Matured But Not Liqui­dated or Displays Renewed Details
Corporate Deposits Matured But Not Liquidated or Renewed
Displays Corporate Deposits Matured But Not Liquidated or Displays Renewed Details
Locker Due
Displays Locker Due Details
Cheque Return
Displays Cheque Return Details
Amount Blocks
Displays Amount Blocks Details
Stop Payments
Displays Stop Payments Details
Limits
Displays Limits Details
Line Details
Displays Line Details
Collateral Details
Displays Collateral Details
SCHEMES
Displays Schemes Details
Fund Transfer Details
Displays Fund Transfer Details
Payments and Collections Details
Displays Payments and Collections Details
Mutual Fund
Displays Mutual Fund Details
Insurance
Displays Insurance Details
Credit Card
Displays Credit Card Details
11.20 Netting Group Transaction Report
11.20.1 Generating Netting Group Transaction Report
The Netting Group Transaction report provides netting group transaction details. You can invoke the screen by typing 'STRGRNET' in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
Group Code
Specify a valid group code for which you want to generate the report from the adjoining option list.
Account Number
You can generate the report based on the following account number criteria. The following options are available for section:
Specify a valid account number for which you want to generate the report from the adjoining option list, if you have selected 'One'.
Date
You can generate the report based on the following date criteria. The following options are available for section:
Specify a valid date for which you want to generate the report from the adjoining option list, if you have selected 'One'.
11.20.2 Contents of the Report
Header
Field Name
Field Description
Branch
Branch Date
User ID
Indicates User ID
Date & Time
Indicates the Date and Time when the report was generated
Module
Body of the Report
Field Name
Field Description
Netting Reference Number
Indicates Netting Reference Number
Netting Date
Indicates Netting Date
Account Number
Indicates Account Number
Account Branch
Indicates Account Branch
Account Currency
Indicates Account Currency
Indicates Transaction Reference Number
Transaction Date
Indicates Transaction Date
Debit Amount
Indicates Debit Amount
Credit Amount
Indicates Credit Amount
Total Debit
Indicates Total Debit
Total Credit
Indicates Total Credit
Net Debit
Indicates Net Debit
Net Credit
Indicates Net Credit
11.21 Print Maintenance Control Log Report
11.21.1 Generating Print Maintenance Control Log Report
The Print Maintenance Control Log report provides print maintenance control log details. You can invoke the screen by typing 'STRMSMLG' in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
Report Options
Function ID
Specify a valid Function ID for which you want to generate the report from the adjoining option list.
You can generate the report based on the following change criteria. The following options are available for section:
Print Copies
Check this box if you wish to print copies of the report.
11.21.2 Contents of the Report
Header
Field Name
Field Description
Branch
Branch Date
User ID
Indicates User ID
Date & Time
Module
Body of the Report
Field Name
Field Description
Maintenance Program
Indicates Maintenance Program
Action
Indicates Action
Mod Number
Indicates Mod Number
Field Name
Indicates Field Name
New Value
Indicates New Value
Old Value
Indicates Old Value
Maker ID
Indicates Maker ID
Maker Date
Indicates Maker Date
Checker ID
Indicates Checker ID
Checker Date
Indicates Checker Date
